Page 1 of 2 12 LastLast
Results 1 to 50 of 59
    Reputation: dhbomber's Avatar
    Nov 2006
    Best way to lighten your trail/all mountain bike?
    This has probably been beaten to death!
    But I havent found specifics on what I want to know! so bear with me.
    I don't know..titanium bolts...were to put them? I've found some kits on fleaBay for cheap for everything from the thomson stem to the seatpost to the calipers and rotor bolts!
    I'm no weight weenie.... or am I?
    I just saw that stuff on Ebay and thought about how to lighten your 6" travel (for ex.) SMARTLY.
    Any other ways?
    -Go tubeless
    -Titanium springs (if applicable)
    -Etc.??
    I have this....
    Frame: 2010 Intense tracer Vp Medium WHITE w/grey stickers, not the red ones.
    Fork: 2011 Fox 32 RLC 150 Fit Qr15 with the Kashima thingy BLACK
    Headset: Chris Bling (King)...InSet at the top, external at the bottom. BLACK
    Wheels:
    Rim: Stans Notubes Flows 32h BLACK
    Spokes: Dt 14/15 BLACK
    Nipples: Alloy BLACK
    Hubs:
    Front: Hope Pro2 15 thru axle 32h BLACK
    Rear: Hope Pro2 10 thru axle 32h BLACK
    Rear Axle: DT Swiss RWS 10mm x 135mm
    Tires:
    Front: Kenda 2.3 Nevegal (tubeless converted)
    Rear: Kenda 2.1 Slant Six (If available...if not Small Block 8 in 2.3)
    Crankset: Shimano XT w/32t chainring
    Bottom bracket: Shimano XT
    Pedals: Time ATAC (beat to shiz)
    Front der: None....MRP 1.x BLACK
    Rear der. Shimano XT shadow 10 speed
    Chain: Shimano XT 10 speed
    Cassette: Shimano XT 10 speed 11-36t
    Shifters: Shimano XT 10 speed, Right Only
    Stem: Thomson X4 80mm
    Handelbar: (If Available) Syntace Vector Carbon 31.8x740mm 8deg. sweep
    (If Syntace N/A RaceFace Atlas FR cut to 740mm BLACK)
    Grips: ODI Cross Trainer Lock on (suuuper comfy)
    Brakes: 2010 XTR Disc Brakes w/Shimano fixed 160 rear rotor and 180 front rotor. Ti bolts.
    Seatpost: Thomson 31.6mm BLACK
    Saddel: Fizik Gobi XM Ti BLACK
    Thoughts?
    My Bike: http://forums.mtbr.com/showpost.php?...3&postcount=49
    On-One Whippet 650b XC machine
    meow meow
    Reputation: b-kul's Avatar
    dont see anyplace you could shed a hell of a lot of weight. already seems like a fairly lightweight build to me.
    Nov 2006
    Quote Originally Posted by b-kul
    anywere?
    is the list above your build or what you are looking to buy as replacement parts.
    if this is your current build, why fuc with it? Looks damn good to me.
    Nov 2007
    I found it easier to go on a diet!! Cheaper too!!
    Reputation: Joules's Avatar
    Quote Originally Posted by dhbomber
    if that build is too heavy, then yes. You are a weight weenie.
    Ti bolts are one of the most expensive ways to lighten a bike; $3-4/gram, even if you replaced every steel bolt, you wouldn't save enough to notice.
    A Ti spring might save you half a pound, or an air shock could save you more. An XX cassette is quite a bit lighter than XT 10s, but I'd never spend that much on a wear part. Masterpiece post, and I bet there's something lighter in the way of chain guides. Eggbreakers would save you somthing vs Time if you're ok with disposable pedals. And the tires you chose are pretty heavy.
    most of that are, IMO complete wastes of money. I don't think I'd do any of them except the tires.
    Reputation: kdiff's Avatar
    anywere?
    How much does that thing weigh right now, any clue? I have the SC equivalent, mines at about 28-29lbs with a '11 Talas and heavier wheels (CK hubs & Mavic 723 rims) and possibly some other heavier components. (Used a scale at the LBS.) So really your bike has to be fairly light.
