Results 1 to 71 of 71
    Reputation: BaeckerX1's Avatar
    Oct 2007
    The Anti-Weight Weenie Thread: Adding Weight to Your Bike
    With almost everyone constantly doing everything to drop weight in search of the lightest bike possible, I'm curious to know how many of you have added weight to your bike in order to make it more capable. I figured it would be fun to talk about the opposite end of the spectrum for once.
    I took my Pivot Mach 5.7 from 28 lbs to around 30.3 lbs. I definitely worry about my bike less on very technical trails now. Here's what I thought were worthwhile weight additions.
    -Specialized Command Post BlackLite to get that seat out of the way on steep technical sections and drops
    -Beefy, High Volume tubeless tires at 800+ grams each for better grip and more protection through rocky terrain
    -203mm rotor front, 180mm rotor rear for the long descents, really steep trails, or just those oh sh*t moments
    -725mm bar cause narrow ones just don't cut it.
    What are some of your worthwhile weight additions?
    Gotta get up to get down.
    LMB
    I would probably just gain more weight since it is so much fun eatting. I had a friend that says that losing weight is cheaper than thousands of dollars spent on lighter equipment.
    Reputation: V.P.'s Avatar
    Sure, adjustable seatpost, wider bar, stronger wheelset.
    www.derbyrims.com
    Reputation: derby's Avatar
    Coil fork and shock adds a 1.5 lbs (ti) to 2.5 lbs (steel).
    AM cranks such as Saint or Afterburner or Hammershmit
    Chain guide
    Remote drop post
    wide rims and tires
    i felt this way for awhile, but now lately i've taken up with a group of guys that ride technical, tough trails but with hardtail 29ers. And while I love my Enduro, on these group rides i'm getting my ass kicked, and it's rough on the ego. Much of it is probably that they are better all round riders, but man, I must have 10/12 pounds more bike. It's so true - you just need more than one bike
    Reputation: tk1971's Avatar
    Went from a QR fork to a 6 pound (and change) Marz 55R with 20mm through axle. Add a cheap 20mm front wheel for even more weight. A few months later, when the 55R Suntour cartridge crapped out, I converted it to an open bath (more oil). Now, my 39 pound Reign is really, really, really front heavy.
    I've seen guys on 20+ year old rusty Schwins pass me both going up and down various trails and fireroads. I figure riding a heavy bike will help get me there.
    Mar 2006
    When I had my wheels built, I was all-too-easily talked into shiny golden alloy nipples. In the last month I've shorn four of those. Had my wheel rebuilt yesterday with brass, as it should be. Alloy nipples don't belong on mountain bikes.
    Founder: Dirty3hirties
    Reputation: ddraewwg's Avatar
    If possible, coilover fork and shock (dunno if Pivot allows a coil shock or even if it's possible).
    greedy
    Reputation: have2ride2day's Avatar
    Went from 685mm carbon bars to 760mm aluminum. From 2.2 tires to 2.4. Adjustable seatpost.
    My riding partner has a Mojo that is down to 25 lbs. He's always joking that everytime he drops a pound, I add one. Sad thing is, I spend as much money adding weight as he does dropping it.
    Edit: I also put two FULL scoops of Stans in each tire. If I wanted to have to worry with flats, I wouldn't have gone tubeless.
    Addicted to the Classifieds
    Reputation: hardboiled's Avatar
    I don't think I've ever made a change to my bike that resulted in lower weight, I tend to build up a bike cautiously optimistic with parts from the lighter side of the spectrum and gradually add weight over time. the usual spots are tires and suspension. I'm currently contemplating/struggling to resist putting my Lyrik solo air DH back on my trailbike which currently has a 150mm Revelation. trying to tell myself the extra 10mm of travel and marginal stiffness gain is not worth the extra 1+ pounds. I also have a dropper post in the closet that will probably work its way back on the bike although for my riding (big ups followed by big downs) I'm less convinced of the value of a dropper.
