Results 1 to 36 of 36
    011100000110111101101111
    Reputation: unfluid one's Avatar
    Aug 2005
    Custom hardtail geometry check!
    I'm putting together some numbers for a custom steel hardtail using true temper platinum ox and wanted to run the numbers by you guys. I think these are pretty standard, but not sure if I should consider increasing or decreasing angles by 0.5 degrees. I'll be using it as a trail bike with the ability to handle drops, jumps, etc. Pretty much like a Chameleon, Sinister, etc in a steel singlespeed format. Hopefully comes in ~6lbs. I ride in the SF bay area in Northern CA. Rides vary from XC rides with a lot of climbing, to drops, rock gardens, stunts, log drops, technical descents, depending on where we ride. And occasionally i'll hit some doubles.
    #s based on a 150mm 535cm a-c fork (EDITED from 160mm)
    Effective top tube length: 23.25" (EDITED from 23)
    Seat tube length: 17"
    Bottom bracket height: 12.5"
    Chainstay length: TBD, This should be optimized based on 32x18 singlespeed gearing, where the axle position is slightly forward of the halfway mark in the flanged Paragon drop outs to maximize the dropout & plate overlap.
    Probably comes in around 16.75 or so? According to the calculator here.. if someone familiar with these calculations can double check, would be great.
    Seat tube angle: 72
    Head tube angle: 68 (EDITED from 68.5)
    Head tube length: any opinions here? Will be using press fit headsets like chris king
    mbtr member
    Reputation: scottzg's Avatar
    SS'ing with a big fork sucks, imo (so do long forks on hardtails), but if i was gonna do it, i'd prolly steepen the STA, lengthen the TT and run the shortest stays i possibly could. Give me a little more breathing room and keep the rear wheel weighted as i stand up every climb.
    STA isn't a super important measurement since you can really adjust it with an offset post and sliding the seat. I like short head tubes and high rise bars for the nad clearance and possibility to really lower the bars if you shrink or something.
    If it were me, and i was dead-set on a 160mm fork (rather than, say, a 36 spacered down to 120-130...) I'd slacken the HT to something like 67. I've got a 130 on my hardtail with a 69* hta and previously had a frame with 67.5 but otherwise the same geo, and the slacker frame was definitely more stable when i went deep into the fork's travel. I didn't really care about the steering either way, just got accustomed to it.
    I'm just a idiot in front of a keyboard, what does your builder think?
    "Things that are complex are not useful, Things that are useful are simple."
    Mikhail Kalashnikov
    Aug 2005
    Thanks for your opinion!
    So I have a 29lb Sinister Ridge which I run SS and have a pike up front. I usually wind it down on the climbs and i have no problems keeping up with the others.. i do all my climbs on platform pedals as well. The #s below are pretty much the same as the ones on the Ridge except a tweak here and there (TT & ST are shorter by .5) and I'm asking for very small TT/ST taco (size will be similar to the one on my Ventana Terremoto) to increase standover.
    I did run a 36Van on the Ridge for a while and I like the pike a whole lot more, so I figure i'd keep the #s generally the same and maybe slacken the HTA by .5 degrees and shorten the rear
    What is considered a short headtube for a steel frame? 4"?
    My builder thinks the #s are just fine at a first glance but so far we've only been really focused on which dropout implementation to go with and frame material
    Ideally I'd like 16.5 CS, but using the SS gearing calculator, i'd have to go shorter to 26.45 and increase my gearing to a 34x18 which I've been considering, or go long with 16.75 and keep my 32x18. The Ridge is 16.7 and have no complains (love it on the downhills.. a bit long at the dirt jumps) but I'm always up to tweak things.
    local trails rider
    Reputation: perttime's Avatar
    Aug 2005
    I went for 34/19 gearing, which works out close enough to 32/18:
    http://gallery.mtbr.com/showphoto.ph.../ppuser/266295
    I like Brant's (On-One) thinking that people have two main reasons to put tall forks on trail hardtails:
    - to get the bar higher (silly way to accomplish that)
    - to get a slacker head angle (unnecessary if the frame is designed to be slack)
    ... the downside of big forks on HT's being that you have huge brake dive that varies your angles by several degrees ...