    You could always review Shimano's site to see what XTR components would be lighter. (Assuming their weights are accurate.)
    I would be worried about the quality of the titanium bolts from ebay? Hopefully someone on here has tried them because I'm curious now.
    definitely switch to the red stickers. that'll help
    Nov 2006
    Quote Originally Posted by skithebert
    HAHAHA!!!
    The grey ones are 1g. less!
    Kidding...
    Well...I'm waiting for the parts to built the bike...so I have no weight...I figure it's gonna turn out at about 29lbs? Not that heavy if you consider that my build has some heavy duty (ish..) parts...
    I just posted this thread so trail riders...like you and me...could save some weight off our 27 to 30 lb bikes! not just MY bike.
    Ebay ti bolts have proven quite strong...my dad races XC and trains with the same bike that have them....not a single one has problems.
    XTR components would save a little...but at a very high cost....Cranks? a rather spend 150 bucks on the trusty XTs than burn some 400 clams to save 200g.
    My choice of tires...well...although a little heavy my kendas have proven very reliable and durable....I'm not gonna put some paper thin tires just to save some grams and be plagued with flats! Thats why I say...lose some weight...in a SMART way.
    Come on guys! Some weight saving tips!
    Reputation: Tillers_Rule's Avatar
    Sep 2004
    The XTR brakes are heavy, you can get some Formula R1's and save like 300 grams for the set.
    But I just got some XTR brakes as well, found a good deal online. Have yet to install them but they look great and if they hold up like everything else Shimano I'll be happy
    Reputation: charging_rhinos's Avatar
    Jump higher. Bikes feel lighter in the air.
    tangaroo: What electrolytes do chicken and turkey have again?
    rck18: All of them, because they're meat.
    Feb 2006
    What rear shock u running?
    Few ideas - 2ti Egg beaters, sunline stem, alligator rotors,
    Nov 2006
    Quote Originally Posted by Tillers_Rule
    Same as you! Got a pretty good deal on them!
    They seam pretty decent...weight wise...
    Formulas are nice too!
    Nov 2006
    Quote Originally Posted by pmaddy
    I'm in NO WAY running those egg beaters *****!
    They are like a nice set of Gouda Cheese pedals!
    I got a lighter Thomson stem...plan on putting some Ti bolts on it...
    I was thinking of Ashima rotors...they seem paper light, but I don´t know how durable they are...
    Oh and the shock is your standard RP23
    Nov 2006
    Quote Originally Posted by charging_rhinos
    For suuuuure I'm gonna be jumping this bike!
    Bikes should be about 20 pounds lighter in the air! HAHAHA
    Should have gotten an XC bike.
    Unrealistic expectations suck, don't they?
    From your build i would suggest If you leave your wallet out of your pocket that should save a tonne of weight.
    Sep 2004
    Yea I just weighed mine, 309 grams for the front, less than I expected.
    wuss
    Reputation: dropadrop's Avatar
    The correct way to lighten a Bike like that is to take a speadsheet and list all components. On another row put your current parts and their weights.
    Then search for lighter parts that are strong enough and add the weight saving and price. Once finished it should be easy to pick where you can save the most for the cheapest price.
    fool goin up, joker down
    Jan 2009
    Quote Originally Posted by dropadrop
    true that. if you already have a fairly light bike (which you do) then this is the most efficient way to lighten things up.
    Mamma speed I'm back!!!
    dude
    Reputation: joeyjoedotorg's Avatar
    The bike seems light enough. Time to work on the engine.
    if you're dying to waste money, you could alway just paypal it to me. between ti bolts and just giving me your money, you really wouldnt notice any difference in the way your bike rides
    - I believe the hadley aluminum through axle is lighter than the DT through axle. Not sure about exact figures but I'd bet 50g or so.
    - ESI chunky grips. save about 100g over your ODIs. Cheap, and they don't move around on the bar.
    - kmc x10sl chain.
    - sram XX cassette.
    - edge composites wide bar. Light, awesome.
    - formula the One brakes + rotors.
