Results 1 to 36 of 36
    climbing with 160mm fork
    Does anyone climb with a 160mm fork? More specifically a marz. 66 rc3?
    Any opinions on this? I want to do freeride stuff, but don't want to shuttle with the "cheaters".
    I have Lyriks, non adjustable. Climb fine. With the marzocchis, just dial in a litlle low speed comp. Make sure your seatpost can go high enough to get a good leg extension
    I have a TALAS 36 with the 160-130-100 adjustment. I really don't like climbing with it set to 160 on technical terrain or when it's very steep. If you don't intend to do that type of climbing, you're probably fine with a 160. (Some people prefer the 160 even for technical and steep climbs because they say it creates a more consistent feel.)
    Mojo0115
    I have a Lyrik that I can dial down for climbs and do drop it down to around 140mm pretty regularly if I know the climb is going to last. I don't bother for shorter climbs.
    That said, I probably do about 80% of my climbs with the fork at full length simply because I can't be bothered and the difference is not that noticeable so I often just plain forget to dial down the fork and even more often forget to dial it back on the descent until get into it.
    Just roll it......
    Reputation: ebxtreme's Avatar
    66 rc3 = 180mm of travel and a A2c of 565mm.
    36, Lyrik, Wotan, 55 = 160mm of travel and ~545mm A2C
    I've got a 36 and my bike climbs pretty welll at 160mm, but my frame also has a zero stack headset which keeps the front end lower. When things get steep, I drop it to 130mm. When they get really steep, I drop it to 100mm.
    Cheers,
    EB
    i can climb with my 160mm fox van no problem
    Me too, Van36R on ReignX1 and it climbs everything but the super-steep.
    But you are leaving out a huge variable - the bike!
    Virtual-pivot (style) bikes generally climb better with tall forks than single-pivot or FSR, etc bikes, since they squat less, and will keep the front wheel on the ground better.
    EDR
    Reputation: eatdrinkride's Avatar
    Jun 2005
    I've got a Lyrik on my 575 and climb most of the technical stuff with it at 150 or 160mm. I could dial it down but then my BB drops too much and I get a lot of pedal strikes. For long-ish smoother climbs I often run it at 130 or so, it just feels a bit better at 130 when seated and climbing for a while.
    I am running a lyrik and did a little experiment yesterday - our most techy extended climb with no raising the seat or u-turn utilization.
    I found that TECHNIQUE is everything. Even after having switched to a 60mm stem and 2" risers, with some finesse you can still make it just fine.
    My technique was garnered from this bit of advice:
    Quote Originally Posted by Ro.nin
    There's a certain technique they teach you for climbing. Most of the guys have brushed a bit on it.
    Pardon my french - the technique is called: F@ck The Football
    So imagine you're holding a football and doing the 'respective' motion towards it. That means:
    - hands placed on the bars as close (narrow) as possible, without giving up control - the football is narrow, right; and you wanna 'hold it'...
    - slightly pull on the bars - this will keep your front wheel on the ground - you wanna pull the ball towards you...
    - keep your elbows tucked in, while pulling on the bars. Do not pull too hard - you will get tired - as usual
    - move your mid-section forward - you're holding a football with your hands/elbows and try to 'do it', remember?
    - lean slightly forward - maybe you want to be 'nice' to the ball at the same time...
    There you go. Basically all those things everyone said before me, but in a formula easier to remember...
    F@ck The Football.
    I have a 150mm marz all mountain 3 fork. I do mostly cross country on it. I can switch the lever on the fork to lock it out on long climbs, but I usually forget until its too late. The only time it sucks to climb is when I don't have it locked out and I'm trying to stand up for medium length to long climbs. There is just too much give in the front.
    If I stay seated I have no problems. Raising the seat will help, but I usually forget that too.
    TNC
    TNC is offline
    noMAD man
    Reputation: TNC's Avatar
    First thing first...
