I am keen to get some Continental Barons for the rapidly approaching winter months but this summer went UST for the first time and love the extra grip achieved from the low pressures. I know that Conti do not make a UST version of the Trail Baron but wonder if you think it would be possible to get a seal with a non UST tyre?
I am new to this whole UST thing and have no experience other than the Trail Queens (Kings) UST that I have been running all summer.
My exp w/ Conti non-UST is w/ der Kaiser and Rubber Queen/Trail King folders. You'll need to use at least 2 scoops of goo, twice, and on buckets.
Compressor helps a LOT here. Get the 1st round to seat w/ soap, then lay them flat on a bucket. Flip it over every couple of hours...2 cycles here should be fine. It'll still leak, but slow enough for a day's ride. I repeated this twice w/ both tires before the porous sidewalls finally sealed up. The der Kaisers were a JOKE! I don't think that weave looking sidewall is decoration...I actually think it is woven 'cause it sure leaked like it was! The RQ/TK were a bit better, but still leaked like a sieve!
Here's a thought: You know that spray sealant stuff being advertised on TV...the one where they sprayed a screen door and mounted the thing to the bottom of a boat...hummmm. Turn a tire inside out and spray it down? :yesnod:
Edit: Threw up the question on the Wheels and Tire forum on the Flex Seal
Edit edit: apparently, Flex Seal is a shipping scam. Found this on Amazon instead
I rode on non ust 2.4 trail kings all summer. 1 scoop of Stans on 823. Mounted them without a compressor, I use a strap to hold the tire on the rim and a Parks tire pump. I'm very happy with this set up tons of grip.
I found with airing up Contis non ust, that the easiest way is to air it up with a tube in it to seat the bead. Let it sit overnight. Then deflate, carefully unseat one side, pull the tube out, dump some stans in there and air it up using a compressor.
THanks all.... I will buy the tyres and give it a go, if it all fails I will add some tubes......
You have insufficient privileges to reply here.
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.2K members
Since 1990
