Results 1 to 3 of 3
Thread: carbon question
    carbon question
    Does anyone know why carbon cranks still use alloy spindles?
    most likely because of the NDS crank arm interface. Lots of torque on that clamp area. just a thought.
    Because the resin used in carbon will never exceed the hardness of alloy and as mnigro said, the torque will damage the resin and thus the carbon structure. Carbon structure is amazing in tension, but crap in compression/crush so no applications such as spindle w/ crushing or torque forces.
    The thing w/ handle bar...if you limit your crushing force (the bolt torque spec) and make the carbon thick enough, there's no real torque involved and so still works.
    Edit: I'm sure Mr. Magura will chime in on this shortly.
  1. Air 9 carbon question
    By nuckingfuts2 in forum Niner Bikes
    Last Post: 03-06-2011, 07:41 PM
  2. Air 9 Carbon Question
    By packfill in forum Niner Bikes
    Last Post: 03-02-2010, 06:08 AM
  3. Carbon Question
    By nuck_chorris in forum Weight Weenies
    Last Post: 08-04-2009, 04:46 AM
  4. Carbon Question
    By Husker1 in forum 29er Bikes
    Last Post: 10-17-2007, 08:31 AM
  5. Carbon Bar Question
    By bigwheelboy_490 in forum 29er Bikes
    Last Post: 11-06-2004, 12:54 PM
