Results 1 to 75 of 75
    Kiwi that Flew
    Reputation: deanopatoni's Avatar
    Broken Carbon Handlebar anyone?
    Anyone broken a carbon handlebar?
    The reason I ask is that I have.
    I came down after an 'off' and got up to find my handlebar had snapped half an inch in-board of the brake level. The bars have been sent back and I have just now received an assessment back from the UK distributer stating that the brake leavers must have been over-torqued. However, the fact is that the brakes have been on the bike untouched for over a year. Surely if they were infact over-torqued, then they would have broken way before now??
    Or am I being fed some BS?
    (adding that this is my third carbon bar since 2006 and the first failure)
    Any thoughts?
    Cheers,
    deano
    Reputation: dump's Avatar
    It's hard to say deano. Carbon isn't known for its crashworthiness... overtorquing or not. If you set the torque on your lever to the recommended amount, it would be pretty easy to refute the claim of overtorquing. If you overtorqued your brake lever, I would be concerned about overtorquing your bars at the stem as well. I suggest getting a torque wrench and being mindful of the recommended settings from the bar and component manufacturers.
    Kiwi that Flew
    Dump, thanks for your comments.
    Good point about the stem. I'm not one for over tightening and in the past have had to retighten my stem as it slipped after reassembly after flying to the Alps (didn't have a torque wrench with me).
    --- deanopatoni ---
    Reputation: Luigiugueto's Avatar
    Oct 2007
    I did once too, really nasty crash.
    Its possible I couldve overtorqued my bars as I didnt own a torque wrench back then, but I've never been hamfisted and knew better than to over tighten things. Nothing on my bikes was ever close to being particularly tight.
    This bar also broke about an inch inboard from the levers. Ive never bought carbon bits since then... not even
    I have crashed pretty hard on my Carbon Heavens. One really bad at Fort Duffield, TN. I broke the brake, but the bar has been stellar.
    What kind of bar was it?
    18 Focus Raven Lite
    17 Focus o1e
    17 Yeti ASR-cT
    16 Bianchi Specialissima
    15 Echo Big Deal
    Kiwi that Flew
    Quote Originally Posted by irishpitbull View Post
    As I have asked the manufacturer to reconsider their assessment, I thought it would be polite not to name them (yet - pending some good news). That said if I was you irishpitbull I would be very (very) concerned. I had a big crash 4 months before the bars actually broke in a relatively small crash.
    --- deanopatoni ---
    Quote Originally Posted by deanopatoni View Post
    --- deanopatoni ---
    Thanks for the concern.
    18 Focus Raven Lite
    17 Focus o1e
    17 Yeti ASR-cT
    15 Echo Big Deal
    Kiwi that Flew
    Thanks Hongzheng.
    Worth noting that the handlebar installation instructions have NO advise on torque settings.
    --- deanopatoni ---
    BMF
    Oct 2007
    I had a carbon bars on two bikes that I've since sold. Crashed multiple times, broke brake levers on two separate occasions, but never had any issues with the bar breaking. It seems weird that the distributor would be making the call as to the cause in your case - I would be more comfortable with a verdict from the manufacturer who would have purposely broke many bars during design and testing and would understand from the broken bar probably quite a bit about why and how it failed. I'm not saying the distributor isn't qualified, but it seems less likely that they would be.
    I've never broken a carbon bar. However when
    I was a kid I broke quite a few steel ones.
    I have only broken Alum bars, never carbon ones and I use carbon bars for DH, and AM and have crashed many times hard on them and I am not concerned. The brake lever could have been over torqued if you check the bolts every so often and move the bolt just a little bit it will add up over time, there was an article on it that most bolts are way over tightened due to the checking of bolts and not people reefing on them when installing
    nocturnal oblivion
    Reputation: stumblemumble's Avatar
    Mar 2006
    I broke my carbon monkeylite bar in a wash out type crash. Snapped it halfway into the ODI grip (which shattered and tore as well).