    At least in my case, tall forks tend to reduce standover clearance to nothing, too.
    Quote Originally Posted by scottzg
    Except that STA and seat position on the post also play together with TT length.
    Reputation: MMcG's Avatar
    Jul 2003
    You sure you want to use True Temper OX platinum on a long travel HT? There might be something more suitable out there - I'd ask whoever you are having build said frame about that aspect of things.
    Aug 2005
    Quote Originally Posted by MMcG
    If there are other better opinions, I am all ears. But my builder-of-interest recommended the Platinum.. i think he uses it on all his DJer type of bikes. I wasn't exactly sure on what tubing i specifically wanted so i left that up to him.
    Jul 2003
    go to bikeforest.com and play around in their free bikeCAD software to see what happens with changes in HT length, ST Angle, bb height etc. It is fun as hell - but be warned, it can get addictive. These are two that I worked up based around a Manitou Nixon Comp at 445mm of travel and with an AC height of 510mm and an offset of 41.25mm.
    FM
    FM is offline
    Reputation: FM's Avatar
    Apr 2003
    Quote Originally Posted by unfluid one
    #s based on a 160mm 545cm a-c fork.
    Here is my take on it: Adjustable travel forks are the way to go! So design your geometry around the amount of travel you will use most often- then just make sure the frame is built to take the extra leverage of a longer fork, even if you only use that longest travel setting occasionally.
    Another way to look at it, is to choose your fork first, then design the frame with the geometry you want based around the middle of the travel adjustment range.
    Unfluid One and I have been rappin' and I've shared the CAD drawing I've created for my upcoming custom frame. If you look at the specs, I designed the frame at 68.5 with a 517mm a2c fork, but specified I may use up to a 545 a2c fork on it. The idea being it will spend %80 of the time with a Fox Talas 36 at 130mm travel setting, but I want to be able to slacken it out just a bit further for the steepest trails.
    Jul 2003
    FM - what's the ETA on delivery of your frame from Curtlo?
    FM
    FM is offline
    Apr 2003
    I think sometime this century
    I'm expecting a sketch any day.
    I expected 4-6 months going into it, so I am still waiting patiently (coming up on 5 months). Really, how it comes out is more important to me than how long it takes. However... the longer it takes the higher my expectations become
    Long as I have it when the snow melts off my favorite trails here, I will be OK with it.
    Aug 2005
    The reasoning behind my #s are kind of round about but I took my current hardtail's geometry based on the 160mm fork it was designed around. Sure I ride a pike at 110 most of the time and drop it or raise it accordingly. The uturn gets used every single ride. As a result my actual riding # are lower and steeper than on paper but I don't know the exact numbers and probably will mess up trying to calculate it myself. But I like the setup so far. Just not sure on chainstay length!!
    Aug 2005
    btw FM has been very helpful with all his charts and diagrams.
    who knows.. i may get my bike before he does! and i haven't even placed my official order yet..
    Jul 2003
    BTW - I asked FTW about the Ridge's geometry numbers that you see on the Sinister Site - and those are based around a 150mm travel fork (as opposed to your 160mm fork).
    Just in case that helps you out a bit.
    Aug 2005
    Oh nice thanks for that info! i sent him and skye an email about that as well this morning but you got it to me faster. 150mm.. what is the a-c on that you think? 535mm probably then?
    I have the 2006.5 model, but i don't think they changed the geo too much.
    Dirt Deviant
    Reputation: savagemann's Avatar
    The numbers look really close to the Inbred 456 i will be finished building tomorrow!
    Should be nice. Based on a 6" fork the geo is
    HTA 68.5
    STA 72
    Chainstay 16.75
    TT 23.9"
    Center to Top 20"
    BB height 12.5 -ish
    http://www.on-one-shop.co.uk/acatalo...ue_456_30.html
    Sounds like you are on the right track! Can't wait to see it.
    aka baycat
    Reputation: Ryan G.'s Avatar
    what builder are you considering? Inquiring minds want to know since the bike setup is ideally what I am going for on a Chromag waiting to get my grubby hands on and we ride in the bay area.
    Aug 2005
    Quote Originally Posted by baycat
    Talking primarily to evil4bc at nemesis projects. he's been very responsive and helpful considering that I have been sending emails to him at all sorts of hours over the past 2-3 days. He is local so that's a big +.
