Results 1 to 18 of 18
    Reputation: chris9888's Avatar
    Can air fork pair with coil shock?
    I was thinking of getting RC4, but my nomad is running on Talas36. Should I get DHX air instead? Thanks.
    ZEN RIDER!
    Reputation: Mt.Biker E's Avatar
    Mar 2006
    Air forks have come along way so i wouldn't sweat it. If it was reverse I might say stick with one or the other - rear suspension being more subtle & relying on spring rates more than your fork.
    Life in every breath
    Reputation: KTMDirtFace's Avatar
    I have DHX RC4 coil on my bike and a 36 float 160 rlc fit on the front. Went with the Float because i hear the talas doesn't work as well. But I have no idea.
    Seems fine and saves a little weight.
    Had a coil front on my old bike vanilla so it didn't have much for adjustments.
    Guerrilla Gravity Pedalhead XL
    Big Test Icycles
    Reputation: Hangtime's Avatar
    What shock are you replacing and what do you want out of the bike. If you want to save some weight go air but I think I would be looking at the new Push link for the Nomad (if you have the Nomad 2). I think the Nomad with an RC4 and the new link would be sweet.
    Quote Originally Posted by KTMDirtFace View Post
    My Kashima Talas is awesome. I like the fact that it can be switched to 120mm during long climb and back to 160mm on downhill. Wonder if pairing coil shock with air fork produces less favorable effect than pairing air shock and air fork?
    Quote Originally Posted by Hangtime View Post
    I am currently running DHX Air and Talas 36 on Nomad carbon. Thought of upgrading to Kashima DHX Air or RC4. I want it to do big drop. Air or RC4?
    addict
    Reputation: powderhound82's Avatar
    I am running a RC4 with Ti coil and 36 Float on my Nomad2, great combo. Still dialing in to the sweet spot on the shock, lots of interacting adjustments, getting close. Soaks up big hits no problem. I have not tried an air shock on it, so cannot comment on the difference in performance, If weght is a concern, and you're happy with it, stick with the air. Sometimes on long climbs, my mind begins to wander and I think about shaving weight on my Nomad, once I point it down, those thoughts instantly disappear. The Push link is on my short list.
    Ride On!
    Reputation: 53119's Avatar
    Nov 2008
    ccdb w/steel coil and xfusion vengeance hlr been playing well together. i think the hi-lo compression adj on the fork has really helped it balance that amazing ccdb. been really impressed with the xfusion so far though!
    Axe
    Axe is offline
    Custom User Title
    Reputation: Axe's Avatar
    I ride DHX coil on my Coiler with Wotan fork in front. Works great. Then, Wotan is one of the more coil like feeling air forks.
    Reputation: Steve.E's Avatar
    ccdb rear and bos deville forks on a transition covert here, lovely combo, haven't ran the forks on anything longer than the descents at Innerleithen but they coped fine there.
    meow meow
    Reputation: b-kul's Avatar
    it wont feel like a mismatch if that is what you mean. even if that were the case i dont see why you would settle for lesser rear suspension to match lesser front suspension.
    Reputation: spooney's Avatar
    Jun 2010
    Rear shocks are more prone to fade as the oil heats up from the air seal friction. This problem is not so on most forks as the air and damper are on different sides so one does not affect the other so basically the rear shock is probably better as a coil and the fork not so obvious a difference between air and coil, although these days air shocks are really good in my opinion.
    The weight of DHX Air is 0.98 lbs vs RC4 0.99 lbs, not much of a difference. Base on the comments here, I think the choice is obvious - RC4
    Quote Originally Posted by chris9888 View Post
    That weight does not include the spring. So add at least another pound or more to that.
    Picture Unrelated
    Reputation: zebrahum's Avatar
    Jun 2005
    Another air/coil user. Float 36 with a DHX4 rear (until I can afford a CCDB).
    Axe
    Axe is offline
    Custom User Title
    Depends on the stroke. For 2.25" 550lb-in steel is about 370g. Titanium would be about 300g. Softer springs would be significantly less.
    Worth it.
    I have run a few air/coil combo's over the years and find that air shocks should be left for short travel XC bikes. Air forks are a bit of a compromise but work well. Currently using a CCDB and Kashima 36 Talas RLC.
    I have DHX 5 with the Push link, and Talas RLC on the front. Rides great, but I think I'd rather have a Float or a Bos Deville - I don't think the Talas is anywhere near as smooth as those other two.
    Or a Van maybe...?
  1. Coil fork on Air shock?
    By rancid08 in forum Shocks and Suspension
    Last Post: 12-06-2009, 03:09 PM
  2. Air Fork with Coil Shock
    By yashayashayasha in forum Shocks and Suspension
    Last Post: 02-25-2009, 06:30 AM
  3. Air Rear Shock with Coil Fork?
    By msgvb in forum Shocks and Suspension
    Last Post: 10-01-2008, 11:51 AM
  4. Coil fork - air shock
    By VR46 in forum Shocks and Suspension
    Last Post: 11-24-2006, 10:26 PM
  5. Coil shock / Air fork on a Heckler?
    By Burpee in forum Santa Cruz
    Last Post: 10-06-2004, 02:53 PM