    Definitely wasn't from torque spec, it was from me using it as a plow. I am 145lbs though...
    "...like sex with the trail." - Boe
    GAME ON!
    they say you overtorqued, you say you didn't. how can they prove you did or didn't? well, they don't really have to. they can't prove you did, you can't prove you didn't. the only deciding factor is that they are the deciding factor and they tend to favour their own best interests.
    RIP Adam Yauch
    "M.C. for what I AM and do, the A is for Adam and the lyrics; true"
    Kiwi that Flew
    Quote Originally Posted by saturnine View Post
    This is exactly my predicament.
    --- deanopatoni ---
    Kiwi that Flew
    Quote Originally Posted by The Beater View Post
    Your point about overnighting over time is very interesting. I guess that is why Easton state that you should use 'carbon friction paste' on their stems to help with slippage?
    --- deanopatoni ---
    Kiwi that Flew
    Quote Originally Posted by Kristatos View Post
    I agree. On seeing the response from the uk distributed I forwarded it on to the US manufacturer for comment. No response yet.
    --- deanopatoni ---
    Carbon paste is always worth it the fsa stuff claims you can use 30% less torque or something like that
    Kiwi that Flew
    Here are some interesting comments from PinkBike on carbon bars and paste.
    Pinkbike Product Picks - Pinkbike
    Easton recommends using both a torque wrench and a carbon friendly friction paste during installation, and it is well worth spending a few minutes to make sure that there are no burrs on any of the aluminum control's clamping surfaces. Our single complaint stems from having our brake levers rotate a little too easy when crashing, even when tightened down quite snug. Having them rotate from a crash isn't necessarily a bad thing, but the marks that the clamps left in the bar's clear coat certainly are, even if they weren't deep enough to compromise the bar in any way. Despite the slippery surface, the Havoc Carbon is still one of our favorite bars due to its light weight, high stiffness and great comfort. - Mike Levy
    Reputation: trap121's Avatar
    Mar 2011
    Why doesn't Easton put torque specs in the manual? Anyone know what they are?
    Broken but on the mend
    Reputation: mzorich's Avatar
    Mar 2011
    Quote Originally Posted by trap121 View Post
    my 35 carbons came with torque specs.
    my guess why they broke is either over torquing which is very easy to do with them or a defect in the molding process. i am hoping they are not Enve because i know of a few people who broke them. but its was due to over torquing then when they crashed they broke like yours.
    Mar 2011
    I have havens and havocs and neither came with torque specs. Makes no sense while they would sell carbon bars with no specs?? That being said, Im very happy with mine and have not had any issues with numerous ugly crashes. If they do fail, I will gladly buy new ones.
    Jun 2012
    Never broken mine, but that sounds unlucky
    Reputation: C-Dale_Rider's Avatar
    I've been riding and crashing a bontrager Trekking carbon bar for 6 years now. It has survived crashes on asphalt, a broken clavicle on a downhill bomb, and numerous trees/rocks/other stupid stuff. It's a 620mm so it's too short for my new bike build so it will stay on my xc bike. Brand name carbon is where its at.
    Kiwi that Flew
    The thing I donít understand is, if I had over-torqued them (possible but very unlikely as the carbon bars I have from 2006 and 2007 are still going strong with the same torque settings), why did they take over 12 months to fail? This does not make sense to me. I would have thought they would have broken after a big crash I had in May or maybe during 6 days heavy riding in the French alps in July. But it was a medium crash in Wales 12 months after the leavers had been installed.
    I guess if I have had at least 2 years use of them I would just be happy to get a new set, but 12 month is just not long enough. I thought also that a BIG name brand that specialises in the best bars on the market would be keen to give me the benefit of the doubt. This is why I forwarded my claim directly to the manufacturer for their comment, and not just the opinion of the UK supplier who donít specialise in design and manufacture but specialise in selling stuff.
    Still no response from them.
