Results 1 to 45 of 45
    May 2013
    New question here. Buying a new trail bike, going back to 26 inch
    Hello folks. I'm not entirely sure if this is the right subforum for this question. Anyway, I hope you'll bear with me.
    I'm going to be buying a new trail bike this summer. I ride technical singletrack with plenty of rocks and roots, a few drops up to about 3-4 feet. It has a lot of climbs and twisty terrain that favors low speed and a somewhat short wheel base, which is why I'm going to go back to 26 inch wheels after riding a 29 FS for a year.
    Now, I know that I need to get out and test ride a few bikes. But before then I'd like to get some preliminary input.
    I'm looking at bikes with something like a 67-68 degree head angle and 130-150 mm travel. I'm thinking about the Trek Fuel EX and the Stumpjumper FSR (not EVO). Unfortunately I don't think I'll be able to test both these bikes, so I'm wondering if anyone here has experience with both and is able to tell me how they compare.
    Finally, I'm looking for input from other rides who ride the same kind of terrain I do -- low speed, technical singletrack with steep climbs and descents. Drops up to about 3-4 feet. Which bikes do you recommend that I look into / test ride? What kind of travel / geometry do you prefer on these kinds of trails?
    I'd check out the Yeti SB66 as well!
    > /dev/null 2&>1
    Reputation: Procter's Avatar
    Feb 2012
    For low speed technical single track with rocks and roots, steep climbing + descending with drops, you might want a DW link or VPP bike who's power won't be sucked away under compression:
    Santa Cruz Blur LT (140mm)
    Pivot Mach 5.7 (145mm)
    Turner 5 spot (5.5 in)
    Ibis Mojo (150mm)
    SB66 as Bob Saget stated
    I like a 67.5ish head angle for technical climbing with drops and heavy decents. All those are right around 68-67.5, and if you want to go slacker you could try a 10mm longer fork (than recommended), and/or a higher stack lower cup, or a 1.0 degree works angleset which works with a tapered steerer.
    If you do drops 3-4 feet now, all those will hold up, but, you might find yourself wanting to go bigger as you get more comfortable with those over time (I did). If you think you'll go any bigger, consider a beefier bike, like a Knolly Chilcotin (160mm), Ibis mojo HD, or a Pivot Firebird (167mm). A bigger bike like these will open up possibilities, but yeah you'll feel it on tight steep technical single track. I'm no free-rider but my firebird really helped me take my jumps and drops up a notch.
    May 2013
    Thanks for the replies.
    You've recommended a lot of good short link bikes, but unfortunately I don't live in the US and these bikes tend to be marked up by a huge amount here in Europe. Bikes like SC and Turner are already pretty expensive, but in my country they are marked up by about 50%. Otherwise an Ibis Mojo would be high on my list
    I'm limited to big manufacturers like Specialized, Trek and Giant. I'm also looking at bikes from Lapierre, Cube and Canyon.
    Nearly all European manufacturers use some version of Horst Link, which I honestly think is quite good for technical climbing because of its active nature. But I do see the appeal of VPP and DW link.
    If anyone has some experience with the regular Stumpjumper Comp 26" I'd be interested to hear about it. It seems like my local Specialized dealers have gone into full 29er mode, so this model isn't available as a test bike.
    I may be able to test the Evo 26er, but although I like the RCT3 fork I think it may be too much for my use.
    Reputation: qbert2000's Avatar
    Quote Originally Posted by cyclismo View Post
    if i was in europe i'd look hard at yt industries. great design and killer spec like canyon and cube, but i like the design and looks of yt better myself. the wicked looks just that, wicked
    Wicked Pro-20131700
    i still prefer the ride of a well designed horst link over a mini link that relies on chain tension to counter-act power induced suspension bobbing. i want my suspension active all the time
    Bicyclochondriac.
    For low speed twisty rocky-rooty terrain, I would not worry too much about a really slack head angle. 68 is plenty slack for that, IMO. ALso, I've owned two DW-Link bikes, and while one (MKIII) was reasonably good at remaining active pedaling over roots and rocks, the other (Turner 5-Spot) is not. I think that for what you are describing, Horst-Link is still a good way to go.
    Reputation: rustybkr's Avatar
    Re: Buying a new trail bike, going back to 26 inch
    If you have access to GT bikes check out the Distortion, sounds perfect for you.
    Giant Reign would fit your requirements. I have one and think it is an excellent value. Reign X if you are biased towards downhills.
    No offense to those who suggested it, but the Yeti SB-66 is about as far from short wheelbase as you can get. I think it's a nice design and the Carbon version is totally lust-worthy, just not in this application. It's long and low design is better for ripping straight to large radius turns found in the western us, not cleaning tight tech of the northeast, or apparently that found in cyclismo's area.
