Results 1 to 36 of 36
    Aug 2013
    Can hardtails ride AM trails?
    Can hardtails ride AM without ruining your bones?
    North Van/Whistler
    Impossible - you will die and your bike will self-destruct
    You're welcome
    Locals' Guide to North Shore Rides http://mtbtrails.ca/
    ^ What he said.
    squish, squish in da fish
    Reputation: fishwrinkle's Avatar
    lol i do believe there are all sorts of HT AM bikes.
    Reputation: BigHit-Maniac's Avatar
    Does a bear s*%t in the woods?
    You in Oklahoma City? If yes, come ride with us.
    > /dev/null 2&>1
    Reputation: Procter's Avatar
    Feb 2012
    Re: Can hardtails ride AM trails?
    Depends, a trail with a class 3 Am certification is acceptable for hardtails with minimum t6001 al and minimum 1.3 mm wall thickness at the lower chain stay junction (this is using Imba am trail classification handbook version 3.2.1.2, not norba tsclf cert 2.6, they are a splinter group).
    However, when you get up to am trail classification 4 and 5 (again, imba 3.2.1.2 criteria only , you know, average trail feature 6.3 inches height with a frequency of 12 features per 20ft trail distance, I'm sure you've seen it), then you need a min 2mm wall thickness, which is only prevalent in a handful of production run bikes. I don't need to tell you because I'm sure you'd have found the same after a little research.
    CoolArrow
    Reputation: jhazard's Avatar
    When you find some AM trails, let us know...
    Cool BandolArrow
    Jerry Hazard website
    Reputation: charging_rhinos's Avatar
    Do mullets mean less teeth?
    tangaroo: What electrolytes do chicken and turkey have again?
    rck18: All of them, because they're meat.
    Apr 2013
    They can. But you should first have both a will and a durable power of attorney. You should also carry contact information for your next of kin.
    It's thoughts of riding hard tails on AM trails that keeps causing lawmakers to consider laws about what kind of bikes can be used in different places. It is just irresponsible to consider it.
    Reputation: bigfruits's Avatar
    Mar 2011
    steel frame, big tubeless tires, good fork and your bones may be ok.
    theyre poking fun because AM is a type of bike not trail.
    if youre a troll, go f**k yourself.
    Titanium junkie
    Reputation: Loudviking's Avatar
    Oct 2011
    You can ride whatever you want on any trail, just depends
    on your testicle fortitude. Used to be you bought a bike and rode it, didn't
    have all these classifications. Just use your head and don't get stupid.....
    Climb into the sky, never wonder why - Tailgunner
    You're a Tailgunner
    Aug 2013
    Quote Originally Posted by bigfruits View Post
    I'm not a troll. I am a noob
    Reputation: Fix the Spade's Avatar
    Quote Originally Posted by charging_rhinos View Post
    There is a correlation, but science has yet to prove a causative link between mullets and both toothlessness and halitosis.
    There is a proven inverse correlation between number of hard tails owned and time to fix a pinch flat though.
    Dec 2011
    As long as you carry a gun
    To put yourself out of horrible misery when your bike explodes ripping your legs off miles from nowhere
    May 2005
    It's not about the bike. For proof, take a look at this video:
    Martyn Ashton - Road Bike Party - YouTube
    The unfortunate truth is, if you ride an AM trail with a hardtail, it can no longer be classified an AM trail and is reclassified a sissy xc trail... PLEASE don't ride one with a ht and destroy any more AM trails! there are so few as it is!
    I would think the rock piles on downhill burst would be a freaking nightmare, but your legs are your main suspension!
    Aug 2013
    Okay I understand.
    Dec 2012
    Quote Originally Posted by WarBoom View Post
    "Miles from nowhere" does that mean somewhere???
    And by the way real men ride hardtails...
    gravity fighter
    Reputation: Mikecito's Avatar
    Only if you wake up early.
    *rim shot*
    Dec 2011
    Quote Originally Posted by WillT19 View Post
    Miles from nowhere is a somewhere right next to nowhere it's also under the up there and nearer than that over there
    Reputation: fizzywater's Avatar
    Quote Originally Posted by MountainBiker8 View Post
    It really depends on your bones, not the bike. I used to ride Downieville on my steel HT and had a blast. Now I have lower back and herniated disk issues and I have to use my 6 inch squishy bike for everything. Using the HT is no longer an option for me (except to run some errands on paved roads), but if my spine was still OK, I sure would be still riding it. That being said, IMHO a squishy bike does give you more margin for error (which over time may get neutralized by the fact that you tend to go much faster on a squishy bike for the same kind of trail, thus erasing the margin of error advantage...LoL).
    Aug 2013
    Quote Originally Posted by fizzywater View Post
    That makes sense. Thank you.