    - aluminum bolts for shifter(s). I'd stick with TI or steel bolts for brakes though.
    - look pedals? The first ones sucked but I hear the new ones are better. they are lighter than times. Times are the old reliable though.
    - some kind of wacky superlight cables and housing. I haven't done this but if you're pulling out all the stops...
    - then gain all that weight back with an adjustable seat post!
    Nov 2006
    Quote Originally Posted by Ansible
    - kmc x10sl chain.
    - sram XX cassette.
    -I like the skewer ratchet mech of the RWS
    -I like those ESI grips! Have them on my trail hardtail, but they are a PAIN to take em off!
    -I could get a KMC chain....or not
    -SRAM XX cassette? Dude, I'm waiting for the new Hope Integrated cassette! with a 9t!
    -Edge bars are super cool and chic, but the race face sixc's are wider!
    -I like my old Time pedals! I'm kinda skeptic on changing to some pedals I probably won't like.
    -The ebay Ti disc brake bolt kits are at a good price! Probably gonna buy some of those. Just for the calipers and rotors.
    -Superlight cables or housings? Like Nokon? Too expensive...
    -Adjustable seatpost? Naah I don't need one.
    Hahaha I'm NOT pulling all the stops! I'm no weight weenie! I just wanted to know some nice, not to expensive, and smart ways to save some weight on your all mountain bike!
    I don't even know how I'm gonna pay for the bike!
    But hey....I have an idea...let's pretend I have money to burn and I am a weight weenie all mountain bike rider and want to know how could you make your bike lighter while keeping it strong!
    This might come in handy to some!
    Thanks guys!
    that's an xc build in my opinion.
    so no... for actual jumping, over 4 foot drops and such that most consider part of "AM" riding... really nowhere to go.
    everyone's version of "AM" differs of course, but if you can't pound that light little thing around the forests it's not because the bike's weight is holding you back.
    if you're asking for weight dropping advice on a tracer with a xt/thomson/hope/chris king build?? you ARE a weight weenie.
    don't know how you've convinced yourself you're not.
    foll roll de ole troll
    If steel is real then aluminium is supercallafragiliniun!
    T.W.O.
    Reputation: mimi1885's Avatar
    That's a good built already, if anything get the adj seatpost, it would definitely bring out the personality of the Tracer more.
    Lot's of us been there, trying to build the lightest bike, at the end of the day Tracer is more AM than XC, forget putting it in the short mode unless you are racing. As soon as you throw your leg over the bike, you may change your mind and would give up a bit more weight for more fun
    You can go Nobby Nic 2.4 front and Rocket Ron 2.4 rear convert to tubeless and save about 1lb as long as you don't ride near sharp rocky terrain.
    Nov 2006
    Quote Originally Posted by byknuts
    A "real" (by today standards) All Mountain build would be a little bit overkill for were I ride (everyday)...In fact...I would be set with a 5" trail bike....but because how I ride...I like to jump, drop, and general goof aroundness, I went a little bit overboard and got this bike!
    I can't afford to be a true weight weener but fair enough...I'll leave my bike as it will be!
    ***JUST FOR THE FUN OF IT***
    Would Titanium spokes be completley ridiculous?
    GAME ON!
    listen, you've asked for reasonable ways to reduce weight. several options have been given and you've basically said no. several people have said ti bolts won't help you overall and that's the only option you've mentioned in almost every post. here's my suggestion: buy the ti bolts and keep your build as it is because that's what it appears you will be doing anyway.
    you should post this in the weight weenie section.. you're going into splitting-hairs component weights.
    Bicyclochondriac.
    Any other ways?
    -Go tubeless
    -Etc.??
    I have this....
    Wheels:
    Hubs:
    Tires:
    Thoughts?
    Build some wheels with Enve (Edge) Composite rims.
    $1600 bucks for 180 grams saved.. ouch.
    Nov 2006
    Quote Originally Posted by One Pivot
    Exactly!
    Jeez I'll leave the build as it is then!
    The White Jeff W
    Reputation: jeffw-13's Avatar
    Easiest place I see to save weight would be the tires. The lightest 2.35 Nevegals run 700+ grams. Check out the 2.4 Continental Mountain King Supersonic at 530 grams.