    FX4
    FX4 is offline
    Jun 2012
    Well you know how it goes, the squeaky wheel gets the oil. I would keep after them.
    I know CF is stronger but when it fails it's frequently a catastrophic failure. I probably have an unrealistic fear of the handlebar or fork failing at the wrong moment and getting seriously hurt. So I don't see using CF parts in my future. There are just a few too many gory failures floating around the net for my taste.
    dwt
    dwt is offline
    Reputation: dwt's Avatar
    I've broken two; both Easton. One on a road bike, no less.
    The road bike had never been crashed, but the bar broke when I hit a pothole hard enough to pinch flat the tire, and dent the rim. The bar broke on the hood where my left hand was, near the upper bend but NOT near the brifter clamp on the lower bend. So it was the sudden force of hitting the pot hole coupled with my weight on the bar.
    Mtb bar break was similar though that bike had crashed a few times. The bar broke above the left brake clamp (no shifter clamp it was on a 1 X9) as I was descending a rocky staircase. 120 mm fork, but it did NOT bottom out. Again the cause was force of impact and weight on bar.
    Scary stuff that, but I still have carbon bars and seatposts on 2 mtb and 1 road.
    Old enough to know better. And old enough not to care. Best age to be.
    Correct me please if I'm wrong but doesn't CF have a cyclical fatigue life? A lot of sailboats with CF masts are experiencing the same type of failures at the base. Seems to me because CF is an epoxy system it will have a crystalline structure. So if there's a notch defect like a deep scratch or a torn layer of CF weave it could initiate a tear, and rather quickly. CF seems just too stiff for cyclical loading. Look what happened in the beginning of CF frame building. Even now I'll never put my ass on a CF bike because it just simply isn't inherently flexible to ANY degree. Just as a bone will flex slightly before breaking so too does a bike part or sailboat mast. CF works great for flat panels like sailboat hulls and car fenders but I'm still not sold on the 3D forming of CF into bike parts. My 2 cents anyway.
    I am a mech engineer but I don't do CF.
    GAME ON!
    everything bends to some degree. but i'm not a doctor.
    RIP Adam Yauch
    FX4
    FX4 is offline
    Jun 2012
    Quote Originally Posted by C-Dale_Rider View Post
    This is exactly my thinking on the topic.
    Can you bend a column of ice? How about a pure carbon rod? I asked to be corrected if I was wrong and your statement does nothing to this effect other than act as a troll. CF does bend, that is not the question. The issue is CF doesn't yield as much as other materials common in the cycling industry like aluminum or Ti alloy. CF has an awfully abrupt stress-strain curve, too much for me to consider it for CYCLICALLY LOADED APPLICATIONS. Do let me know if I am wrong and please cite examples.
    BTW, I have a very freaky Bontrager trekking bar in CF with the grab handles in the middle and I am always skeptical of it every ride. I inspect it thoroughly before each ride out of paranoia. Alas, someday it too will succumb to cyclical stress fracture and hopefully I won't be on the bike when this is discovered. CF has no business being used for bars, frames, rims, seatposts, or crank arms in my educated opinion. Next time you're on your aluminum bike hit the brakes and stomp a pedal and watch how much your frame flexes. Do this same procedure on a CF bike and you'll begin to understand why CF sucks for frames and sailboat masts in terms of durability.
    Oh and if you lay up the CF too thin it will appear to flex but in reality (meaning you have to look really close) the crystalline structure of the epoxy is fracturing. Every single movement no matter how minute will cause some degree of fracture to take place. The matting weave is there to prevent the whole thing from falling apart too soon. Think of it like reinforced concrete. Concrete will always crack and is not flexible to any degree but what keeps buildings and bridges in the air? Reinforcing steel does. Same with CF. Weave is the rebar for CF.