    Maybe I missed it, but what kind of bike are we talking about? A 66RC on a Stumpjumper FSR will likely create a crazy climbing geometry, but on another bike...?
    I don't use travel reduction adjustments on any of my long travel forks. A Van 36, an '06 66SL, and an '08 Nixon 160 Elite. All of these forks have been on a Nomad and older Bullits. Practically nothing seems to hinder the climbing ability of my Nomad with these forks, and the Bullits only tend to feel the higher geometry issue with the 66SL at its 170mm full extension. A super short wheelbase bike with relatively short chainstays will probably not be as good for climbing with a 160mm fork, but most others should be fine. Lean forward a bit more as the climb steepens to improve front wheel stability.
    I have a lyric also and do most climbs in 160 mainly because
    I often don't have time to switch down to 115, or it is too bumpy to take a hand of the bar to switch the fork.
    Reputation: nickgto's Avatar
    Dec 2005
    My BMC Superstroke (6 inch short 4 bar parallel link) is steered & suspended by a 170mm 66RC2X (555 AC height). Although the fork doesn't have travel adjustment, I can still do 8 mile climbs with 3,500 feet elevation gain as well as steep technical climbs with the bike. Luckily the Superstroke came with a zerostack headset thus the HA isn't that slack and sits at a guesstimated 67 degrees.
    On long fireroad climbs, I set the rebound knob of my fork to full slow and set the low speed compression of the fork 3/4 from full stiff, and this setting takes out most of the suspension bob up front. I also turn the propedal of my RP3 to the strongest setting and this gives me the right pedalling platform for that type of climbing. I raise my seat just enough for proper leg extension.
    On steep, short, and rocky technical climbs; I set my fork with low speed compression dialed 1/4 from full plush and the rebound knob set at 5 clicks from full close. I set my propedal on the middle setting, and my seatpost is lowered by about 20mm from my smooth fire road height.
    DH:Mountain Cycle Shockwave 9.5 w/ 888R
    FR:Marin Quake w/ 888RC
    AM:BMC Superstroke 01 w/ 66RC2X
    ♥ ς╥33
    Reputation: longcat's Avatar
    I think even 135mm (crappy tora) is too much when climbing, well it depends on how steep it is but on one particular hill I have to ride up everyday it feels like I'm gonna fall over backwards, and if I stand up it feels like its sucking power from me bouncing up and down.
    Quote Originally Posted by Curmy
    Carbon is a fad.
    Quote Originally Posted by robicycle
    Just lube your ass with asscream and ride for how long you want.
    It depends on bike geometry.
    I have a bike with a 180 mm non-adjustable totem and I don't mind climbing on it in the least bit. Even on the super steep techy sections the only disadvantage I see is the slackish head angle.
    Te mortuo heres tibi sim?
    Body english. I find myself moving around and having my weight more forward on the bigger forked/slacker angled bike 66*HA - 180mm fork), as well as using the granny to sit and spin far more than on my hardtail. Which has a 160mm fork.
    It's that fine balance of maintaining rear wheel traction and no bringing the front wheel up/getting it too floppy. Experiment a bit, and try the football humping thing. Moving forward a bit on the seat helps on its own as well, though not so hot if you don't have a decently padded up saddle nose...
    4od
    4od is offline
    I have a big chunky Domain 302. For climbing I usually don't either bother to drop down the travel.
    I think a good balance between shock/fork and decent bump threshold/Pro-Pedal/lockout on the shock are more important than having a short fork up front.
    Reputation: Broccoli's Avatar
    Quote Originally Posted by first.hander
    I drop my Wotan down to 120mm with a press of a lever, turn platform on, and it climbs like an XC bike (well, if an XC bike was 35lb). I also use Crank Brothers headset that is another 5mm lower in front then most others)
    Magura Wotan, Lyric 2-step, TALAS 36 are made for this.