    No moss...
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    You are now officially a weight weenie...visit their forum - after you purchase a gram scale!
    "Just because I drive a Porsche... doesn't make me Pete Fagerlin"
    Bicyclochondriac.
    Exactly!
    Yeah, if you want stupid light it's gonna be stupid expensive. To be fair, though, it is 180g rotating weight (that's like 8 pounds off the rest of your bike ).
    I would not do it, but I've also never found myself looking at titanium bolt kits.
    El Gato Malo
    Reputation: Wishful Tomcat's Avatar
    This thread should be renamed as "Best way to lighten your wallet?"
    Quote Originally Posted by Trail6
    Awesome!
    Nov 2006
    Quote Originally Posted by Zachariah
    Hahaha you don't get it! I'm no Weight Weenie! Like I said...I'm not gonna blow my money on Ti bolts, or stupid 1gram carbon fiber chainrings, or whatever things Weight weenies do to get their lightness fix!
    Dude I ride a 30 lb. hardtail...I'm NO weight weener
    T.W.O.
    What are you then? How much weight do you plan to cut out of that list, let us know so we can help. A lot of people gave great tips, but it's going nowhere with you.
    You can change the tires and save about 1lb for less than $100, other than that it would be $1000-1500 each additional pound. And if you go down that route my boy, you are a weight weenie.
    Aug 2010
    To be the perfect weight wiener you need lighter tires, ti bolts, spokes, spring, an one arm fork
    2011 transition 250
    2009 DB scapegoat
    Reputation: Dr.Zoidberg's Avatar
    R1 brakes and Conti Montain Kings or Supersonics (depending on your terrain), both of which have already been mentioned. You can also go lighter than Flows; Arch (depending on terrain) or Havens will save you even more. Saddle is pure personal preference.
    Another way to waste money is to swap the fork and shock for carbon DT Swiss equivalents.
    Nov 2006
    I already have one of my kidneys and a little piece of my liver on sale!
    I found some Ti bolts in my old man's tool box! shh don't tell!
    Probably those will fit my stem and some other bolt here and there....
    I know I'm not noticing any of those lost grams...I'm not a weight weenie! I'm just putting them on there just for the "bling" factor...if any..hahaha
    I'm doing my tire research...It's probably smarter (as you guys tell me) to bump down some rolling weight...instead of stupid little jewelry thats just gonna burn a hole in my almost empty wallet! Dang!
    thanks guys!
    Nov 2006
    thanks guys!
    Keep us posted on what you do with tires...
    GAME ON!
    Quote Originally Posted by Dr.Zoidberg
    the carbon dt swiss stuff isn't really any lighter. ultimately (based on claimed weights for both), the revelation world cup is considerably lighter. i think stiffness was the goal over weight. the rear shock is pretty much the same as any other comparable shock. more money for no gain.
    you could switch a 2.35 nevegal for an even heavier tire and your bike would feel faster. nevs feel like you're pedaling through mud, always.
    Nov 2006
    I've NEVER had any problems with nevegals! they are great! but they do roll slow!
    Thats why I'm trying out some different tire! I can get Kendas for a very good price, so I'm probably experimenting with them first. the new slant six should be good! Nice and light! going tubeless...without UST...just stans...see how that goes
    fnar fnar brrraaaaap
    Reputation: ilostmypassword's Avatar
    Take a photo. Blow it up and mount on card. Run around the trail making bike noise. Light as!
    Just attack it randomly with a Drill, a sander and a angle grinder you'll knock 1lb of it easy.
    Reputation: monty797's Avatar
    At the end of the day you need to look at what you want out of that bike. 25lbs or 27lbs it'll not make a bit of difference at the end of the day.
    I've honestly stopped weighing my bikes and could care less, realistically it's a number on a spread sheet. At the point where your bike is currently you are going to have to drop significant coin to get to that goal and you are really going to have to look at your weight to strength gains at point as well.
    Quote Originally Posted by monty797
    At a certain point buying a new lighter bike provides more value.
