Results 1 to 9 of 9
    Sep 2013
    Component question
    I have a '13 Kona Tanuki which came stock with a Deore rear. Can I put an XT on the rear, and if so, will it cut down on some of the chain slap? Also, is the XT compatible with the shifters that came stock? Thanks!
    Feb 2007
    Assuming that your bike came with a 10 speed drive train, you should be able to do it. You can replace with xt and you would need the clutch model that has a built in tensioner to reduce chain slap.
    Sent from my SGH-I317M using Tapatalk 4
    Sep 2013
    It came with 3x9 drivetrain. Shifters are Acera, as is the front der. If I can't use an XT because of my 3x9 setup, any suggestions on an upgrade for the rear?
    Feb 2007
    You can use a 9 speed xr. Only it won't have the clutch and therefore only offer limited chain slap reduction. It will shift better due to the stronger spring. Best bet for chain slap is a chain guide of some sort
    Feb 2007
    I meant 9 speed xt
    Sep 2013
    Thanks for the info!
    Reputation: charging_rhinos's Avatar
    if chain slap is what you're worried about and don't want to get an entire new drivetrain and shifters/derailleurs, you could always get a chain tensioner like a bionicon c guide or similar. The right way to do it would be to replace your derailleur, chain, and cassette, and get a 10speed clutch rear derailleur, but that can be very costly
    tangaroo: What electrolytes do chicken and turkey have again?
    rck18: All of them, because they're meat.
    Aug 2005
    Get an Xt 9 speed shifter while you're at it.
    2016 Santa Cruz Hightower 29er
    2016 Chromag Surface 27.5+
    2013 Transition TransAM 29er
    2017 Motobecane Lurch FS 26 fat
    Reputation: lotusdriver's Avatar
    Sep 2013
    The Tanuki Deluxe has a rubberized protector on the rear triangle below the chain.
    If the Tanuki does not have this fitted, it would be worth fitting it, as it pretty much silences any chain slap.
  1. Sram component swap....chain question??
    By #Cyclelife in forum General Discussion
    Last Post: 03-01-2013, 06:50 PM
  2. Component question - advice needed.
    By Edlund in forum 29er Components
    Last Post: 08-19-2012, 01:03 PM
  3. Component Swap question
    By irishpitbull in forum 29er Bikes
    Last Post: 06-14-2012, 12:47 PM
  4. Enduro Expert '11 - component question
    By edgonz in forum Specialized
    Last Post: 11-22-2011, 05:51 AM
  5. Replies: 9
    Last Post: 05-05-2011, 01:26 PM