    GAME ON!
    listen, i said i wasn't a doctor.
    i don't even know what the argument is anymore. there are people who straight up bend, break and destroy every part made of every material and there are people who can't break any part made of any material. then there are those who break carbon and wonder about it's place and strength and those who break alloys and wonder if they should have picked carbon instead. we're 10 or so years into this argument and probably another 10 or so years from the end. nobody's wrong (yet) and nobody's right (yet). those who are anti-carbon will enjoy their alloy stuff and the pro-carbonists will enjoy their fancy, expensive composite stuff. both sides win.
    i hope i can break my carbon bars so i can finally have a side to stand on but right now i'm smack dab in the middle, hoping what they tell me is right.
    RIP Adam Yauch
    007 is offline
    b a n n e d
    Reputation: 007's Avatar
    Jun 2005
    I've contacted Easton on this very notion. They clearly stated that their bars are capable of supporting any properly installed handlebar mounted component (e.g., shifterpods, stems, brake levers, grips) that is torqued to the specs provided by the component manufacturer.
    Oct 2010
    @ c-dale rider... check out this link and tell me if you still think carbon has no place in bike frames at least. Santa Cruz Bicycles - Test Lab - Pinkbike
    its all about the weave and layup used for different areas of the bike that determine its strength, flex/stiffness, and weight. as for carbon wheels... the claim has been floating around that at least the santa cruz downhill team has gone from going through new al wheels every race, to using 1 set of wheels laced up with enve carbon hoops for the entire season. you dont have fully trust carbon, but i personally dont see a reason to worry.
    as for bars ive heard bad things about Eastons EXCEPT for the Havens and Havocs.
    with carbon bars in general some people have had great experiences, others have not. could be a defect, over torquing, or just sheer force of a particular incident.
    regarding properly torqued parts, at the shop i work for we ALWAYS use the Ritchey torque key when installing carbon bars and controls, and have not had any issues. the torque key is $15-20 pretty inexpensive vs the cost of new bars.
    i actually set up my controls so they will move in a crash instead of breaking, but are not so loose they move just by bumping them. i believe this has saved my levers from breaking a few times.
    Juice
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    Bottom line is you crashed and they broke. Buy another bar and hopefully you don't wreck again bad enough to break anything.
    I've wrecked a few good times, never broken my carbon bars. Did break my brake levers, collarbone, and cracked stem.
    RTM
    RTM is offline
    #1 Latex Salesman
    Reputation: RTM's Avatar
    To touch on the question of how the manufacturer is handling this...they are in a tough spot. Instead of pushing for a replacement, maybe settle for a discount on another bar. The manufacturer can't outwardly, and readily agree with you without pushing back a little bit. Otherwise they're sending the message that this kind of thing does happen under normal conditions even when torqued perfectly. That would not fly.
    Kiwi that Flew
    Quote Originally Posted by RTM View Post
    This is a good point RTM. They have offered me a 'crash replacement' at 50% off full RRP. I'm thinking as I have had the use of a bar of a year already, 50% for a new one is reasonable (?). Adding to this I have asked for their more robust DH bar that has a 35mm diameter, so will need a new stem from them as well. They have offered me a great price on that also. So in summary I guess I'm getting a far deal.
    Next time I will take photographs of the installation along with the torque wrench and keep these with my sales receipt for save keeping....
    Thanks all to those who have commented on this thread.
    Thanks to MerlinCycles.co.uk for their efforts on my behalf.
    Cheers
    deano
    RTM
    RTM is offline
    #1 Latex Salesman
    well, I say you handled this with class, and the manufacturer stepped up to meet you half way. you can both be satisfied with this deal. imagine that! reason, compromise and happiness in a carbon breakage thread!
    Kiwi that Flew
    Good words RTM. Good words.
    Kiwi that Flew
    Here's the photos.
    Noting that the bar broke at the shifter clamp and not on at the brake clamp.
    I was lucky that when I landed on the bar end it hit bone and not soft tissue, else the bar may have gone a bit deeper.