    Mar 2006
    You should be able to pedal it OK, its all about technique. Insert the seat into your butt (to get your weight forward) and pedal nice and smooth.
    Reputation: Luigiugueto's Avatar
    Oct 2007
    Get used to it, what bike are you pedalling up a hill with a 66??
    The bike's geometry will have a major roll as well..
    Thanks for the responses. I actually made a typo and it's supposed to be 180mm of travel. It's going to be on a Canfield brothers CanDiggle.
    Reputation: wormvine's Avatar
    I have a 66RC2X (180mm) on my 6point. Puts HA at 67deg with a 14.2" BB height. I climb a lot with this bike. I had a 66sl ata and would lower the fork but I just didn't see any real difference so I went to the fixed 180mm RC2X. The front end will want to lift on the steepest of climbs but all I do is move forward and the front stays down. I have a climb on a local trail that is utterly brutal. It's smooth but sooooo steep. My bike does fine when I position myself more forward. The hard part is not puking my lungs out when I reach the top!
    I am running:
    IH 6point
    DHX5-air
    Hope Pro2/DT 5.1d wheelset
    66 RC2X
    Shimano 08' XT brakes
    37-38lbs
    Go for the 180mm fork. If you want the plush travel, you will adjust your riding style to make it work. I love my 66RC2X.
    Oct 2007
    Those CanDiggle have adjustable geometry right?
    You should be fine.
    How much does she weigh?
    Nov 2007
    Is that Marzocchi's new travel adjust system!
    Quote Originally Posted by Luigiugueto
    You should be fine.
    I haven't built it up yet, but I'm aiming for 36-38 lbs. We'll see though as funds are limited right now.
    Man that belt method looks sweet!
    Reputation: Atomik Carbon's Avatar
    I don't find climbing to be the problem with a long fork....
    The reason that I insist on buying a long travel fork with adjustable travel are for thise times when you are riding very fast through twisty and technical trails. It makes a huge difference in how the bike handles.
    Brackish
    Reputation: carbuncle's Avatar
    Dec 2005
    My do-it-all bike is a Coiler D with a 150mm 66VF on it, it's a little loose on the steeper climbs, I have to move my weight up to keep the front wheel down, but overall it doesn't hold me back.
    Fort Valley = Gnarl Fest
    Reputation: Jekyll_Jockey's Avatar
    Quote Originally Posted by carbuncle
    Word I have ridden with a 170mm Jr T and made it work. You are deff not going to win any races but you will get there. Also I'm not too ashaemd to push when necessary
    It depends on bike geometry and even stem length.
    I felt no need for travel adjust on my Talas 36 when I rode a 90mm stem on my RFX, but do find myself using it quite a lot now for longer/steeper climbs with a 70mm stem.
    Hear no evil. See no evil. Speak no evil. (Do it !?!)
    Reputation: Karve's Avatar
    Mar 2006
    Dude I climb with totem air without any issues on my helius FR
    Reputation: boostin's Avatar
    I ride the 36 Talas and leave it in the 100mm setting most all the time unless heading down some extended downhill/freeride stuff. My bike set up is the Transition Covert with 5.5" of travel. The propedal on my rp23 is clutch on the climbs more so than the adjustable travel on my talas
    I dream on two wheels
    Reputation: Simonns's Avatar
    Quote Originally Posted by TNC
    Thank you, that is exactly what I wanted to hear. Im going to be putting my 170mm RC2X on my Nomad when it gets here and was wondering if it was going to affect climbing like it does on my Bullit.
    -Simon
    Neg reppers r my biatches
    Reputation: FoShizzle's Avatar
    Quote Originally Posted by CharacterZero
    uhhh....wrong, its the parts; the more expensive the more you will enjoy your ride and the better your skillz will become
    sofa king awsm
    This thread hasn't helped my climbing but it's sure made me appreciate the erotic qualities of a football that much more.
    Quote Originally Posted by Buster Bluth
    you're a monster!!!