    I don't think adding weight to your bike makes you an "anti weight weenie" unless you are adding stupidly heavy parts for the kind of riding you do. I try to run the lightest parts that will hold up to the abuse I dish out and give me the performance that I'm looking for. I think of myself as "weight conscious" more than a weight weenie though.
    meow meow
    Reputation: b-kul's Avatar
    Quote Originally Posted by BaeckerX1 View Post
    how does that compare to a reverb? thinking of picking one up especially now that i ride a spec
    Oct 2007
    Quote Originally Posted by b-kul View Post
    Not as smooth or easy to operate as the Reverb, but it works well enough. The mid position is hard to find at times. The thing I like about it is in most cases when it fails it should still be usable. You should be able to pull it up to the top position and lock it since it uses a locking collet to lock it in place. The Reverb would just sink when it fails, leaving you to do a lot of standing pedaling. The Reverb wouldn't fit on this frame so I'm using the Speshy one. It's probably my "second-best" option, but probably the best option for back country/high country rides where I'd be worried about the Reverb failing.
    LMB
    Oct 2007
    Quote Originally Posted by have2ride2day View Post
    I also add extra Stan's for piece of mind.
    LMB
    Reputation: YamiRider1316's Avatar
    Mar 2011
    in the process of adding a hammerschmidt which is probably gonna pork up my already tank of a mission
    My second hand stock Whyte E4 so far is upto 28lb's :-
    More comfortable seat
    2.4 RR compared to a 2.1 Vapour Pro.
    2.3 Spesh Eskar front tire rather than another 2.1 Vapour Pro.
    The biggest difference I noticed was fitting a 180mm cheaper rotor on the front, the WW Hope rotor over heated like crazy, but doesn't fade on long descents so who cares.
    I expect stronger spokes and rims back and front soon
    I went the other way My previous bikes were: bullit, heckler, 575 & blur LT. They were between 35 to 30lbs. I thought this is what I needed to go down hill fast in my area. My current bike is Mojo SL @ 25lbs and it goes down hill just as fast or faster in many section, but it climbs way better than any of my previous bikes
    Trail Rider
    Reputation: mlx john's Avatar
    Remedy 9 stock was just over 29 pounds.
    Ditched the bontrager tires, went tubeless w/ 2.1 Nevegal rear/2.35 front w/ 2 scoops
    Race Face Atlas AM bar 28.5"
    KS Supernatural adj. seatpost.
    sitting @ 30.5 pounds and the bike rides so much better.
    Trek Fuel EX 9.8
    biking is fun
    Reputation: climbingbubba's Avatar
    Quote Originally Posted by half_man_half_scab View Post
    Probably a bad wheel build to begin with then, more than likely over tensioned. I have been running alloy nipples on every wheel build for the last 5 years with zero issues whatsoever. I use them on anything from my XC to DH bike. Do nasty rocky descents, hit up to 25 foot gaps and 15 foot drops. Haven't even broke one yet.
    As for gaining weight, The best place for improved stability is also the worst place for pedaling uphill, the wheels.
    For me, I can no longer run anything less than a fox 36 or lyrik. My bikes are build to ride XC but be able to hit any drop or gap that is on the way down. so I will gladly add weight for more security. Also coil rear shocks are always a huge improvement.
    Typically I like my AM bikes in the 30-33 lb range.
    And lastly, I don't buy into the whole just lose/gain weight instead of taking it off or adding it to your bike. I think it would actually have an opposite effect. For instance gaining a ton of weight on a light bike would make the bike even more squirelly and easier to break the bike. Adding a ton of weight high up (you) will make your center of gravity higher. In the reverse, if you are really lightweight and your bike weighs a ton it will be hard for you to control and maneuver. No one can tell me that losing 2 lbs of fat will equal losing 2 lbs of rotational mass from your tires or wheelset. Generally when you are trying to lose weight off your bike, losing iweight from the wheels or high up like the saddle, post, handle bars, etc is the most beneficial.