    Next time I'm taking photographic documentation of the installation with torque wrench so that there can be no argument if I break the next one.
    Happy New Year trails...
    deanopatoni
    (PS - Please excuse the nipple shot!)
    Attached Thumbnails Attached Thumbnails Broken Carbon Handlebar anyone?-img_2460.jpg
    nocturnal oblivion
    Mar 2006
    ^^^I'd hit up Vegas after that. Mine snapped mid-grip, so there's no way it was torque related. Snapped in a wreck.
    Kiwi that Flew
    Quote Originally Posted by stumblemumble View Post
    True - I definitely got lucky
    Not so lucky with the Easton warranty - quote below as returned to my place or purchase:
    "After an inspection of this item it has been deemed as not covered by our warranty. It is our opinion that the brake leavers have been over tightened causing a stress fracture to the carbon. Over time this would have weakened the bar, a small impact can then cause the snap that has occurred. I would recommend discussing the use of a torque wrench with our customer and explaining the importance of this"
    007 is offline
    b a n n e d
    Jun 2005
    Schweeeeew I'd be pissed and would definitely be fighting that one.
    Kiwi that Flew
    Quote Originally Posted by OO7 View Post
    Sent Easton the photos, my email and the email from the UK importer. Easton refrained to comment or to respond to my polite email.
    Like I say. If you want a warranty, try another brand. Bars are expensive enough, so I would definitely not buy wheels with a worthless "advertised" warranty.
    I was surprised with the response from Easton (or none response).
    007 is offline
    b a n n e d
    Jun 2005
    Yeah, I'm really surprised as well . . . and would definitely make me think twice about another Easton product. A failed part + poor warranty is not a good thing.
    Reputation: mojojojoaf's Avatar
    Man I have never seen a bar snap personally except once YEARS ago and this just confirms my fears of a bar snapping - dean you were lucky.
    Kiwi that Flew
    Quote Originally Posted by mojojojoaf View Post
    Cheers Mojojojoaf.
    --- deanopatoni ---
    Rep Power: Pick a number
    Reputation: Xcisok's Avatar
    Going to hang around for this one to see the out come
    I think I would be adding the words broken Easton Haven bar and no warranty to the title. I am sure a bit of bad publicity would not be liked by Easton!
    Kiwi that Flew
    Quote Originally Posted by Rick Draper View Post
    True.
    --- deanopatoni ---
    Kiwi that Flew
    UK Sale of Goods Act 1979 CHAPTER 54 .... an Act to consolidate the law relating to the UK Sale of Goods .... the seller or buyer, the party not at fault may maintain an action for damages against the party at fault.
    (Edit)
    This is what they are referring to when they say that something "does not effect your statutory rights"
    --- deanopatoni ---
    bikeaholic
    Seriously? It's pretty obvious that what Easton is stating in their response is 100% reasonable having looked at that picture.
    Quote Originally Posted by Dougie View Post
    +1
    No doubt in my mind this was user error.
    18 Focus Raven Lite
    17 Focus o1e
    17 Yeti ASR-cT
    15 Echo Big Deal
    Kiwi that Flew
    +1
    This is the only experience of carbon failure that I have had. The odd thing is that the brakes where not over torqued. This is the reason I'm going to photograph the installation next time.
    It's just an easy 'get out' for them, because if a bar has a manufacturing defect it is going to fail at a clamping location right?
    We will never know.
    --- deanopatoni ---
    Kiwi that Flew
    UPDATE:
    1. Easton did replace my bar as soon as I contacted them directly. No questions asked (I did provide them with all the same information as given to the UK distributor)
    2. I bought a new torque wrench and checked all my existing bolts and they where ALL WELL UNDER THE RECOMMENDED MAXIMUM!!
    So in conclusion I am really glade I contacted Easton directly as there is NO WAY that my bar controls where over torqued. Even bolts than I have tightened without a torque wrench where still well under the maximum setting. The whole process did leave me without a bar for 6 months and I did have to spend another £45 to get a second torque wrench to prove to myself that Im not a installation d!ckhead.
