Results 1 to 59 of 59
    Reputation: Helmetless's Avatar
    Best Maxxis (Front) Tire for AM
    Hey guys,
    After having tons of "issues" with Kendas I want to buy a couple Maxxis for more thorny trails such as today's trail. I've found myself 3 or 4 times a day patching tubes because of a thorn attached in my Nevegals, Excavators, Small Blocks, Mocos, etc. Very thin sidewalls, I am afraid. My friends use Maxxis and they never have any problems with them so I'm kinda dissapointed about these tires.
    Trying to use the same configuration I have with Kendas, my decision for the rear tire is the Ranchero, which works quite well on the trails I ride (part dry, part dusty, part rocky).
    WHAT WOULD BE THE PERFECT MAXXIS FOR THE FRONT? (BTW IN 2.35 PLEASE)
    Thanks much!
    Minions
    Quote Originally Posted by Helmetless
    Hey guys,
    Thanks much!
    Maxxis are nice tires but they not going to block thorns, best thing to do is go UST or convert to tubeless for thorns. Also maxxis can be narrow, step up to 2.5 single ply exo minions.
    Thanks Ratt, I am afraid I couldn't correct my thread before you've posted. I know that tubeless is a choice but I want the normal stuff. My partners are using 2.1 folding bead Maxxis with inner tubes and never have issues so makes me wonder if I'm a bad luck man or I am just a Kenda owner.
    So you say a Minion up front. But 2.35 maybe is too narrow. No worries, my wheels are completely XC, 24mm wide. I think 2.5 is too much for me, even if is a Maxxis
    ran an ardent front with tubes...works great
    I currently run an Ardent 2.4 up front, great tire. The only thing is you have to commit and lean it in turns. There's a sketchy zone in the tread before the knobs on the edge catch but once they take over no worries.
    A minion or high roller 2.35 is almost same sized as a Kenda Nevegal 2.1. Ardent, Crossmarks and etc is the newer high volume tires from Maxxis.
    The place where I usually rides, don't have much torns and sharp rocks though, but I just changed to a Minion 2.35 for the front and Crossmark 2.1 for the rear. This is really a fast combo compared to my previous Nevegal 2.1 front and Hutchinson Scorpion rear.
    Haven't have the chance to test it out on the trail though.
    Quote Originally Posted by dumbaSS
    Hmmm... thanks! but at first glance it looks like a pretty tricky tire for a newbie. Note that I'm coming from a 2.35 Nevegal tire up front so I need a similar one, confident and not necessarily great for just one thing but good for everything. What would be more in the comfortable side while descending with no comprimise in climbing? (I know I'm picky and trying to have everything in just one tire). Just wondering how Advantages and High Rollers go as compared to the Minions
    meow meow
    Reputation: b-kul's Avatar
    tricky tire? never heard that before. does it have to be maxxis? what about panaracer or conti? persoanally im loving the rampages right now.
    Reputation: 2clue's Avatar
    Are you riding in the middle of the trail? Maybe its just that your friends are riding center on the trail and you like to veer off to the sides? Also it could be that you are riding in front and cleaning up the trail for them. If a thorn can take out a kenda it can take out a maxxis...and a conti..and a panaracer..and what ever with rubber.
    Quote Originally Posted by b-kul
    That's because English isn't my native language. But I think you got the idea.
    Quote Originally Posted by 2clue
    I think you're right.
    I mean, I'm not cleaning up the trail to my friends but I like to take advantage of rocks that I often use as ramps and playing a little on corners - whereas my friends are doing simple xc riding right in the middle of the track. But I've never had flats while doing that.
    Never had issues before with my Maxxis (just the normal) and have read lots of complaints about Kendas - most of them are about flats. Despite those commentaries, my own experience says that there's a difference between these two brands.
    meow meow
    wasnt a dig at your english but i honestly dont get it. are you refering to the fact that you need to lean the ardent hard or else it has a sketchy zone?
    A maxxis 2.5 highroller or a 2.4 Advantage
    To lean the ardent hard may require the rider to change his body position to put weight up front. Am I right?
    Quote Originally Posted by dogo
    Yep I think I'll go for the AD option
    think
    Roll of stans tape, some sealant, and whatever tires you like. They don't have to be UST.
    Try to stay out of the thorns at the side of the trail, like someone mentioned.