    Reputation: 53119's Avatar
    Nov 2008
    08 Tr. Covert
    xfusion vengeance hlr
    steel coil ccdb
    Tr. Revolution 32s
    SLX drivetrain
    32lbish figure
    she's never been on weightwatchers so she rolls deep!
    Some of the things mentioned in this thread aren't really anti weight weenie. They're just items you bought to make the bike fit you better, or items that set the bike up properly for the terrain you are riding. Having bars that are wide enough for your preferences/body size, an adjustable seatpost, and chain guides are not anti-weenie items. However, I'll play along.
    I use heavy ODI end plugs in case I seppuku myself with the handlebars.
    http://www.bikepartsplace.com/images/med/31865169.jpg
    I use four scoops of sealant per tire. I could get away with less, but unless I'm racing, I'd rather have enough in the tire to seal anything I feel like running over.
    I use rotors with aluminum carriers because for me, they stay true longer. This makes it easier to center my brakes and not have any rub. I also prefer rotors that have brake paths with less cutouts. Keeps my pads alive longer. These things translate to a heavy rotor.
    Oct 2007
    Quote Originally Posted by Kyle2834 View Post
    It's just a fun thread. Don't over-analyze it. The title just got people to open it and read it is all. Besides, it's about increasing weight to better your ride instead of reducing weight. So, yes, anti-weight weenie. Weight Weenies often make sacrifices in durability and ride quality just to decrease weight.
    LMB
    I like the idea of the thread, I just didn't want to see a million people talk about what handlebars they use. I mean no offense to those that already said handlebars.
    Well, I think a distinction needs to be made here, since many of those making sacrifices in durability and ride quality do so for the purpose of a race bike.
    Oct 2007
    True, I know what you mean. Handlebars often don't make that much difference in weight really, but it all adds up. I know tires made a huge difference with increasing weight for me (my rear tire is over 1.8 pounds by itself), but it was very much worth it for the increased rock protection, grip, and cush. I could run lighter tires with less tread, but I think it would hurt my riding rather than help it. Maybe if I didn't live in Colorado I could get away with a less beefy tire. I used to be obsessed with having my bike below 30 pounds, but almost everything I did or looked to do to reduce weight resulted in decreased capability or too high a cost for no real performance gains. Now I'm quite content with my bike at 30.3. It's just a number on a scale.
    LMB
    Oct 2007
    Heh. Not all. For some it's about status and having the lightest bike possible. Have you seen the weight weenie forum? Plus the marketing inundates us all. Anytime you pick up a bike magazine or read a bike website it's about how lightweight and great a frame or component is. I know it's easy to succumb to the weight weenie demons, but I also know my bike seems to perform better through rock gardens and such with a little junk in her trunk.
    LMB
    Good thread man! I added weight in all the ways you did and more. An MRP chain guide, SLX boat anchor rear deraillure. $40 bucks couldn't pass it up. Nevegal 2.5 single casing tires. I like straight wheels so I just built a rear wheel with lazerdisk DH rim. Just added a heavier shock. Monarch rc3. Next season the totem gets a coil instead of air. I'm roughly at 35 lbs.
    Aug 2005
    I have a 06 specialized enduro and i know i could have it around thirty pounds or a little less but instead i added parts to make it super burly... put on a hadley/823 wheelset with 2.5 minions which is bombproof and an old 05 marz z150 which i absolutely love. I also replaced the dhx air for a RS vivid coil. Everything else is pretty normal but just those few parts add plenty of lbs and are very confidence inspiring!
    Attached Thumbnails Attached Thumbnails The Anti-Weight Weenie Thread: Adding Weight to Your Bike-315.jpg
    Reputation: jtnord's Avatar
    Jun 2010
    My do all (mainly XC) is a Bullit @ 37lbs. I am considering going from solo air totem to coil totem and 2.5 minions to 2.7 minions. I would put a dropper post on if I wasn't rather cramped with a setback post.