    Reputation: BaeckerX1's Avatar
    Oct 2007
    I was wondering how long it would take before someone posted one of those Chromag hardtail vids
    Gotta get up to get down.
    LMB
    Level 5 Rider!
    Reputation: Desidus's Avatar
    Jun 2013
    Go and hit it with a rigid, wasn't that long ago that suspension bikes were just an idea in someones head. People still did crazy "stuff" back then... It's easier on you and the bike and you can go faster on a FS, but not necessary in the least. Make sure the frame is sound and then pick the best lines you can.
    You earn 1000 exp!
    You are now lvl 5! (5/100)
    Str +3, Sta +4, MTB Skills +1, Grip +1, Iron Butt +1
    New Item - Broken pedals
    Give it a crank
    Reputation: Mtn-Rider's Avatar
    May 2010
    You can ride AM trails on a hardtail, just leave enough room for the DH riders to fly by.
    Reputation: oopsthathurt's Avatar
    Aug 2013
    Yes... If you don't mind "bike hiking" (walking your bike).
    Reputation: Luigiugueto's Avatar
    Oct 2007
    I miss my hardtail, she was way more fun. Although she made me faster on my FS
    Jun 2013
    Yesterday we were riding a very rocks course at a local ski area on full DH bikes (only the second time on DH's). A guy blew past us on a hardtail, showing the rider is much more important than the bike. I tried to catch him, but his skill was far beyond my noob abilities.
    However, the last time we saw him was in the bike shop where is was looking for some part to get his bike rolling again...
    Reputation: Fuglio's Avatar
    Good job!
    didnt want to feed this troll thread but i cant help myself
    since i just bought a hard tail ill repost a Video i made of my shenanigans
    <iframe width="560" height="315" src="//www.youtube.com/embed/V6h1PBP0xW0?list=UUKtJssbgfYezdG5CEVSpHtQ" frameborder="0" allowfullscreen></iframe>
    and some pics
    <a href="http://s34.photobucket.com/user/mrpea9999/media/logride.png.html" target="_blank"><img src="http://i34.photobucket.com/albums/d141/mrpea9999/logride.png" border="0" alt=" photo logride.png"/></a>
    <a href="http://s34.photobucket.com/user/mrpea9999/media/jesushardtail.png.html" target="_blank"><img src="http://i34.photobucket.com/albums/d141/mrpea9999/jesushardtail.png" border="0" alt=" photo jesushardtail.png"/></a>
    <a href="http://s34.photobucket.com/user/mrpea9999/media/4df172b7-ba2c-49cf-90ff-ebd302e0810f.jpg.html" target="_blank"><img src="http://i34.photobucket.com/albums/d141/mrpea9999/4df172b7-ba2c-49cf-90ff-ebd302e0810f.jpg" border="0" alt=" photo 4df172b7-ba2c-49cf-90ff-ebd302e0810f.jpg"/></a>
    <a href="http://s34.photobucket.com/user/mrpea9999/media/26815028-a4dd-4345-b395-42b3310af593.jpg.html" target="_blank"><img src="http://i34.photobucket.com/albums/d141/mrpea9999/26815028-a4dd-4345-b395-42b3310af593.jpg" border="0" alt=" photo 26815028-a4dd-4345-b395-42b3310af593.jpg"/></a>
    <a href="http://s34.photobucket.com/user/mrpea9999/media/0706131347a.jpg.html" target="_blank"><img src="http://i34.photobucket.com/albums/d141/mrpea9999/0706131347a.jpg" border="0" alt=" photo 0706131347a.jpg"/></a>
    lets just turn this into the hardtail hucker thread
    Aug 2013
    I'm not a troll. I am a noob who does not know lots about Mountain Biking.
    Nice video btw
    Nice video btw
    Well I am a troll. So take it from me. If you ask can I ____ on a ___? its always a troll question cause it will start trouble... Watch start a thread Can I ride technical trails wearing clip ins? and youll get a lot of responces
    Attached Thumbnails Attached Thumbnails Can hardtails ride AM trails?-troll-doll.jpg
    Quote Originally Posted by Fuglio View Post
    so... can I ride AM on a 29er ht?
  1. Mission Trails or Other Local Trails (Sunday July 21) Ride!
    By Bryan Luu in forum California - Socal
    Last Post: 07-20-2013, 07:16 PM
  2. Need help with hardtails
    By E_farv in forum Bike and Frame discussion
    Last Post: 07-14-2013, 07:30 PM
  3. How are the trails for hardtails?
    By davidlax12 in forum Nevada
    Last Post: 04-10-2013, 07:21 PM
  4. Ride Dirt Trails, Not Mud Trails.
    By c0nsumer in forum Trail Building and Advocacy
    Last Post: 12-04-2012, 12:15 PM
  5. Trails for hardtails in PHX
    By TXPABIKER in forum Arizona
    Last Post: 05-14-2012, 01:41 PM