    I have Ardents on one bike (2.4 front 2.25 rear) and 2.35 minions on another (DHF/DHR). The Minions have less volume but they rip. The more aggressive knob profiles give more cornering traction I think. The Ardents are a good tire but the 2.4 are both large and fairly heavy. If you run a 2.4 in the rear make sure you have sufficient frame clearance.
    If you don't mind running pizza cutters the 2.35 minions might be my favorites.
    Reputation: G-AIR's Avatar
    2.35 High Roller
    I think you want the 2.35 High Roller. It is very predictable, works in the front or back, and works in a lot of conditions. The 2.35 has plenty of width for AM riding. If your friends are riding 2.1s the 2.35s will be plenty.
    The 2.35 DHF is another great option. I currently run the DHF front and HR in the rear. I really like this set up. Like you, I used to run the 2.35 Kends Nevs. I liked the tires but had problems with pinch flats and it rolls like poo. Go for the High Roller and you won't look back.
    Stay away from the Ignitors.
    Good Luck.
    TG
    Quote Originally Posted by bad news
    BN,
    How does the volume and size of the 2.25 Ardent compare to the 2.35 DHF? I am thinking of running the 2.25 Ardents on my HT.
    Thanks for an y info.
    TG
    I'm more of a dog person
    Reputation: unclekittykiller's Avatar
    Feb 2006
    2.4 ADV is an enormous tire. great grip but just too big. bigger than my minion 2.5 dhr.
    +1 for the Ardent. 2.25 Ardent on a 28mm wide rim hits the sweet spot for me.
    Maaaaan
    Reputation: Ericmopar's Avatar
    Aug 2003
    I've used the 2.4 Advantage, the 2.25 Advantage and Ardent, and currently the 2.5 Minion DHF EXO with the 60 maxpro.
    In dryer terrain at least, I think the 2.5 single ply EXO Minion DHF is the way to go. It's a fat tire, but not much bigger than a 2.35 Nevegal.
    Maxxis also makes a single ply 60mp DHF in 2.35, if your fork arch has tight clearance issues.
    They aren't puncture proof, but they are better at preventing flats than Kenda and Continentals I've tried.
    Use with a 2.35 Minion DHR folding, 60mp on the rear. Great Combo.
    Communist Party Member Since 1917.
    Quote Originally Posted by Ericmopar
    How's the 2.25 Advantage? Simple curiosity as I used the 2.1 AD in the past (XC ride). Still undecided because I don't see a winner tire , everyone has his favorite (which is cool! btw)
    DGB
    DGB is offline
    If you're looking for something that is a similar size to a 2.35 Nevegal, that will fall somewhere between a 2.25 and 2.4 ADvantage. Be careful though, as was said above, the 2.4 ADvantage is huge! It's a very tall tyre and you'll struggle to fit it in most XC fork crowns (I had trouble fitting one in a RS Revelation crown when mounted on DT XR400 rims). The 2.4 is also a heavy tyre and, IMO, isn't as good at cornering as a smaller 2.35 Minion DHF.
    I run a 2.25 ADvantage on the rear of my HT (I don't like the ADvantage up front) and it's similar in size to 2.35 Minion/High Roller/Swampthing (all older Maxxis tyres are small in comparison to their newer tyres - ADv/Ardent).
    For the conditions you mentioned above (dry, dusty, rocky), I'd go with a Minion DHF 2.35 Single-Ply 60a folding.
    smartass
    Reputation: amish_matt's Avatar
    For reference, the ADvantage 2.25 is more or less the same size as the Highroller 2.35.
    For me, the ADvantage 2.4 is way to big. As others have said, it's huge. I've used it, and much prefer the 2.25 size.
    I run an ADvantage 2.25 front and Ardent 2.25 rear and really like that setup. Previously a Crossmark 2.25 rear. Using the Ardent now only because of the EXO sidewall, the Crossmark was great otherwise, but the sidewalls never lasted as long as the tread.
    Reputation: charging_rhinos's Avatar
    I really like my ghetto tubeless setup with Minion DHF Exo 2.5s front and rear.
    Don't be afraid of a 2.5 Minion. It's not too wide. Like others have said, the Minions run much smaller than its size says. It is about the exact same size as my old 2.35 Nevegal, for reference. I measured them with calipers to be sure. The 2.35 Minion would be very narrow indeed, so I stayed away from it. But I have to say, they grip incredibly well, and even though they have taller tread than my old Nevegals, they do roll a little better. Yes, they feel a bit different than Kendas, and that's going to be the same experience whenever you switch brands. But now that I know the tires well and can predict their behavior, they're the best set I have ever ridden.