    6'5" 230lbs
    My Build: Vitalmtb - Bike Check
    Mar 2006
    I always try to remove some weight from one area if I'm going to add weight in another. Areas I can't escape weight are on the wheels and tyres and rear coil shock. I never cared much for light weight till I bought a carbon hardtail in addition to my duallie and my outlook has done a 180 - weight really matters.
    Oct 2007
    Quote Originally Posted by gravityfreaky View Post
    I think it does to an extent. I wouldn't want to push a 40 lb bike up the Front Range climbs, but I think anywhere close to 30 lbs is pretty good for a do-it-all bike, and a bit heavier if you're doing significant jumps/drops. I do try and save weight where I can, but never at the expense of significant durability or reliability, and I'm not above adding weight if it will help my bike ride better.
    LMB
    I have a Ibis HD as my do all bike. I keep trying to run some lighter weight tires on it for the longer more mellow rides I do (like something in the 700gram range). Inevitably, I always wind up slapping the 950gram Butchers SX back on.
    While the lighter tires feel great on the long never ending climbs, I always wind up overworking them when its time to go down. Whatever time/energy they save on the climbs gets lost when dealing with a slash in the tire or lost pressure due to burping/folding.
    So my source of weight addition is 500grams of tire love. Ultimately well worth it.
    Reputation: anvil_den's Avatar
    Nov 2007
    I keep ramming up my El Guapo but its all for functional purposes... currently ~35lb (not too sure cos I never took it to the scale)
    A bit more wt on "DH" run days with bigger rubbers. Normal time on trail I find its not so much if a heavier rubber is better (mostly on jungle trail, lots of roots and rock) but huge volume is really my kinda things..low psi lots of float and not having to fiddle with lo-comp too much
    moar alike..
    Reputation: Deerhill's Avatar
    Dec 2009
    Quote Originally Posted by morandi View Post
    yep, tires = instant gratification
    Axe
    Axe is offline
    Custom User Title
    Reputation: Axe's Avatar
    I had one dedicated weight weenie bike, and it steadily gained a couple pounds. Tires, better fitting saddle, chunkier grips, different headset, wider bars, full length housing, brakes that do not suck (oh, boy, does Avid Ultimates suck).
    Took my RIP9 from 27.5lbs to about 31.5lbs.
    -Burlier wheelset, went from American Classic hubs with Stans Crests to Stans Flows on Chris Kings
    RS Reverb dropper post
    Wider bar, shorter but heavier stem, 725mm RaceFace Atlas AM and 70mm AKA stem, had a 700mm flat bar and Thomson stem. Although I just got a Sunline Vone AM stem 65mm so that should be similar to the thomson
    Added bashguard, swapped 32t mid ring for 36t, now running a 22-36-Bash
    185mm rotors F and R
    Heavier tires, 2.4 front, 2.25 rear, both Ardents
    XT trail pedals, had regular XT's on it prior
    Rides so much better, notice the weight a bit on the climbs, but its a totally different bike on the downhills and technical stuff. Best decision I ever made for mountain biking was to not worry about the weight and build it how I wanted too.
    Reputation: ride the biscuit's Avatar
    same as you, OP, plus adding chainguide
    not sure on the weight gain from my RS reverb, but i'm pretty sure it was surprisingly small...like 1/3lb or so from previous stalk seatpost
    my bar is around 750 but its a chromag osx...very light anyway. no clue how much the bigger rotor costs weight wise but again gotta be pretty negligible
    tires, esp, front tire is something i view as a an absolute must.
    I just went all coil on my bike. DHX shock and Lyrik Coil. Also put in some 2.4 Rubber Queens and a X Fusion Hilo Post.
    Took my RFX from 32lbs to 35-ish.
    Oct 2007
    Quote Originally Posted by eric_tfa View Post
    Both my bikes have the big rings replaced with bashguards, but I used e13 TurboChargers and I don't think it added much weight, if any. If it did it wasn't noticeable. The Tomac Snyper has an e13 Heim 2 chainguide on it, but I can't run one on the Pivot due to no ISCG tabs and the press-fit BB. I'm using the same bar as you.
