Results 1 to 12 of 12
Thread: Bike hubs
    Aug 2018
    Smile Bike hubs
    Hi,
    I'm new to cycling and stuff, recently I saw that you can buy front and rear hubs for your bike's wheels like for instance "deore xt front hub":Bike hubs-new-temporary.jpg
    But how do you replace it with your old hubs? Do you need a bicycle mechanic?
    I would appreciate it if someone can help me out.
    Jun 2014
    Yeah, you would need to build a wheel around the hub, with spokes and a rim. You could either do this with your existing spokes and rim or with new ones. I think people generally only replace hubs when one is broken and even then they take the opportunity to upgrade more often than not.
    Some bike mechanics are wheel builders others aren't. You can do it yourself, but it requires a bit of skill. Regardless, you want a wheel builder rather that a general bike mechanic.
    Dec 2016
    Quote Originally Posted by TwiceHorn View Post
    Except you will most likely need different length spokes for a different hub.
    Someone who can't build a wheel shouldn't be called a mechanic. It's basic stuff.
    Other than a bit of skill you also need some not so cheap equipment like a truing stand, dishing tool, and ideally a spoke tension meter.
    Jun 2014
    Excellent points. The sad reality, though, is that a lot of "bike mechanics" can barely true wheels, much less build wheels.
    EAT MORE GRIME
    Reputation: 127.0.0.1's Avatar
    Nov 2013
    I am an expert in everything any bicycle or parts
    can have or do or assemble/disassemble. no problem
    but I stay the hell away from wheels and building them, I leave it to the
    wizards.
    I can also build a piano but no way can I tune one properly
    "Put your seatbelt back on or get out and sit in the middle of that circle of death." - Johnny Scoot
    Dec 2016
    Quote Originally Posted by 127.0.0.1 View Post
    wizards.
    If you understand the basics, and you can true a wheel (which anyone can learn), you can also build one after watching a tutorial. It's really nothing special, but you need the proper tools.
    Guest
    Generally it's cheaper to buy a new wheel than to rebuild one with new hubs if you can't do it yourself. Most bikes come with wheelsets that have relatively well matched components (i.e. low grade hubs generally come with cheaper spokes and rims) so if you replace the hubs you're only upgrading one of three parts that make a good wheelset.
    Reputation: WHALENARD's Avatar
    Feb 2010
    Only on a Cannondale and only then if you're on an all meat diet.
    It is no measure of health to be well adjusted to a profoundly sick society.
    EAT MORE GRIME
    Nov 2013
    Quote Originally Posted by HollyBoni View Post
    yeah I know. it is the lack of accurate truing stand and tensionometer stopping me
    trying to do it with the forks or stays as a truing stands is problematic
    Reputation: s0ckeyeus's Avatar
    I've trued several of my wheels with a rim-drive trainer.
    (It actually worked pretty well.)
    Barely in control
    Reputation: Schulze's Avatar
    Feb 2007
    wizards.
    Neat. My mommy always said I could be a wizard!
    Jan 2009
    It's not hard.. hmm, ok it is hard at first. But once you get over the learning curve it's pretty easy actually. I taught my self by reading Sheldon's like 20 times lol. And truing stands are not that expensive, that is to say you can definitely build just fine on a cheaper 100 buck stand.
  1. Hubs hubs hubs
    By reamer41 in forum Wheels and Tires
    Last Post: 01-09-2018, 02:31 AM
  2. hubs hubs hubs
    By rho in forum Singlespeed
    Last Post: 05-31-2013, 07:34 AM
  3. Center Lock Rotor Hubs or 6 Bolts Rotor Hubs
    By hamis in forum Wheels and Tires
    Last Post: 05-13-2011, 12:11 PM
  4. XTR hubs VS XT Hubs
    By Timeframe in forum Wheels and Tires
    Last Post: 05-03-2011, 11:43 PM
  5. stan's ZTR hubs vs. high end - King, DT 240 - hubs
    By gabbard in forum Wheels and Tires
    Last Post: 02-07-2011, 08:57 AM
Members who have read this thread: 84