    HIGHLY recommend getting the Minion DHF 2.5 Exo single ply in 60a hardness.
    tangaroo: What electrolytes do chicken and turkey have again?
    rck18: All of them, because they're meat.
    Slime Tubes
    Saw someone mention tubeless (and I'd have to agree), but it sounds like the guy doesn't want to go that route--so I wonder why no one has mentioned Slime tubes? Before I went tubeless, I rode many Kendas (Nevs, BG's, SB8's, etc.) & Maxxis' (Xmarks, High & Holy Roller, Minions, etc.), and they all had flats at about the same rate with regular tubes. If you want to keep using tubes, the Slime will help on any brand/tire; as long as it is indeed thorns & you're not pinch flatting.
    think
    Quote Originally Posted by G-AIR
    BN,
    TG
    I would say the 2.25 Ardent is at least as big and probably a touch larger. Although the knobs are not as tall the casing is definitely larger and higher volume.
    I am pretty happy with the Ardent, but I'm not sure I see any real advantage to it over the Minion. The Minions rip.
    Reputation: nixgame22's Avatar
    I've been running a 2.35 Ignitor on the front over the summer and love it. Pedal Pushers in Golden CO suggested that, and an Advantage on the rear for typical Front Range trails.
    Maintain internal heights.
    The Unaffiliated
    I am running the Specialized Purgatory, ghetto tubeless. I'm on my second tire and I have NEVER flatted and I mostly ride in the Chihuahua desert (cactus, goatheads, and all sorts of sharp plants and rocks).
    I have had lots of holes in ME, but my tires have held up.
    Quote Originally Posted by Philius413
    Rather than Slime, I'd recommend filling some tubes up with a few ounces of Stans No-Flat sealant. Slime does work to a degree, but I've had FAR better results with Stan's. It doesn't throw tires off balance as much as the thicker slime does, and it flows into and stops leaks faster. That's the sealant of choice for tubeless conversion-type people like myself that were just too cheap to go out and buy tubeless rims. The only issue is that no sealant is a permanent fix. They will eventually leak out, even if slime or stan's latex plugs the hole. But it might get you through the rest of your ride... or possibly just get you farther away from your car
    There are other options too, like Panaracer Flat Away kevlar tire liners. Definitely go for the kevlar if you look for liners though. The cheap Mr Tuffy plastic ones weigh a ton and don't work. Some people have had good luck with them, and others not. All depends on the thorns you're hitting, I guess
    I still think the thread starter ought to at least consider the ghetto tubeless option though. It works on almost any regular tube rim and tire setup, has a super good flat sealant in it in case it does puncture, and it eliminates the worry of pinch-flatting altogether. I was really nervous about trying it, but now that I've done it with my beloved Minions, I'll never go back to tubes again. A whole season without a single flat!!
    meow meow
    Quote Originally Posted by charging_rhinos
    im really intrested in the gorilla ghetto tubless (did you do this) but im not sure if it will work with non ust tires. any comments?
    The Minions rip.
    Sorry, but what do you mean with rip? I only know two meanings of it: rest in peace (lol), or to copy stuff.
    Rabid Lana fan
    RIP: see "SHRED"
    "Man, did you see Peaty? He was rippin' the downhill!"
    "Man, did you see Peaty? He was shreddin' the downhill!"
    rOCktoberfest 2015 pt I here
    rOCktoberfest 2015 pt II here
    Quote Originally Posted by net wurker
    RIP: see "SHRED"
    Thank you Net Wurker! All sorted out. So, the Maxxis Minion is a great tire despite its width
    I didn't use Gorilla tape. Ive heard from some people that the chemicals in the Stan's will slowly dissolve the adhesive of most tapes. I did the 20" bmx tube method, and it's rock solid. I've got non-ust Minions on non-ust WTB Laserdisc rims. The seal is excellent, and no worries about the tape ever crapping out. Only caveat is that the first fill-up needs an air compressor to rapidly puff the tire onto the bead. I just walked to the corner gas station for that. Then a regular bike pump to get to the correct pressure.
