Results 1 to 36 of 36
    Reputation: jsqueri's Avatar
    Dec 2010
    Body position debate
    Help me settle it.
    My buddy and I have been debating the best position for taking steep rocks and drops at low speed. I love this type of riding and I feel very confident with my weight shifted way back. My arms are bent and flexed and my weight comes back to center once over the obstacle. He says keep the weight over the seat. I get that for fast moving downhill, but for slow techy stuff?
    Jun 2012
    Can't really give you an answer without seeing your form and his... for all we know you could both have the same form but a different idea of where your weight is being placed..
    But for slow techy stuff I can't really imagine why anyone would want to be behind the seat... I don't go behind the seat unless im going 15+ or going airborne.
    Whatever you do, don't ride like this overacting tool in the MBA "26/27.5/29" wheel size grudge match. This drama queen deserves every lost tooth that falls out of his head.
    Dec 2010
    "I can't really imagine why anyone would want to be behind the seat"
    I'm talking low speed on the down side of boulders mainly. Not quite vert, but close. I don't do anything as big as this photo, but same idea. I just can't see rolling down this with my body in the same position it would be on flat ground.
    Jun 2012
    Oh.. in that case.. HELL NO... on stuff like that always lean back as displayed in the photo. Trying to ride down that in a neutral riding position will likely result in face being introduced to ground or rear end being penetrated by seat.
    Trying to ride down that boulder in a neutral position would be like purposefully leaving your dropper post fully extended for a long steep downhill... just doesn't make sense and is asking for trouble.
    Also that wheel size chart with all the different body positions is one of the worst things I have ever seen.
    Yup it's really tough to answer without some pictures to get an idea of specifics. Generally speaking, you want your center of gravity (hips) to remain in relation to your bikes center of gravity (bottom bracket). These to points are variable based on: body type, bike geometry, terrain.
    I will say that a lot of people ride too far back when it comes to the bike pointing downhill, or riding technical terrain. You need to keep adequate weight on your front wheel to pilot the bike. With modern frame geometry having a more slack head angle, I find you don't need to ride very far back in the cockpit.
    In the pic above, that is a pretty normal position on a downhill bike. Because of the size of the frame, and the steepness of terrain...I would describe his hips as being low, not back.
    Dec 2010
    Very visual writing there shred. You don't mind if I quote some of those gems when explaining this to my buddy do you
    I think focusing on where your butt is relative to your seat confuses the issue. What you want to is for your center of mass to be over the bottom bracket. This keeps you centered on your bike.
    In the picture above, if you drew a line from the dude's approximate center of mass through the bottom bracket it would be pointing straight down. That is the position where he is centered and balanced.
    It just so happens that for that particular rider on that particular bike his butt is behind the seat to achieve his centered position.
    If he was too far forward, he would endo. If he was too far behind the seat just for the sake of being behind the seat, he wouldn't be able to pull up for the transition. His position relative to his seat is a secondary result of him finding his center over the bike in that position.
    edit--- just saw LAXcarp wrote the same thing only better a few minutes before me. Good job, Laxcarp
    Dec 2010
    I like this. It's the closest I've read to an absolute statement on this that covers ups downs and flats. I also like it because it validates my view. As the front axle drops lower on a down hill your weight should move back accordingly, the lower the axle the farther back you go.
    CoolArrow
    Reputation: jhazard's Avatar
    The image of the DH guy is a little distorted due to the wide angle lens it was shot with..
    A while back I used to think that way behind the seat the way to do it, until I saw some people rolling things steeper than I did, and saw how "centered" they were in their bike. Good example here:
    (rider: Fuglio Pea)
    If you lean too far back, you lose the ability to effectively navigate...
    Cool BandolArrow
    Jerry Hazard website
    Dec 2010
    In the first pic you can see his butt is over the rear axle, his upper body is very low and, to your point, his arms are still bent giving him plenty of control over the front end. The rider in teh pic you posted isn't as extreme, but he's definitely back a good bit more than he'd be on a flat section of trail.
    Dec 2010
    Actually, this is a GREAT example...
    So what's your take? Keep the butt pretty much over the seat or getting behind it? That guys butt is definitely behind the seat, no?
    Reputation: knoob's Avatar
    Re: Body position debate
    The seat is irrelevant. Your center of gravity(hips) over bikes(bottom bracket) center of gravity! As stated very clearly, multiple times above.....or the best 3 outta 5 on said obstacles.
    Dec 2010
    Yeah, maybe we need some female riders to in order make a more informed assessment here.
    I'm liking this explanation also.
    Dec 2010
    So as I was saying, if you take a look at her butt you'll see its behind the seat.
    Dec 2010
    Quote Originally Posted by knoob View Post
    Hey, I stated this opinion pretty clearly to my buddy too, but he's still debating it so I'm just looking for other input. There are other opinions apparently.
    I get it, the butt relative to seat isn't really the point, but generally as things get steeper your butt moves back.
    CoolArrow
    Quote Originally Posted by jsqueri View Post
    The point of the photo was to show that his head/shoulders are the important part, not the position of his arse. And in the first pic, his rear end is NOT over the axle:
    They're not moving "back" so much as they are down. Its not about the butt. Don't look at his butt (well, if that's your thing, feel free of course :P ) But check his shoulders/head - it's about moving your center of gravity *down* and in to the bike. The fact that there's a seat in the way is beside the point - except you have to move behind the seat to get low, and that's what happening in the photos. The first rider is more "extremely" positioned, but he is lower - not further back than my man Fuglio.