    For that type of terrain, the Pivot 5.7 and 5 Spot would be better tools, but cost prohibitive.
    The Trek or Stumpy FSR would fit the bill. One reservation I have about most of Trek's FS frames are the proprietary Fox shocks they require. I think the suspension design is nice, but what if you want to throw a Monarch Plus on there? +1 for the Stumpy.
    Would you consider used? There's a lightly used 2011 5 Spot for sale here in the classifieds with free shipping (not mine). It's possible this seller works for (or has hookups with) UPS or Fedex and might be willing to ship overseas...for free. Just a thought.
    > /dev/null 2&>1
    Feb 2012
    Good point k1 creeper!
    mountain biker
    Reputation: slyfink's Avatar
    If I lived in Europe, the allure of Cube, Canyon and YT would be hard to ignore. Especially since they get such good reviews...
    If you like DW's bikes, he's licensed his "Split Pivot" to BH. In a recent interview on Vital, he said his "one bike for a desert island" would be the BH Lynx 6. Seems like pretty high praise given that he's worked on some pretty impressive bikes...
    continuous growth is the strategy of a cancer cell.
    May 2013
    Quote Originally Posted by k1creeker View Post
    If I bought used, it'd have to be from a manufacturer that lets you transfer warranty. I think Turner might do that, actually... Anyway, the used market is pretty good here in Norway, lots of people keep their bikes for one season and sell them off. I've seen a few 5 spots on the used market.
    But I prefer to order a 2014 model at a 25% discount, or maybe pick up a 2013 model after the summer.
    The GT Distortion may be a bit too much, but the Force is viable. I'm a big fan of GT's isolated drivetrain, although I think it may be inferior to Maestro and DW. The Force is just a bit... ugly.
    The Cube AMS 150 is a good pick: CUBE*AMS 150 Super HPC Race It has 150 mm travel, 68 degree HT, 114 cm wheelbase (2 cm shorter than Stumpy Evo). It also has a carbon frame at the same price as the Evo.
    OK, I realize that this thread is turning into me thinking aloud, so I'll ask one more question: will a classic 67 degree, 150 mm bike be too much for the kind of riding I do (technical singletrack, max 3-4 feet drops)? Will I end up as one of those guys who owns a big bike and uses only 2/3 of its travel?
    Reputation: BTTR's Avatar
    Jun 2012
    If i were you, and since i live in Europe, i would buy my BlurLTc
    Why not go with less travel, try a Trance and put a Works headset to get it slacker.
    North Van/Whistler
    The Trek rides a little more stiff and up in the travel. The Stumpy tends to absorb terrain more. There's neither wrong or right. They're both solid bikes and it's individual rider preference.
    There's a lot of bikes in that class that are frankly awesome. In that class I've tried the Transition Bandit 26, Norco Sight 26, Ghost Lector and various 650b bikes that are priced so high that I'm reluctant to recommend them because (i) they're not available and (ii) they'd be way outside the price range of the bikes you've named.
    Basically for that kind of terrain I like bikes that can change direction and speeds quickly. I'm not as worried about top end speed. Both the bikes you named would do very well.
    Because you're in Europe I'd be looking at bikes like Canyon, Ghost, YT which are stupidly inexpensive
    Locals' Guide to North Shore Rides http://mtbtrails.ca/
    May 2013
    But more travel is fun too!
    The Trance isn't a bad idea. The question is basically if I should go for 68ish HA and 130-140 mm travel or 67 HA and 150 mm travel.
    North Van/Whistler
    Yup to your question. Almost certainly but if that's what you want its your money.
    That Blur LTC is an awesome bike; only drawback to me is that it doesn't do bottle cages but that's my personal thing.
    Given that you live in Norway you almost certainly want good local support since your trails are hard on bikes.
    Your terrain sounds a lot like my local trails. I tend to go a little bigger on the jumps and drops but everything else sounds spot on. I started with the regular stumpjumper and liked it a bunch. After about a year I upgraded the bike to the evo version. I would say the evo with 150mm travel and 67 head angle is just great. It doesn't give up a lot on the climbs and technical stuff but you gain a ton of stability on the downhills and drops. I would say either stumpjumper would suit you well, but don't be scared to try out the evo. It's a blast!
    wyrd bið ful ãræd
    Reputation: chinaman's Avatar
    Ever considered a Nicolai AM? HA 67. Travel adjustable between 135 -170.
    LCW
    LCW is offline
    Reputation: LCW's Avatar
    OP - Don't ignore the 575... It gets overshadowed by the SB66 these days, but it's an awesome bike that can be built light or burly. A bit more active and plush than an SB66. Some like that. Some like the livelier feel of the SB. Geometry wise the 575 fits your parameters nicely.
