Results 1 to 24 of 24
    007 is offline
    b a n n e d
    Reputation: 007's Avatar
    Jun 2005
    Carbon Bars and Grips: Ergon's = no go?
    So I just got some Easton Carbon Havoc's and kinda bummed that my Ergon's won't work because of the offset clamp . . . .
    Now I'm looking at the ODI Rogues . . . can someone confirm for me that the clamp's pinch point isn't offset like the Ergon's are (i.e., closure is on the centerline)?
    is that in the easton documentation? i must have missed it. i use ergons on my ec70s
    the ODIs clamp wherever you want them to. just rotate them.
    The mountains are calling and I must go
    The MTB Lab
    Reputation: pastajet's Avatar
    Which Ergon grips?
    007 is offline
    b a n n e d
    Jun 2005
    I dunno . . . maybe I'm reading the instructions wrong, but go to page 4 on the Easton Havoc Instructions Page and that's my take. Maybe these instructions don't apply to lock-on grips and only bar ends?
    Note: I don't want to use bar ends . . . i just want to use my Ergons (that DON'T have bar ends).
    007 is offline
    b a n n e d
    Jun 2005
    Quote Originally Posted by pastajet View Post
    Which Ergon grips?
    I have GX1's . . . I just saw that the GP1's will work . . . however that still means I need to buy new grips
    GA1-Ls on Easton Havoc Carbons and all good. However I wouldn't use the supplied endcaps. Bars are too thick so used the one thinner endcap that comes on the outside of the package for cosmetics and grabed another from another package.
    After two months my left grip is slipping around its housing.
    007 is offline
    b a n n e d
    Jun 2005
    So I ended up getting a set of ODI Rogues . . . they are loosely on there for right now.
    How tight do I need to torque these down?
    It just to the point where they stop slipping?
    Is it a specific torque value?
    Do I need to use friction paste?
    Reputation: Shalom's Avatar
    Nov 2008
    Generally 4-5 Nm torque. Ritchey torque-key works well and is cheap.
    007 is offline
    b a n n e d
    Jun 2005
    Quote Originally Posted by Shalom View Post
    I almost bought one of those until I realized you can't change bits. Its permanently a 4mm hex which is fine for many (most) things but not everything
    mine spun around a little until i used friction paste
    use it on the shifters and brakes too
    i think the bontrager torque key has swappable bits
    007 is offline
    b a n n e d
    Jun 2005
    Quote Originally Posted by Evan55 View Post
    Same thing with the bontrager key . . . its welded in there (my LBS and I have tried to disassemble them).
    I can see why the paste on the shifters/brake levers might be necessary, but I actually want them to spin pretty easy if I get in a crash. We'll see if I can get by without it.
    Reputation: client_9's Avatar
    electrical tape and gel toothpaste
    Hey,
    If you don't have any friction paste .....
    On my Easton carbon bars instead of friction paste I used some gel toothpaste and one piece of electrical tape (as a shim).
    A Baker St. Muse
    Reputation: michael573114's Avatar
    I've got some Ergons on some Bontrager XXX Lite carbon bars, no real problems so far. They do slip a tiny bit, but I'd have to really wrench on them to do it. Haven't done it accidentally yet.
    I do have to get some friction paste anyway, my seatpost clamp (also carbon) keeps slipping slightly, so I may as well apply some to the bars.
    Quote Originally Posted by client_9 View Post
    ...I used some gel toothpaste...
    I like this idea!
    Edit: I'm assuming you're talking about the old-timey type vs the gel type
    Nov 2008
    Quote Originally Posted by OO7 View Post
    Correct. For most things that you want that little torque for, 4mm is the bit. If you want to be able to change bits, you will have to go for a torque wrench, which is sadly a whole lot more expensive.
    007 is offline
    b a n n e d
    Jun 2005
    Right. I'm looking at the shimano pro model. ~$100.
    Just torque it until it's stiff and doesn't move. I've been doing that for years, no slippage, and various sets of monkeylite carbons have held up great.
    Dec 2008
    torque key itīs important.
    Ergon Bike
    Reputation: ERGON's Avatar
    Nov 2006
    This only effects out barend models when NOT using a re-inforcement plug. The non-barend models are OK for use on carbon bar as long as our torque spec does not exceed the torque spec on your carbon bar of choice.
    Jeff K.
    Ergon USA
    Harbor Freight. Get on their email list. I got my inch-lbs model for 10 bucks, and just scored the 3/8 drive one for the same. Precise enough for bike work.
    007 is offline
    b a n n e d
    Jun 2005
    Quote Originally Posted by ERGON View Post
    Jeff K.
    Ergon USA
    Hmm. Well, I have the ODI's now so I will try them out for a bit. But I have had problems in the past with numb hands so I may switch back to the Ergons. I dont know off hand what the torque spec is for the Havocs. I'm guess 5nm.
    007 is offline
    b a n n e d
    Jun 2005
    I shoulda done my homework first before running out and spendin' money . . . Easton has also confirmed that off-center clamps are fine for lock-on grips . . . just not bar ends.
    In other words, the Ergon's are fine to use . . .
    007 is offline
    b a n n e d
    Jun 2005
    So I have been running the ODI's for a few weeks now and I took them off tonight to find that the clamps had left a groove in the carbon. Its not very deep and I doubt its beyond the surface finish, but deep enough that you can catch it with a fingernail.
    It also took a fair bit of torque to get them to not slip. No idea what "value" it was as I didn't use a torque wrench, but I basically would tighten each bolt 1/4 turn until I couldn't move the grips. It took a fair bit to get them "locked" (more than I expected) and now the bar is marked. I don't care about the mark, but its more of a concern that over time this will weaken the bar and lead to failure at that point.
    So my thoughts are:
    a) friction paste
    b) electrical tape under the clamps
    c) back to the Ergon's
    007 is offline
    b a n n e d
    Jun 2005
    I went with the friction past. Will post an update for future reference if anyone else ever finds themselves in a similar situation, but initial impressions are that this did the trick. Much less torque required to sung them up.
  1. what grips & bar ends on my carbon bars?
    By mat-with-one-t in forum Singlespeed
    Last Post: 11-13-2011, 06:27 PM
  2. Grips for Carbon Bars
    By stunzeed in forum General Discussion
    Last Post: 10-05-2008, 08:55 AM
  3. Carbon Bars w/ Lock-on Grips
    By cb4photo in forum 29er Bikes
    Last Post: 08-25-2008, 06:07 AM
  4. grips & carbon bars
    By steegemed in forum General Discussion
    Last Post: 03-09-2005, 03:34 PM
  5. grips and carbon fiber bars
    By plate in forum Beginner's Corner
    Last Post: 02-08-2004, 08:20 AM
