Results 1 to 5 of 5
    dlc is offline
    Carbon Riser Bar??
    Does anyone know of a wide 30mm carbon riser bar? The new sixc look perfect but don't want to have to buy a new stem.
    Enve would be perfect with a little more rise.
    Dec 2004
    I have the ProTAPER® Carbon 720 AM 2" the bar. It's steel strong. At a little over 28" long it falls short of your rquirement but I recommend it (about 1 5/8" short). They also make a 780 bar, but only at a 1" rise. You might need to comprimise. I recommend the 720 AM and I have had 32" bars before.
    Reputation: dirtrider76's Avatar
    Sep 2012
    I'm pretty happy with my Enve riser bar. I beleive they have a DH version as well, not sure if its got more rise or just beefier.
    I like to fart when I'm in front of you on a climb
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    I have the carbon Answer protaper 780, it is low-rise, but also not the most sweep at 7 degrees I believe. It helps to keep the front end of my enduro 29er low. Real strong bar btw, no confidence issues there, thick carbon layup at the edges.
    Reputation: Trail_Blazer's Avatar
    May 2012
    Hey I was on the same quest and was having a hard time finding one in stock anywhere with a 30mm rise.
    The crank brothers iodine 11 is the best one I could find in stock, esp on sale for under $100.
    Crank Brothers Iodine 11 AM Carbon Riser Handlebar | Chain Reaction Cycles
    Truative has one too that's got a 30mm rise, and Deity also.
    Easton makes one but it's impossible to find in stock anywhere.
  1. recommend a carbon riser bar
    By J-Bone in forum 29er Components
    Last Post: 10-24-2013, 11:47 AM
  2. Replies: 0
    Last Post: 03-01-2013, 02:18 AM
  3. Replies: 0
    Last Post: 03-01-2013, 02:06 AM
  4. Forte Carbon Riser 31.8 ??
    By zachkh in forum Weight Weenies
    Last Post: 09-04-2011, 09:51 AM
  5. enve carbon riser bar
    By lifeis11 in forum Ibis
    Last Post: 02-28-2011, 04:45 PM