    Santa Cruz Hightower LT
    EVIL Following
    Reputation: charging_rhinos's Avatar
    The SB-66 is a great bike, but it is a bit costly. I owned a Giant Reign for 3 years, and it was also an incredible bike. It pedaled better than most any bike in its class, and felt much more slack and stable at speed. The yeti felt a bit twitchy and nervous when going through rocks at high speed. I recommend the Giant without a moment's hesitation. Fantastic bike, and the price is incredibly low compared to other bikes in its class. Super fun bike.
    Oh, it also kills Specialized fsr bikes in terms of overall performance. There is simply no way to tune a Speshy linkage to cover the range of pedaling efficiency and downhill performance.
    tangaroo: What electrolytes do chicken and turkey have again?
    rck18: All of them, because they're meat.
    May 2013
    The Giant Reign seems like a perfect choice. The Reign 1 is only 29 pounds with a dropper post, according to a review. That's light for a bike with full SLX and probably a slightly heavy wheelset.
    Mr. Knowitall
    Reputation: hssp's Avatar
    Quote Originally Posted by charging_rhinos View Post
    What fork was on the Yeti? It screems for 34mm og bigger stanctions...
    Reputation: p4nh4ndle's Avatar
    Oct 2012
    Quote Originally Posted by bobsaget View Post
    Yes. If (remind you, IF) I were in the market for a 26" double boinger at the moment the SB66 would be at or near the top of my test ride list.
    I ride similar terrain to as you (upstate NY) and I am very satisfied with my knolly endorphin. I have an older model frame with a head angle of 68...which feels a touch too steep for the downhills. The newer model frames are at 67 and I have heard nothing but raving reviews.
    Reputation: Tikiguy's Avatar
    The new Treks both Fuel and Remedy went 29. My 26 Remedy works the slower, techy, slippery stuff we have in the PNW and still rips the open stuff.
    2016 Whyte T-130C RS
    4 foot drops consistently would have me thinking you ought lean more to a 140 bike atleast. trance and the fuel x are a bit on the rough xcish end of things. step up to the reign with the maestro link is definatly the most cost effective way of getting a mini link design like the dw or vpp you can get. dw was quite pissed how giant skated around patent laws to come up with the maestro. a whole bike with dropper for the price of the patented dw and vpp frames. the fox fork and frame alone are worth the list price of the reign 2. the only down side is supporting the Chinese economy vs american
    Feb 2013
    Rode 29HT for 11 months and just purchased Trek Fuel 26er....Best investment i've made in long time The new 29 fuels look like sweet rides so i might pick one up down the road! Happy Trails
    SWING YOUR LEG OVER IT AND PEDAL
    if it were me besides the reign. I would go banshee spitfire. a 140 bike with the 67 DHish front and 74/75 steep seatube for climbing the steep stuff. never rode one personally but I love the idea of that geometry. the newer one has a new upper link design but its also a lower mini link. I personally ride a cannondale rz140. its ok. not laterally stiff enough for how abusive I can be though. it will probably have a short life span but its way light with 6lb somthin oz frame.
    how much do you weigh and how smooth are you? if your lighter, more fluid and pumpy, I would lean towards the lighter more flickabile choices of the spectrum. if your a Clydesdale and are gonna bomb into rock sections balls out; I would go 150+. 140 is a nice compromise. and again each manufacture has lighter or studier builds. theres also the transition bandit @140.
    Reputation: Fuglio's Avatar
    Quote Originally Posted by akiracornell View Post
    dont seem like much of a down side to me.
    China-men need jobs too
    Quote Originally Posted by Fuglio View Post
    didn't mean that in a racist way. one of the down falls of usa is that it no longer manufactures anything. unemployment is at an all time high. and the middleclass is just about disappeared. everything comes down to the bottom line. cheaper manufacturing means higher profits. didn't mean to mix politics with mtb. im poor. giant would be my choice also. but its also this attitude that feeds the machine of bottom line.
    May 2013
    I'm more like the former, so I'm leaning towards 140. In a couple of years I think I might look at a Mojo SL, but right now I'm still leaning towards the 140 mm Stumpy or the Reign.
    In a month or two the new Stumpjumper lineup will be revealed. I have a feeling that Specialized will redesign the Stumpy for 2014, considering that the current design has been around for four years now. Though knowing Specialized, they might eliminate the 26" Stumpy all together...
    Reputation: 8valvegrowl's Avatar
    Kona Process?
    Yeti ASR-5
    Reputation: ihaveagibsonsg's Avatar
    I hated the reign rear suspension. The initial part of the stroke is real plush but on big hits it blows through travel quickly then ramps up quickly. It's just not a smooth shock for big hits.