    Thanks all for your comments good and bad.
    Cheers
    Deano
    Five is right out
    Uh, what about the part where you had a "massive" crash on these 4 months prior to the final crash? Could it be that you've been riding around on damaged bars ever since then and that it was simply a matter of time before they failed?
    Kiwi that Flew
    Quote Originally Posted by womble View Post
    True - It could have been that. In which case it should have been replaced under Easton's warranty without any of the UK distributor BS.
    Five is right out
    They have automatic crash replacement on their carbon bars? Nice.
    Here in the states at least, they have or had a no questions asked replacement policy if you manage to break one of their carbon bars. This was implemented when the first introduced their carbon handlebars as they were new technology that had a shaky past under different manufacturers. So that policy was there to ease any fears people had about the strength of the bars.
    So, what you're telling us is, that the thousands of companies that build carbon fiber parts for these type of applications, like F1 teams and the millions of people that use these carbon fiber products are all wrong and you know better then all of us. Uneffing believable!
    Bingo!!
    007 is offline
    b a n n e d
    Jun 2005
    Exactly . . .
    Automatic? No. You have to call them.
    The fact that the bars were crashed prior to the failure is irrelevant . . . glad it worked out for the OP. Why anyone is busting your balls for it is beyond me . . .
    Flying in High in the Sky
    Oh come on people it's just a carbon bar your arguing over about. No need to get all pissy pants and techinical. Get it replace and move on.
    Kiwi that Flew
    Quote Originally Posted by James_spec View Post
    It was replaced with a 35 havoc carbon 800mm. AMAZING!
    The new haven is now on my Flux which suits this bike perfectly.
    Cheers
    --- deanopatoni ---
    Banned
    Take advantage of warranties all day long, I say
    Reputation: Rojo Grande's Avatar
    Oct 2012
    So the moral to this story is, take advantage of every opportunity, set your morals and values aside....you are not responsible for your actions? I hope you enjoy your next bike and components, made only in China.
    "El Cajon?, that's the anus of San Diego"
    nocturnal oblivion
    Mar 2006
    No good
    Quote Originally Posted by Rojo Grande' View Post
    Warranties are only for show after all, it's not like there's a reason a company backs up a product other than hype.
    I broke my Easton carbon bars in a wreck, had I known I would've warrantied them.
    Bars shouldn't snap under a rider in a wreck. Just like any other component, they're designed to withstand the rigors of riding.
  67. #67
    Bars aren't made for wrecks, they are made to steer bikes clear of wrecks. You can't expect companies to warranty stuff because you crashed and broke stuff.
  68. #68
    nocturnal oblivion
    Mar 2006
    Quote Originally Posted by Mountain Cycle Shawn View Post
    Wrecking is a part of the sport. Some companies give no questions asked warranty because they know this.
    Furthermore, I'm 140lbs. No bars should be snapping under me.
    Crash warranties are just that, not sure where there's room for argument.
    Manufacturer defect warranty is different and is not what we're talking about.
  69. #69
    Oct 2012
    Bottom line there are companies out there designing, developing and producing the best products they can for the consumer. That's the capitalistic way.They offer warranties for the things that they feel they are responsible for, which are defects in design and manufacturing. When the consumer takes advantage of this over and over, the innovators, designers and people that put up the money to create the products that we want/demand, will stop. You and me, will be left looking for innovation, design and parts that are created and backed by third world producers that will have no accountability, ever! Just like our current government does, keep effing the people that produce the products that the consumer wants and they will pack up and leave.
    If a product is poorly designed, manufactured or defective, then we should have the opportunity to get our money back. If we abuse that same product then we should take responsibility and either buy another one (That we liked) or move on and try another brand.
    Don't kill the industry because you feel everyone owes you because you spent money on their product.