    I took off the stock wheelset because the rims were too narrow (DT-Swiss 350 hubs with DT X430 rims). I'm thinking of getting the wheels rebuilt with Flows instead using the same hubs. How are you liking the Flows?
    LMB
    Reputation: 426h's Avatar
    Yup. Somtimes i use high volume tacky dh tires. Other than that? No.
    Quote Originally Posted by DeerhillJDOG View Post
    +1 the only parts on my bike where weight becomes a part of the decision process is tires and the difference in climbing with dh tires vs xc is incredible
    Jan 2011
    Yes!! this thread is so much fun, and so true also!
    on my Mach 5.7, it all started with heavier grips (ok just few grams, but you know... , then replacing 160mm rotor (definitely too small, too on/off for longest downhills) with 185mm and adaptor, some more frame protection, 2x more Stan's in the tires...
    One thing I am really not ready to compromise are the wheels : i stick to customs Crest/Nobby for dynamics, but I have to admit I am not in the toughest downhill business.
    skaterqwertyuiop
    Reputation: skaterqwertyuiop's Avatar
    Lol I definitely belong in this thread. My do-it-all bike weighs about 35 or so.160mm travel. I run a 2.5 Dissent up front and a 2.1 Weirwolf in the rear. I think the weirwolf is wider than 2.1, but that's what it's labeled as. I love having a big front tire; riding roots and rock gardens are so much more fun now.
    I have never considered weight while buying any component. As a matter of fact, everything i've bought has been heavier than the original. Wheelset, tires, seat, 203mm brakes. The only new part that i've got which is lighter is my SLX crankset... and i got a chainguide with it. I honestly don't care about weight. I've said it before and i'll say it again, Climbing is going to suck no matter what, might as well make bombing down more fun.
    I think i'll add that to my sig.
    It's not about what bike you ride, but how hard you tear it up
    T.W.O.
    Reputation: mimi1885's Avatar
    Good topic B,
    Beside the usual upweight of adj post, meaty tires, and beefy wheels they add more fun to trail riding as the margin of error is wider.
    I put Hammerschmidt to both my AM bike and XC bike it add 2 lbs to my bike but it's definitely a good thing. I clean more tech climb and can carry more speed and momentum into the climb. I find myself spinning out less as well as burning thigh in the middle of the climb. I can shift under full load on the climb you can't do that on the reg FD
    I have considered Rohloff for my bike a few times I love the action but not the engagement and the shifter it's such an awesome piece of engineering, with all the moving parts and it's still pretty light.
    Really really bad squirm last night, bike couldn't hold a line at all especially in the rough stuff, so my DT 6.1 Rim + real spokes ( not triple butted wennie stuff ) + hope pro 2 hub has gone onto the E5, it's slowly getting heavier
    Slightly smaller rear tire aswell as I've still got a 717 there till I would out this Big Gripper hassle and order something tougher.
    Reputation: client_9's Avatar
    + 2 lbs .... zero regret
    I replaced my air shock w/ an Elka Stage 5 w/ Ti coil.
    And added a KSi950 dropper seatpost to my Nomad.
    Worth every ounce and then some.
    I actually have that bash as well, weight is probably similar to a 44t ring. I was worried about durability originally due to the sorta "honeycomb" feature, but its held up exceptionally well.
    I love the Flows, Gone down hard with them a few times and have been perfect. I built them myself using DT ProLock Alloy nipples and they have been great. Love the wider rim, and of course the ease of going tubeless. I recommend Stans wheels to everyone, think they are fantastic.
    The RF bar is great, had that bar on various bikes and always go back to it.
    Te mortuo heres tibi sim?
    Same as many others - various tires, and dropper posts on all three mtbs now.
    GAME ON!
    i added heavier tires and a reverb
    RIP Adam Yauch
    "M.C. for what I AM and do, the A is for Adam and the lyrics; true"
    Reputation: pulpwoody's Avatar
    Fun thread.