    I also tried to get a hold of Dobermann over email and mtbr since late last week but they haven't responded. I essentially wanted a big brother to the Molosse to take advantage of the nifty sliding dropouts.
    I did consider Chromag and contacted mike truelove + ian about a custom stylus built by mike using custom sliding/horizontal dropouts, but the cost will be the same as their samurai which is more than i want to spend. great guys there as well though.
    Aug 2005
    Nice! I'm hashing out #s for the positioning of the paragon dropouts.. in 32x18 will run in the 16.75" mode. To accommodate 34x18, I can go either 16.45 or 16.95, but not both while maintaining 16.75" and keeping the slider in the front 1/2 of the dropouts (more overlap = stiffer interface).
    So..16.45 or 16.95. Thoughts?
    Te mortuo heres tibi sim?
    If anything, I'd got with the same head angle but based around a shorter fork like the Pike. IMO, 160mm on a 68.5* HTA is a bit odd. I'd either base that around a shorter fork height like the Pike, or slacken the HTA more to accomodate the travel.
    Considering the back end won't have any sag/compression, that 160mm up front will steepen things up quick coming from 68.5*. Granted, that's under quick hard compression, it's not as if you'll ride it that way, but still... With newer forks these days, at least it's pretty easy to dial in some damping to ease up on brake dive and bobbing when pedaling yet still letting the fork remain plush and active when needed.
    Got one hardtail with a Pike and a 68.5* or so HTA, and another with a Lyric at 67.5* or so and I kinda' wish I'd had the second built to have the 67* around the same size fork as the other -518mm. I've found the sweet spot on the Lyric hardtail to be running it at 150mm vs. the 160mm full travel. Shorter overall, and burly enough for what I do for sure. Or if you just want the increased stiffness and burl, desing it with your angles around the shorter fork, but run the taller fork at 140mm.
    I'd also go for a shorter/braced seat tube, but that is personal preference/ a personal size thing. I've got short legs, and just prefer the aesthetics of the steeply sloped TT that give a bikes appearance. Depends on how much you like to have your seat dropped when the time comes as well. Less an issue if using a dropper type post, but still a consideration.
    Unless your builder goes nuts, you ought to be even able to get a frame nearer the 5# mark vs. 6# IMO. Beefiness I guess depends on how big and burly you plan on jumping and dropping. My Peyto frame is gussetted pretty damn well, and beefy and it comes in just a hair over 5#. My burly ti frame is near exactly a pound less.
    It's tough tot hink of all the little details, but fun at the same time!
    Aug 2005
    Thanks SL.
    I changed the specs so that the geometry is based on a 150mm (as the Ridge i find out is), and slacked out the HT to 68* and lengthened the TT to 23.25. What is the rule.. you lose a degree for every 20mm? 10mm? I figured with 140mm, I'll still come in around 68.5ish.
    I thought about going slacker, but I like the quick handling of my Ridge, even when set at 120mm. I have a 67.5 dualie in the garage for the hairy stuff, and wanted a stiff quick bike. That and I've never tried a slack hardtail.. so a bit apprehensive going that route on a custom frame without trying it first.
    Good call on the brace cuz I also asked for a tiny little brace.. something along the size of the ones on Ventanas. I don't really have a issue with standover, but i thought a tiny brace would give it some extra flair.
    Thanks for the suggestions so far!
    I've always read about a degree change for every 25mm or so seems to bear out in my experience. If you have known numbers to work with, you could bust out some trig to figure things out for sure.
    Cool. I'll just throw other ideas out there, not really knowing what you're after, but what the hell:
    ISCG mounts?
    Disc side stay braces?
    Running a dropper post, and if so, want cable guides for that?
    Thanks SL.
    Aug 2005
    All comments are welcome since I should consider everything.
    Yes to ISCG mounts!! I nearly forgot about this detail. 05 or old?
    Haven't thought about the disc stay braces.. i figured that is up to the builder if it's needed depending on the tubing. This is just to keep the stays from collapsing under braking right and is primarily for thinner tubing? Brad doesn't have any on his DJ bikes so i'm guessing he hasn't run into problems. I will ask him though.