    I don't know of anyone, other than our government, that is immune from responsibility.............that doesn't make it right to screw them because you want a freebie.
  70. #70
    While riding. Crashing is another thing. Not many companies offer crash replacement. And most of the ones that do, you have to pay extra for it. Oakley used to offer a crash replacement on their sunglasses, till everyone started breaking their sunglasses when they decided they wanted a new pair. That didn't last long.
  71. #71
    ^ + rep for that!
  72. #72
    nocturnal oblivion
    Mar 2006
    I understand what you guys are saying, but the OP's bars broke while riding. It's a big assumption that it was related to a crash four months before.
    I think he's totally justified in a warranty replacement.
    Mine broke in a washout, grip area was used as a plow in redwood duff soil. Should they have broken? Given my weight I don't think so, but they were used a plow. Had it just been a load of torque due to my weight (which it really was if you think about it) then they shouldn't have broken. If I had landed with all my weight on one grip, they shouldn't snap and that's the same force. (broke midway through the grip, not anywhere near a clamp).
    There are limits to any part, but there is a level of stress any part should handle whether from a wreck or riding. That line is a judgement call for the company and consumer. The OP's part broke JRA, a long time after a wreck. Accusing him of drivng out American mfg is rididculous. He made a justified warranty claim, the argument that he screwed the company has no place.
    Again, I know your argument and agree with the potential for abuse. Just not in this instance.
  73. #73
    Delirious Tuck
    Reputation: thefriar's Avatar
    Please communicate that bike parts shouldn't snap in a wreck (or JRA) to:
    -countless spokes
    -countless derailieurs and hangers
    -brake levers
    -frames (not during wrecks!)
    -pedals (after 3' drops to tranny with otherwise smooth landings)
    -Seat posts (cased landings)
    -Saddle rails
    -Chains
    Some stuff I'd rather snap than have seize up/not give and deal with those consequences.
    We don't exactly practice a sport that is cheap and nothing out there can hold up indefinitely to the pressure and physics that are generated in this sport.
  74. #74
    Kiwi that Flew
    Like your's mine broke after getting off line in the air off a 2 foot high jump and landing/ leaning against the side of the trail, plowing with the bar.
    I have been riding MTBs since 1990. I've never broken a bar before this OP. MTBs are made to withstand crashes, so are the components. The big crash I mentioned was big for me, may have been small for others, left me with a sprained thumb and sore foot. Rode the 5 miles home. Rode the next day. No big deal. Did bottom out my Lyrik fork which doesn't happen much for me.
    Easton replaced my bar. I'm not trying to bring down Bell Easton Sports corp, I'm supporting them. I've bought 2 more of their bars since the breakage. They did the right thing. They honoured their warranty.
    Cheers
    deano
    --- deanopatoni ---
  75. #75
    Dec 2010
    I used to leave the brake levers on my bike partially loose on purpose, so they would spin and not break in the event of a crash.
    At least two people in this thread broke their handlebars in the brake lever zone which make think two things: the first, the levers could have been overtightened; the second, to reduce weight manufacterer use less material in the hadlebar outer area.
    The use of less material in the area farther from the center of the handlebar is understandable since the torque loads exerted by the riderīs weight decrease toward the end of the handlebar, so i think that a crash should break the handlebar near to the center where loads are higher, if it does it near the brake levers i would redesign the piece putting more "meat" in this part or using a different wave direction or whatever designers do to increase strenght. In both cases i think is the responsability of the manufacter to insure that consumer is safe by assuming that bike are crashed and the design must survive this to certain extent. I applaud Easton for back their products and dont think that deanopatoni did something wrong.
    This is not by any mean an "educated opinion" i dont have any knowledge about CF other than this material is "sexy", light and strong, i ride a Blur LTc and dont feel worried for the strenght of the frame, the only reason for me not buying a CF handlebar was that price for this part is too high to justify the purchase over a good aluminium hadlebar...
Members who have read this thread: 8