    Here's a link to exactly what I did:
    <object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/WRM7gq1fcoQ?fs=1&amp;hl=en_US"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/WRM7gq1fcoQ?fs=1&amp;hl=en_US" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
    Rabid Lana fan
    I've been running Minion 2.5 DHF 3c EXO front, and Minion 2.5 DHF 60a EXO rear, and love that combo!
    Running them ghetto tubeless with the yellow tape.
    Although, I have one of the new UST Ardents in 2.25 I'm going to try on the rear. I ran an Ardent before on the rear, and loved it , except for the weak sidewalls. I am hoping the UST version will have beefier sidealls...lots of sharp rocks on our local trails.
    Reputation: I.V.A.'s Avatar
    Feb 2007
    Maxxis catalog. With all dimensions. Just to take the guessing out of the equation. 2.5 and 2.4 is a no no. For part dry, part dusty, part rocky, Minion DHF 2.35 front and Crossmark 2.25 rear. I'm running HR Semi Slick/Larsen TT combo for dry and HR/HR for part wet, part muddy, part boggy. All on Mavic XM719.
    Quote Originally Posted by I.V.A.
    Wonderful add!!!
    This is the ride so you can better figure out what tires it needs
    Attached Thumbnails Attached Thumbnails Best Maxxis (Front) Tire for AM-completa2.jpg
    think
    Yes, it's very good. The 2.35 with 60a compound has plenty of grip, but more importantly the grip is controllable and predictable.
    Maaaaan
    Aug 2003
    It's tread pattern is better suited to the rear. I find that kind of ironic, since it's sidewalls are to thin for rear use in rocky terrain.
    For years I was told to use a DHF on the rear, then I tried the DHR and was stoked. I heard it was really slow rolling blah, blah, blah.
    The DHF front and the DHR rear is a killer combo.
    Someone was saying that the 2.25 and 2.35 tires are almost the same size. That didn't used to be true with Maxxis, but they seem to have re-sized some of the older tires with newer casings.
    The 2.4 Advantage is huge. It's larger than a 2.5 Minion. The Minion 2.5 is larger than a 2.25 Advantage or Ardent however. It's really confusing!!!
    Because of this, I've started using the metric numbers on the sidewall when I can find them. For some reason, the metric measurements are really close, even between different brands of tire.
    A very good & informative site for MTB tires by Shiggy (http://mtbtires.com/site2/)
    I recently got myself a Minion 2.35 with Crossmark 2.1 combo. The measurements are spot on from the site!
    Quote Originally Posted by Kaizer
    Why the link you sent to me directs me to Kendas... ironic eh?
    Well, after a bit of research based on your comments I've decided that the 2.35 Minion is the right choice. I do have a Maxxis Advantage in 2.1 and will use that little one for the rear wheel until I could get a better tire. Now I need to find the folding bead version of the Minion, which is not that easy as wire bead Minions are the usual
    Reputation: nagatahawk's Avatar
    i tried an Maxxis high roller 2.5 not good. felt like the brakes were on all the time.
    Heard good things about the ardent.
    currently I use a WTB Weirfolf 2.3 great tire for dry packed with loose. carves super good.
    on burms and flats. good in dry, wet rocks and roots. Not good in mud. lugs are to small.
    DGB
    DGB is offline
    If you have no luck in finding it locally, you can get it from CRC
    Quote Originally Posted by DGB
    Thx!
    LOL... truely ironic!
    I know I said Maxxis only, but what about the Chunder SX in 2.3?
    Check this out:
    http://bb.nsmb.com/showthread.php?t=131111&page=3
    Maaaaan
    Aug 2003
    I got my folding Minions from either Pricepoint or Jenson USA.
    fan of maple syrup
    Reputation: nuclear_powered's Avatar
    Thread Hijack!
    Are all the 2.5 Minions wire bead?
    The ExoProtection version here at CRC seems to indicate it's a 'high volume' tyre - whereas all mention of Minions above seems to be refer to it as an 'old Maxxis' that's about as big as newer 2.4 Maxxis tyres. Is it just this ExoProtection one that's 'new/high volume'?
    Finally, anyone recommend Fat Alberts more than/less than Minions? Haven't seen any mention here so far and it seems to be the only other DH-esque tyre with a specific front/back tread.
    Quote Originally Posted by nuclear_powered
    Thread Hijack!
    sorry I didn't see the other one.
    Reputation: bholwell's Avatar
    Oct 2007
    Thread Hijack!