    I've been making my Marin Attack Trail heavier every time I buy something, because I'm usually going for durability rather than weight. Since I've built it up:
    Hadley/Flow wheels.
    Command post
    Wider 745 bars
    203 front rotor
    tires, tires, tires.
    For a while, I was running a 2.5 Nevegal downhill on the rear. That thing is a TANK, but awesome. Extra cush, lots of traction, but just too heavy. Replaced it with a UST Nevegal (not that much lighter by the way).
    2.5 Minion up front, and the frame wasn't all that light to begin with.
    The one thing I did that made everything worth while was to replace the rear 11-32 cassette with a 11-34 cassette. Those extra two teeth made a whole world of difference on the climbs, and now the bike is big, heavy, strong and awesome.
    E5's no longer a weenie, I tried to keep it light but 717's + 1.6mm spokes = SQUIRM was all over the shop, feels much better.
    I refuse to buy expensive lighter stuff cause generally it's weaker, but I'd buy expensive ish strong stuff, say a rear mech, deore weight but XT price and STRONG!!
    i instaled biger brakes a chainguide and iam going to install a remote seatpost for thecnical trails
    Reputation: <Steven>'s Avatar
    Nov 2007
    Weight used to be a thing for me, I started out at 12.7kgs and now my bike weighs a bit over 15kg... don't know what the exact weight is cause I'm not interested in weight any more!
    My added weight came from adding a coil fork, more comfortable seat, 750mm alloy bars, adjustable seat post, heavier tyres, bigger rotors and better brakes.
    I went back to lighter tyres for a longer ride a little while back and didn't like the twitchy steering... heavier tyres are much more stable at high speed :-)
    Reputation: 2FewDaysOnTrail's Avatar
    Heavier:
    1. Wider Al bars (Easton Havoc's) w/Ergonomic Grips and machined Al Bar end plugs.
    2. Longer Fork (Fox Talas 120, Terralogics)
    3. Remote Seatpost (Specialized Command Post).
    4. Dark Cycles Bash Guard (Functional but beautiful as well!)
    5. Bigger Tires (Purgatory Control 2.4 on front)
    6. Nitrider 1400 Pro (Gotta see at night man!)
    7. Saint Rear Derailleur w/Specialized Derailleur Guard.
    8. Replaced 160mm rotors with 203mm front rotor / 180mm rear rotor and adapter hdwr.
    9. Stans Tubeless ZTR Flow's with Hope Hubs.
    Lighter:
    1. Tubeless
    2. Sunline 50mm Stem replacing 90mm stock.
    3. XT dual control shifter/hydro brakes.
    4. Ditched the 44 ring.
    5. XT front Derailleur.
    6. My butt is 40lbs lighter since February!
    29.6 Lbs currently according to the Park Scale.
    That about does it.....
    Salsa Bucksaw
    Trek Farley
    Niner Jet9 RDO
    Niner Air9 Carbon SS
    Rockhopper Comp SL
    Reputation: aliikane's Avatar
    Adjustable seat post, stronger wheelset, bigger tires, stronger tubes, coil shock, bigger travel fork are some I think are worthwhile.
    I know this is a big debate, but I think for more downhill type bikes weight to a point is better. I think the weight stabilizes the bike going downhill and too light of bikes get tossed around too much.
    Huckin' trails
    Reputation: David C's Avatar
    Quote Originally Posted by aliikane View Post
    Yep, and pretty often, most FR/DH bikes are not properly design to get a good climbing geometry, so even if I get my FR from 38 to 30, it will still be harder to make it up the hill then with my #36 trail bike... but damn that those pounds are great on the descent... Bulletproof and super stable...
    So when I have to buy a part, I often look to choose the lightest of the choice, but never the weakest... Because we all know that bombing down is not for blingy parts, it's about strength.
    David
    Quote Originally Posted by NicoleB28 View Post
    topless. that's what all mtb girls do. we go ride, get topless, have pillow fights in the woods, scissor, then ride home!