    I used to run a speedball on my old Intense and really liked it. For the sake of simplicity, I prefer just to use a normal post nowadays. I opt for the lever actuated droppers to eliminate cable clutter.
    Are you running the seattube collar slot in the front or back?
    My next concern is color:
    http://nem-pro.blogspot.com/2007/12/...oothpaste.html
    http://www.clubstuttgart.net/gallery...ashiongrey.jpg
    I was also thinking of a washed out peach color. Like how the mint is a washed out green.
    Quote Originally Posted by scrublover
    ISCG mounts?
    Jul 2003
    ISCG mounts?
    This is like deja vu for me!
    Scrubs and I had this same exchange a week or so ago.
    Haven't actually used ISCG mounts - can't say as to if one is better than the other. Figured for guide or Hammerschmidt use - it's supposed to work with both versions though. I'd guess to go for whichever one is in most popular use/has most product/support out there if doing a mount. Non-driveside slider Rohloff compatable for future use?
    A brace probably isn't needed, but that'd be up to you and Brad as to how beefy/burly you two think things need to be. I had one put on my frame more for the hell of it/longevity/my own worries.
    I like the seat slot in front. IMO, it ends up looking cleaner, and marginally less crap gets thrown down the seat tube that way. Dopn't know if there is a functional difference. My non-engineer mind thinks forward facing would be slightly beefier, not having the slot hanging out back with a backwards leaning postpushing against the slot tabs. Granted with a collar on, it's surely a non-issue.
    That mint color is nice looking.
    Progress on yours?
    Jul 2003
    Progress on yours?
    Well - sort of - but in a different direction of sorts.
    Let's just say I've been doing a little local wheeling and dealing.
    We'll see how it all turns out.
    Aug 2005
    just put the order in with Brad @ Nemesis Project!
    Spec'd at 150mm fork
    17" ST
    23.25" Eff TT
    12.5 BB
    68 HTA
    72 STA
    16.3 - 17.05 ST length: flanged Paragon sliders
    Full length cables mounts
    ISCG mounts
    accommodates 7" rotor in back, 2.5 tires + mud
    Very small ST/TT brace no bigger than this
    I noticed that similar frames like Chromag, Transition, Evil come in around 6lbs. So i think that would be a reasonable weight. less would be great of course.
    Color wise.. i kept bouncing around and decided a light color wouldn't go with my white syncros rims. So I'm thinking of this M3 blue called Laguna Seca blue plus a tinge of green.
    The mint green would be sweet if i had mango i9, headset, black rims.
    Jul 2003
    Very cool unfluid one - keep us posted on the build as Brad starts mitering tubes and tacking and welding!!!
    Cheers,
    Mark
    FM
    FM is offline
    Apr 2003
    Rockin.
    Just a few thoughts....
    • what's your height? 23.5 is getting close to what many consider "large"....
    • tire clearance. Always tough when "tubing" is involved rather than a forged/CNC'd yoke at the chainstays... a 73mm shell will help, otherwise you'll need something tricky. Take a look at chromag, Evil, 2soulscycles for instance. On my bike, I'll leave that up to Curtlo, but with a 73mm shell and most any crimped tubing a 2.4 is about the most you'll get, without long chainstays.
    • Past that there's a lot of personal preference stuff, in terms of fork length and angles. Sounds like you know what you want and that's all that matters.
    Aug 2005
    dammit i'm full of typos. I meant 23.25.
    I'm 5'9. My Ridge is 23.5 and I use an offset RF seatpost, Terremoto is 23 w/ straight thomson. So thought I'd go with something in the middle.
    Yup, I specified a 73mm shell. I mentioned cnc yokes, but he wasn't a fan of using them. Brad uses a "box" between the stays and BB.. I put it in his hands to figure these things out.. just told him that a big tire + mud should easily fit! I didn't ask him directly, but perhaps this will work in a similar fashion?
    Here's what I specified:
    * Full True Temper Platinum OX tubing, machined chainstay box. Like a taller/longer Secret Agent.
    * It would be ideal to have the weight below 6lbs
    * Flanged (link) paragon sliders for singlespeed, no derailleur tabs for cleaner look.
