Results 1 to 11 of 11
    Na
    Aug 2018
    New question here. Chain thingy holder
    What is this component called? Its before the derailer that keeps the chain from bouncing and it has a wheel, norcos use to have this but i cannot find a bike with it. Also shouldn't this come standard to keep the chain in place from bouncing to all hell?
    Mar 2018
    Are you talking about a chainguide with rollers?
    Na
    Aug 2018
    Quote Originally Posted by Dropper View Post
    Sure am. Ty.
    Reputation: ColinL's Avatar
    Feb 2012
    Quote Originally Posted by johnmyk View Post
    You don't see chain guides like that much anymore because of clutch derailleurs (since 2012ish?) keep the chain under better control, and narrow-wide chain rings keep the chain in place on 1X drivetrain.
    That kind of guide is also very noisy and has a lot of frictional loss.
    Sent from my XT1635-01 using Tapatalk
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    In 4 years of DH, XC and enduro racing (basically since I started buying bikes with clutch derailleurs), I've dropped the chain about 4 times. One was a large stick in between the chain and chainring, one was due to a derailleur that came loose, two were on a recent race though and the reason that happened was I let my chainring wear down, it was about 2 years old. Replaced and everything is back to normal. Chains do not fall off like they used to, the combination of the derailleur and the narrow-wide ring does an amazing job all by itself. I do plenty of DH/enduro stuff in nasty terrain or at the park and the only situation where I'd want a chain guide is a full-on DH bike, such as 8" of travel front and rear. Only then would I deem it worth it for a little added insurance.
    Anytime. Anywhere.
    Reputation: Travis Bickle's Avatar
    I had a bike that dropped it's chain on one trails 50% of the time. Not even a rough trail, and never dropped the chain anywhere else. If you really need one try something simple.
    https://www.oneupcomponents.com/collections/chainguide
    https://www.mrpbike.com/shop/#!/1X-C...ategory=661403
    I got some bad ideas in my head.
    Reputation: GKelley's Avatar
    Sep 2018
    My last bike kept dropping the chain, so I got the MRP chain guide/bashguard on my new bike for added security.
    It's definitely in the want category, rather than a need. Just be ready for the no vasoline approach on the prices. For what they are, they are horribly expensive.
    Na
    Aug 2018
    Thanks to all for input amd links and stories on what to use.
    Quote Originally Posted by GKelley View Post
    Blackspire has some at reasonable prices.
    Yeah, I'm that a$$hole.
    Reputation: Guy.Ford's Avatar
    One thing to keep in mind also with regards to full capture chainguides like the one pictured above, NOISE. Especially with todays 12sp wide range cassettes, the chain will rub a lot and it's frustrating as hell. I used to be a huge proponent of full guides, until I recently bought a new bike with SRAM Eagle 12sp and no matter how things were adjusted it just wouldn't stop rubbing at some point, making all kinds of racket. So off it went into the part bin to be replaced with a OneUp Bash Guide. Unless you have an older drivetrain, I wouldn't bother, the rubbing noise will make up for the chain slap.
    Like others have said with todays NW chainrings, all you need maybe is a top guide and bashguard like the one below.
    If your still insistent on going with a full guide, I have an MRP G4 Mini (32-36) I'll let go pretty cheap.
    #THELEGENDMTB
    2016 RSD Mayor
    2018 Diamondback Release 5C
    2017 Diamondback Haanjo Trail
    Mar 2012
    I've got a Blackspire bash and guide that I'll sell you cheap.
    I used it on a 2x9 set up and it worked flawlessly; no noise, no lost chains. Friction? I guess physics tells me that it's there but I never noticed it.
    You need ISCG tabs.
    Let me know if interested.
  1. Replies: 3
    Last Post: 02-23-2015, 09:31 PM
  2. Protector Thingy Behind the Cassette
    By s11s11 in forum Beginner's Corner
    Last Post: 11-05-2014, 05:47 PM
  3. Magura Marta SL transport device thingy
    By mat-with-one-t in forum Brake Time
    Last Post: 10-13-2012, 09:00 AM
  4. 2012 chain dangly thingy
    By Walter95 in forum Specialized
    Last Post: 04-24-2012, 05:42 AM
  5. Windows7/IE8 pop up thingy
    By giantbikeboy in forum Off Camber (off topic)
    Last Post: 03-27-2012, 06:39 PM
Members who have read this thread: 102
