Results 1 to 10 of 10
    Formerly PaintPeelinPbody
    Reputation: PHeller's Avatar
    Dec 2012
    Can you ride Caged Clips like Platforms?
    I ride a set of hard soled shoes with M520 clipless pedals. Tension is pretty loose, so I can bail fairly easy. However, I've got virtually no grip on the pedals when not riding clipped in.
    Are there shoes or pedals that allow for more natural "clipped out" pedal feel?
    GIS/GPS Pro using ArcFM for Utility Mapping - Always willing to connect with other MTBers in the industry.
    Quote Originally Posted by PHeller View Post
    If I understand the question correctly, you're looking for a pedal with some "platform" to stand on while not actually engaged in the clip mechanism.
    If so, take a look into the latest generation Crank Brother Mallet pedals or Time Atac MX series pedals. Add in a pair of shoes with actual rubber in the sole's arch area (not plastic like all roadie shoes...and most mountain shoes). Something like a Teva Pivot, Five Ten Minnaar or Shimano MT-33L.
    It won't be as easy as riding with a traditional platform pedal, but you'll get close, and still have the efficiency benefits of a clipless pedal.
    Best of luck.
    smartass
    Reputation: amish_matt's Avatar
    Yeah, hard soled shoes are most of the problem. Even on a proper flat pedal they'll still feel sketchy. I'm really happy with my Shimano AM45's.
    Reputation: ColinL's Avatar
    Feb 2012
    I've ridden a Crankbrothers Mallet with 5.10 Freerider shoes. It is not a good idea at all, the cleat will keep your foot from getting a solid grip and you'll probably slip a pedal. In the case of the Freerider, you'll also feel the cleat a lot and it will be uncomfortable.
    I swap between Eggbeaters and Answer Rove platforms.
    Reputation: Luigiugueto's Avatar
    Oct 2007
    Well, what did you expect???
    OP: Choose a clipless pedal with a nice platform around it with a shoe that was actually made for such a pedal and you have the combination you're looking for. Pedals such as the CB Mallet and shoes such as the Teva Links of the 5.10 Minnaar will do the trick
    Feb 2012
    Quote Originally Posted by Luigiugueto View Post
    Thanks for all the question marks.
    I was actually just riding around the neighborhood with my son, so I didn't expect much and that's what I got. I would not try it on a trail, and that's what I told the OP.
    The rest of your reply I don't think hits the mark. I believe the OP is trying to find a clipless pedal that can actually be ridden on a trail with standard shoes. It doesn't exist. He needs either clipless or platform, and of course the right shoes to match.
    Dec 2012
    Quote Originally Posted by ColinL View Post
    False. I'm wondering what clipless shoes I can get that will allow me to ride comfortable on platforms.
    If you look at a lot of Enduro racers, they are using shoes that appear to have flat soles, despite using minimally caged pedals.
    Perfect example:
    Jared Graves rocking what looks to be a clipless pedal with a flat soled clipless shoe:
    Feb 2012
    Ok... so are you talking about two different pedals, one clipless and one platform?
    Or are you looking for a pedal, whether single-sided or not, that you can be unclipped and still have a good grip?
    EDIT: ok, you added info with your edit. The 5.10 Minnar referenced earlier is like that. There are many clipless shoes that have a flat sole but the cleat will still stick out a bit, and it will be a lump under your foot on a standard pedal or when walking.
    Dec 2012
    I'm looking for more the shoe than I am the pedal. I know about caged clips, I've ridden them, but usually with hard soled clipped shoes, which sucks. Absolutely no advantage over non-caged clipless.
    I have no experience with high quality flat soled clipless mtb shoes and how they might grip a straight platform, caged clipless, or un-caged clipless.
    Like mentioned above, you'll want something like the 510 hellcat or minnaar
  1. looking for tough shoes to ride platforms on
    By LONO100 in forum Apparel and Protection
    Last Post: 08-04-2013, 06:02 AM
  2. Platforms or Clips
    By mest22 in forum Beginner's Corner
    Last Post: 12-22-2012, 01:33 PM
  3. Replies: 51
    Last Post: 11-15-2012, 07:59 PM
  4. A few clips from a recent trials ride
    By cwtrials in forum Videos and POV Cameras
    Last Post: 10-12-2011, 07:59 AM
  5. If I ride both clipless AND platforms
    By raganwald in forum General Discussion
    Last Post: 08-07-2011, 05:04 PM