    * Toptube will have a drop for increased standover, but total seat tube length should be 17". The ST/TT brace(link) should be very small, similar size if not smaller to the ones on the medium Ventana frames & nothing big like the Evil Sovereigns. I'd want the lines of the bike to look smoooooooooth & flowy.. as much as possible
    * Does this frame need a brace on the non-drive side between the chain and seat stays?
    * Toptube and seat stay should meet at the seat tube at the same point.
    * Full length "zip tie" housing mounts for rear/front derailleur, rear disc. All mounts running under the top tube and under the seat stays.
    * ISCG mounts
    * Color: Laguna Seca blue w/ tinge of green
    Component accommodation requirements:
    * Frame must handle & downtube must easily clear and RockShox Lyrik, Pike floodgate knobs, Fox 36, and other similar 160mm crowns without interference.
    * Head tube accommodates press fit headsets. Will run Chris King headsets
    * Frame accommodates:
    o 2.5 tires like Kenda Nevegals with mud
    o 175mm Shimano external bearing cranks (XT)
    o 73mm external bottom brackets
    o single speed, 9 speed derailleur & front derailleur
    o Hope QR seatpost clamp (some standard size, no brazed on seat binder)
    o 7" rear rotors. 8" would be awesome too, but probably won't run them.
    * I will be running 140mm Pike though.
    * Uncut thomson seatpost (i have 31" inseam) should be able to be slammed all the way down.
    Quote Originally Posted by FM
    Rockin.
    Aug 2005
    This is what I'm used to & and it gives me a warm tingly feeling everytime i look down!
    so hopefully ample clearance is possible
    <a href="http://s19.photobucket.com/albums/b198/s1r5upaf1y/?action=view&current=IMG_0807.jpg" target="_blank"><img src="http://i19.photobucket.com/albums/b198/s1r5upaf1y/IMG_0807.jpg" border="0" alt="Photobucket"></a>
    <a href="http://s19.photobucket.com/albums/b198/s1r5upaf1y/?action=view&current=IMG_0806.jpg" target="_blank"><img src="http://i19.photobucket.com/albums/b198/s1r5upaf1y/IMG_0806.jpg" border="0" alt="Photobucket"></a>
    Jul 2003
    Great thought process unfluidone - the reason for the custom frame, just wanted something a tad different than your Ridge is that it?
    Aug 2005
    Yeah exactly. Namely a steel frame, being able to run SS without a tensioner, and slightly better standover. I'm not too short or tall or disproportioned so stock frame sizing is never an issue. Just couldn't find a stock frame that i liked 100%. Transition was close, but had a new nagging issues I didn't wanna deal with, including a taller ST.
    conjoinicorned
    Reputation: ferday's Avatar
    17" ST
    23.25" Eff TT
    12.5 BB
    68 HTA
    72 STA
    cool bike, scary similar geo. to a balfa minuteman...my all-time favorite trail hardtail. i personally would've run a slacker HTA (67) and slightly shorter chainstays...but otherwise sounds like the ideal "AM" hardtail. can't wait to see this one built up, i've loved all of brad's projects that i've seen posted here.
    what would rainbow unicorn do?
    Jul 2003
    Minuteman's were certainly slack. Some slacker than claimed in the catalogs.
    They coulda used slightly longer STs though - but they were designed to be very versatile so perhaps that was a consideration with the ST lengths use on them.
    Aug 2005
    Enlisting your guys again to get an opinion on frame colors now!
    I was pretty set on Laguna Seca blue but am thinking now that it may not look as unique on the thinner lines of a bike frame
    <a href="http://s19.photobucket.com/albums/b198/s1r5upaf1y/?action=view&current=lagunaseca.jpg" target="_blank"><img src="http://i19.photobucket.com/albums/b198/s1r5upaf1y/lagunaseca.jpg" border="0" alt="Photobucket"></a>
    This Verde Ithaca is starting to grow on me and may look pretty sweet.
    Take your pick!
    <a href="http://s19.photobucket.com/albums/b198/s1r5upaf1y/?action=view&current=mur18.jpg" target="_blank"><img src="http://i19.photobucket.com/albums/b198/s1r5upaf1y/mur18.jpg" border="0" alt="Photobucket"></a>