    I vote for the 2010+ specialized enduro. It will sacrifice quite a bit of climbing ability VS a fuel or trance but it will hammer the downhills better than any bike on your list by leaps and bounds..... and berms and jumps and steep rocky technical sections. Mine is equipped with a talas fork which makes the climbs bearable but don't plan on winning any XC races or setting any strava climbing records with it. My enduro is solid as hell too. 3k HARD miles on it and it hasn't needed any upkeep at all and nothing has broken on it except a hanger from crashing the bike. The entry level enduro is well spec'd for the price and is more bike than most people will ever need but at least you'll never feel like you need more bike if you bought something like the fuel.
    May 2013
    The Enduro is way too much bike for me. The terrain here is technical, but it's not particularly fast.
    I think I'm going with the regular Stumpjumper, which was my initial choice. Possibly a Fuel Ex 9 if I get a good deal. I've seen them sell at a big discount.
    In a couple of years I think I'll be looking at something like a Mojo SLR or a Blur LT. My guess is that there will be quite a few 650b bikes in the 130-140 category by then. Not that I really care about the whole 650b thing.
    BLAH BLAH
    The stumpy got a redesign for 2012, it looks a lot like the 2010-11 bikes but is and rides different. That being said they seem to be on a 2 year cycle.
    Whats this line for?
    dwt
    dwt is offline
    Reputation: dwt's Avatar
    If I lived in Europe and were in your situation I wouldn't move back to 26", I'd look seriously at this 650b, available on your side of the pond but not ours
    http://www.cube.eu/en/full/allmounta...r-hpc-160-slt/
    Old enough to know better. And old enough not to care. Best age to be.
    meow meow
    Reputation: b-kul's Avatar
    plus he's from norway. doubt supporting the u.s. economy is high on the op's list.
    anyways, i forget who said it, but take how much travel you want and subtract an inch. one of the smartest things i have read on here.
    May 2013
    So with all these people wanting me to get a 160 mm bike, that's... let's see... 6.3 - 1 is 5.3 ... that's 134 mm... add a bit for good measure and you get 140. Perfect!
    The moral of this story: take the most amount of travel that people online suggest and subtract an inch.
    meow meow
    good way to look at it too.
    Reputation: icecreamjay's Avatar
    We've actually still got a pretty decent amount of manufacturing. Maybe not as dominant as we used to be, but you can't say we manufacture nothing.
    Facts About Manufacturing in the United States
    Did You Know...
    In 2012, manufacturers contributed $1.87 trillion to the economy, up from $1.73 trillion in 2011. This was 11.9 percent of GDP. For every $1.00 spent in manufacturing, another $1.48 is added to the economy, the highest multiplier effect of any economic sector. 1
    Manufacturing supports an estimated 17.2 million jobs in the United States—about one in six private-sector jobs. Nearly 12 million Americans (or 9 percent of the workforce) are employed directly in manufacturing.2
    In 2011, the average manufacturing worker in the United States earned $77,060 annually, including pay and benefits. The average worker in all industries earned $60,168.3
    Manufacturers in the United States are the most productive in the world, far surpassing the worker productivity of any other major manufacturing economy, leading to higher wages and living standards.4
    Manufacturers in the United States perform two-thirds of all private-sector R&D in the nation, driving more innovation than any other sector.5
    Taken alone, manufacturing in the United States would be the 10th largest economy in the world.
    This info taken from the national assoc of manufacturers website.
    NEMBA Freetown VP
    Reputation: lew242's Avatar
    China-men? Last time I looked Giant was pretty much all made in Taiwan, except some very low end models. Also nearly every other bike is made in Taiwan too. You think if someone pays for an American or Canadian brand they are buying made in USA? Not usually.
    Quote Originally Posted by lew242 View Post
    technically, taiwanese are chinamen. roc, republic of china. or taiwan to non mainland chinese. still, world economy and almost everything you have in your closet or cupboard or even the computer you are surfing on was made in asia somewhere.
    don't know why people insist on usa made bikes while high percentage of all their other goods are made there. clothes, tvs, computers, electronics etc.
  1. 1 1/8 inch fork on 1 inch bike....
    By bing! in forum Vintage, Retro, Classic
    Last Post: 09-04-2012, 04:30 PM
  2. Shimming front caliper back a inch is there a problem?
    By Realslowww in forum 29er Bikes
    Last Post: 06-02-2011, 09:16 PM
  3. Tire setup for Colorado -5 inch trail/xc race bike??
    By Dirt_Diggler in forum Colorado - Front Range
    Last Post: 04-15-2011, 11:16 PM
  4. Replies: 25
    Last Post: 03-28-2011, 08:55 AM