    The Exo-Protection Minion DHF 2.5 has a folding aramid bead. Available in a single 60a compound or 3C. The size is the same as the DH 26x2.5 version- it measures roughly 2.4" across the tread.
    Tire Design & Development Engineer. The opinions expressed in this forum are solely my own.
    just along for the ride
    Reputation: Brown_Teeth's Avatar
    Thread Hijack!
    I've run FA and minions as well as advantage, all fine tires but my favorite front is still the single ply 2.35 DTC Kenda blue groove as a front, close second is the minnions or 2.25 / 2.4 Advantage. The FA is an ultra grippy tire but has nasty braking habits as you approach lock up they will literally throw you sideways at times, not drift but freaking try to buck you off. Its due to the tall narrow knobbies folding, do not lock them up on pavement of you will shear knobbies at an alarming rate!. But if you want all grip all the time the FA are fine tires, well built and durable (I run the enduro model, better sidewalls).
    fan of maple syrup
    Thanks for the tips. I can't believe how many different flavours of Minion there are. Just when I'd finished checking out the several on CRC, I get a Wiggle email saying they're having a 20% off all tyres sale for 24hrs. There are Minions in there for A$25.
    And I find another one which - may be the same as some of the CRC ones but they just list them differently on Wiggle, but this one (link) is just listed as Minion DHR 2.5 folding. Doesn't mention number of ply levels or 'protection ability', but has the usual compound choices. And there's no matching DHF.
    Man ... too many Minion choices.
    Are you running the folding bead Minions tubeless?
    I need new tires for my AM rig. Ive currently got folding bead 2.35 Nevegals on there. I ve had them for a while and dont ride my AM bike all that often, so Im starting to see the Stans making small wet spots in a spiral pattern along the entire sidewall, so Im guessing the tires are getting tired of being run tubeless. Oh, well I want new tires anyway.
    So, Im thinking 2.35 Minions, folding bead, with the 3C in the rear and running them tubeless. I have 2.5 MInions on my DH bike, and I really like them. So, Im sure Ill like them on my AM bike for the DH, but Im just not sure about their climbing ability, and how long they will last. Was also looking at the UST High Rollers.
    Im still undecided, as you can probably tell
    Unfortunately no 3C minions in 2.35 size, only 2.5.
    Reputation: wfoacman's Avatar
    I'm mounting a pair of Minion 2.5 EXO 3c's on some Flows tonight. They look like they are running small like many of the Maxxis tires. The 2.5's look more like 2.3 or 2.35. I don't have them mounted yet, but just looking at them they seem like they are smaller than many other brands 2.5 tires.
    I walk the line
    Reputation: BluKoolaide's Avatar
    Dec 2010
    I haven't tried the new 2.5 Exo tubeless, but a 2.35 in SuperTacky (wire bead is the only way it comes) works really well on tubeless rims with some Stan's. They seat tighter than some UST tires, which is a good thing!
    I just mounted up the 2.5 EXO 3C's to my Flow rims with just the yellow tape and some Stan's. The tires went on easy with no levers needed. I couldn't get them pumed up with a floor pump, but with a compressor they aired up no problem and even made some popping noises like with a UST rim and tire. Hardly any Stan's came out from the rim tire interface, just a couple areas on both sides and then I rinsed it off and that was it.
    As for the actual size. The 2.5 EXO 3C with 40 PSI was 2.325 inches with digital calipers. So even if the tires stretch out a bit with a little riding time, I don't see them being anymore than a 2.35 inch tire.
    I agree about ditching the nevegals for maxxis.
    I ran ADvantages 2.4/2.25 last year and they were awesome...until the rear sidewall tore on root. Put on a Minion 2.35f on the rear and then switched to Minion on the front and Ignitor 2.1 on the rear. Both set ups were Stans tubeless.
    While it was lighter, i didn't like how sketchy the rear became with the ignitor. I am going to try Minions on front and rear next season and i think that will be a bomb proof combo.
    The one other thing I like about the maxxis were how easy they were to convert to tubeless and mount, compared to the nevegals. ADv, Minions and ignitors all mounted first time with a compressor and sealed almost immediately. The Kendas, not so much.
    Quote Originally Posted by BluKoolaide
    I'm running the 2.5 Exo ghetto tubeless on some Performance Xenduro wheels. Sealed up great and hold air just fine.