    If you were to keep moving back further and further, your arms would straighten out, and you loose any hope for control.
    Butt, whatever...
    Cool BandolArrow
    Dec 2010
    I got it. That's why I wrote the following in response to your post.
    This the debate I guess I'm talking about. So you just lower your COG. I have found keeping my COG over the BB is the trick. Yes, I'm lower, but I'm also farther back. If you don't move your hips back your COG gets ahead of teh center of the bike the steeper the incline, afaik.
    I know I'm geekin out here, but I really want to understand this.
    Dec 2010
    That's awesome. Your boys I assume.
    Reputation: nauc's Avatar
    low and back, unless you like to do faceplants
    Reputation: Swissam's Avatar
    Quote Originally Posted by k1creeker View Post
    just read that article and they even admit that "in experianced hands" the 26er beats both 27 and 29 up and down. But then go on to claim that 27.5 is the best because MTBA readers are not very experianced. I always get the feeling that MTBA is written by roadies who pick up a MTB once or twice a year.
    Dec 2010
    Dirt Rag FTW
    mountain biker
    Reputation: slyfink's Avatar
    Lee Likes Bikes
    there's some info in there about body position. Dig around his site for more info, or better yet, buy his book. well worth it.
    continuous growth is the strategy of a cancer cell.
    Mar 2011
    Watch Fluidride: Ride Like a Pro.
    Has a good sections on drops.
    The freebie can be had here: Fluidride Like A Pro MTB PART4 - YouTube
    If you need diagrams and text, download the pdf for Instructor course from Terra Method:
    http://www.terramethod.com/downloads...forwebsite.pdf
    Good luck.
    Dec 2010
    Very good stuff. Thanks.
    Oct 2013
    Too bad fluiride is not available any more. Wish I downloaded it. As for the terramethod link, thas is for level 2. There is also a level 1 available here
    Thanks for posting
    i think its completely contingent on how vert the rollin, or drop is, how fast or slow your going, and how big the obstacles your hittin with your front wheel, some rocks in slower situations will hang you up and send you over the bars if your not back far enough. the same rock at 3 mph faster is a no issue. Compared to the pics; I just did a smallish oververt drop/rollin into a small tranny and when I head over the ledge of the rock you better bet im getting low and back. get back as far as the situation dictates.
    in this pic hes compressing to set up for the drop off the end of the rollin. awesome pic. that's gnar.
    Help me settle it.
    if hes pulling off the same section as you with his weight more forward, you maybe exaggerated back, or he has a slacker bike, or bigger wheels? or hes hitting it different. depending on the section your hitting it may just be a matter of lowering your upper weight behind the bars, and keeping all your limbs supple and not braced. heck I don' know, theres no one way to skin a cat.
    Oh, So Interesting!
    Reputation: davec113's Avatar
    In the beginning, when you are getting a feel for riding steeper terrain, better to err on the side of your weight too far back than forward. Over time you will get a feel for where the best position is.
    The biggest thing for beginners is to tell them to push the handlebars down as the bike pivots forward into a depression, otherwise they pivot their body forward with the bike, which is bad/dangerous.
    I have Flat Pedal shame.
    To be clear, he isn't moving his weight back in that pic... his bike is moving forward. His belly button is centered directly over his bottom bracket. That's actually a fantastic position he is in; who is that guy?
    Reputation: Ufdah's Avatar
    Sep 2012
    Quote Originally Posted by slyfink View Post
    Lee Likes Bikes
    I agree with this. His book does a great job. Just remember heavy feet, light hands. You should SELDOM be pushing down or pulling up on the bars. If you are that means your CG is not centered. Just focus on your hands, if you can relax your grip and let your hands "float" on the bars your fore/aft distribution is probably good. If letting go of the bars would immediately send you over the front or back then you need to make some changes.
    Nice butt ........ I would so hit that like the Hammer of God!!!!!!!
    Reputation: targnik's Avatar
    Jan 2014
    What ever gets you to the bottom in one piece! Not much reference to rider size in relation to bike. I have rather long arms (i.e. height is 6ft, arm width is 6ft 2.5in... I am also top heavy (long arms?) I like to get right back on steep techy descents.
    Sent from my i9100 Warbird
    "Mountain biking: the under-rated and drug-free antidepressant"
    I would like the OP to look at it this way, and forget where seat is. It is not you moving your butt back or anything like that. Your bottom bracket is where your weight is, so, imagine it as the center of a see-saw, when you go down your arms stretch out (allowing the forward side of seesaw to go down), letting front of bike go down while not moving from the center of the seesaw. When you go up, our arms come to your body as the front wheel comes up, and you are still over the center of the seesaw. On your bottom bracket, center of the seesaw, you allow the bike to pivot under you while you stay center weighted on bottom bracket. The bike moves, you do not.
  1. V10 Shock Debate
    By brainbckt in forum Downhill - Freeride
    Last Post: 07-31-2014, 08:04 AM
  2. Replies: 6
    Last Post: 07-17-2013, 01:24 PM
  3. Need upper body protection - Leatt Body Protector 3DF?
    By Simplemind in forum Apparel and Protection
    Last Post: 06-25-2013, 11:40 AM
  4. Skills Clinic: body position
    By June Bug in forum Women's Lounge
    Last Post: 06-19-2013, 08:18 PM
  5. Body Position via Stem & Seatpost
    By 4nbstd in forum 29er Bikes
    Last Post: 08-23-2012, 08:39 AM