    Huckin' trails
    Quote Originally Posted by YZ250Fox View Post
    Sure your bike will be stronger and more comfortable with the extra components. However everyone else will be passing you on the trails.
    Yep, in their ambulance
    Reputation: FNG RIDER's Avatar
    zero gained and zero lost. 33 lbs
    replaced QR fork with Pike 20mm,
    added Fox DHX 5.0 coil shock, not good for trail riding.
    replace narrow riims with 28mm rims and 20 mm XTR hubs
    retained heavey duty WTB weirolf 2.3s
    replaced hone cranck with XT
    rear deraileur with SLX
    Replaced 8" hone rotors with 8" XTR rotors
    replaced seat post wih thomson masterpiece w/ wtb rocket v ti saddle
    still heavey but stronger, Fun bike coming down and thru technicals, but I have to tell you that you really feel the 33lbs on extended climbs.
    sold it recently and will be getting an AM bike in the 27 lbs range.
    NWS
    NWS is offline
    Jun 2010
    Quote Originally Posted by V.P. View Post
    Same here, plus Ergon grips, a hefty bash ring, and a comfy seat.
    I used to ride a 25-lb hardtail and replaced it with a full-suspension (6-inch) all-mountain rig that weighs in somewhere around 30 pounds. I'm not an XC racer or one of those guys who "loves to climb." But the climb on my favorite ride usually takes me just under an hour, and there is no significant time difference in doing that climb on my old XC bike compared to my all-mountain. It's no more tiring on the all-mountain bike. But it is a heck of a lot more fun riding down all the technical stuff.
    Also I've found that I can actually ride up some steep, technical uphills that I was unable to ride on the hardtail, because the full-suspension tracks with the terrain and rolls over big rocks, rather than just hitting a wall like the hardtail does. Again, on my favorite trail, there used to be (now there's a detour) a short, really steep, rocky and loose-gravel uphill that I could rarely climb with the hardtail. I could count on one hand how many times I made it up with the hardtail. I got the heavier all-mountain bike, and I made it every time without fail.
    I sometimes think bike companies weigh parts in grams just to make the weight savings from XT to XTR (for example) seem more significant. To go from something that weighs 200 grams to 100 grams seems like a big deal mentally, but it really isn't. (I don't know -- maybe this just works on Americans who aren't as familiar with grams). I added a RS Reverb to my bike (around 520 grams) and was freaking out over the added weight at first, until I learned the regular alloy seatpost I replaced was 250 grams -- a difference of maybe a half a pound? Well worth it for the function. I know 100 grams here and 100 grams there adds up, but like the OP said from the beginning -- sometimes the function is worth way more than saving a little weight.
    Reputation: 6sharky9's Avatar
    im not a weight weenie but will look for the lightest parts for the dollar..An example being comparing two stems and one says 140g and the other 110g for the same money or even less money ill go with the lighter stem but not the lightest I can find..Im doing a project build now hoping to reach the 27lb mark for a hardtail...No where near as light as I can make it..Im guessing stock the bike is 33 34 lbs...My latest purchase was a set of Ritchey Comp rizer bars(31.8/660mm) with an advertised weight of 306g..Well needles to say that was a BS claim..it weighed 365g on my new scale...I wanted lighter but not the lightest I could find...ill be looking for another set of bars it looks like,
    Axe
    Axe is offline
    Custom User Title
    @2whlfun
    I use a Superfly 100 for racy stuff and love the handling/ABP. It made sense to me to get a Rumblefish for technical trail riding. Same handling feel but aluminum frame, added 180 rear rotor with cooling fin pads, dropper post, 2.4 front Purgatory, wide bars and a F34 Talas 110-140 fork. It's work climbing but magic down hill
    2017 SPOT Brand MAYHEM (incoming) 2016 Spot rollik557, 2016 SPOT Brand Zephyr Adventure Bike 55c, Heller 27.7+
    This is a great thread! I like working on bikes but would prefer to suffer with a bomber bike than do trail side repairs while the crew gets edgy waiting.
    Every time I've "upgraded" to a lighter component, it's failed and bitten me in the ass. Best weight-adding upgrades I've made:
    RS Domain--180mm of coily goodness well worth the 6oz. of weight it added over my old Fox 36 Talas.
    Dropper post. No brainer.
    SLX brakes and 8" rotors
    Sticky 2.5 Nev up front and Minion DHF 2.35 out back.
    Wider bars- minimal increase
    Chunky stem- minimal increase
    Stinger chain guide. Only a 90g, but every bit counts.
    Stronger, heavier wheels to replace the "light" ones I keep destroying. Never again.
    Chromo steel-railed saddle. I don't know why it took three bent saddles in two seasons to figure this one out.
    I ride primary up/down AM style descents, with a fair mix of regular trail riding as needed. My bike is heavier than my buddies' but it just feels so much more solid and confidence inspiring. I really never thought about it being heavy until I made the mistake of weighing it recently on a bathroom scale. Ugh, 37 lbs.! I guess that's the price to pay for having a bike that can do what it does without costing $5K.
    Coil front and rear
    2100g freeride wheelset
    800g tires (sorta normal these days)
    Dropper post (also normal)
    Probably gonna throw on 203mm rotors in the front and 180mm in the rear. We have long descents in CO.
    This is on a Nomad. Works great in our bike parks too.
    Though, I'm also building up a light poppy jumpy 5" bike to compliment it. Should be a good backup bike and make riding with the girlfriend or on tamer trails (Fruita) much more fun. It'll be fun to bounce and play around on certain trails with. The Nomad is overkill for about 25% of my riding.
    Reputation: ColinL's Avatar
    Feb 2012
    I ride a 2004 Blur classic that I built up last year from a bare frame. It was 24.5 pounds at creation: X9 2x10 drivetrain, X0 twisters, Fox RLC 120mm fork, Mavic Crossmax ST wheels, Magura MT4 brakes, Specialized Ground Control 2.3F/2.1R tires.
    Added a Blackspire Stinger +90g. Added more Stans, ~50-100g. Changed tires to Geax Saguaro TNT 2.2F/2.0R -- added at least 400g. Replaced Eggbeater 3 with Answer Rove pedals, +180g. (Haven't weighed clipless shoes + CB cleat vs 5.10 shoes. )
    Current tire combo is a Michelin Wild Grip'R 2 Advanced 2.25 front with Ground Control 2.3 rear and I like it. A lot of volume and grip, not a lot of weight. I ride better than last year and I use better sealant, so I don't need the heavy TNT sidewall anymore.
    Next... I am debating buying a Gravity Dropper. I don't have a lot of post exposed, because it's an older frame with a longer seat tube and fairly horizontal top tube, so I'm probably looking at a 1" / 3" drop. I think 3" would be great considering I'm going without right now.
    Dec 2011
    Quote Originally Posted by 6sharky9 View Post
    I think it's safe to say you can go a little lighter than that on a bar, 365g - or even 306g for a 660 bar is remarkably heavy. Depending on what your willing to spend, you could go close to 150- 200g lighter with a wider bar.
  67. #67
    Reputation: Mr. 68 Hundred's Avatar
    AM Waltworks SS HT, New Mexico Spec
    1)DX clipless pedals (had XTR before)
    2)2.5" DHF front, 2.3" Rock'r2 rear (had 'lightweight' 2.35" HD/NN's before)
    3)MTX 33's (had 'lightweight' DL31's before)
    4)Boring DT Comps in front, Alpine III's in the back, DT brass hex nips
    5)Hadley SS rear hub (needed it to fit the 13 g Alpine III's)
    6)Nuke Proof Warhead DH bars with Tioga bar ends
    7)140 Pike (replaced the sissy 120 Fox 32)
    8)KS dropper
    9)Lightweight Holtzfeller stem (it's light because it's only 60 mm)
    10)Main frame tubes are BMX Supertherm
    Not exactly sure of weight but it's not less than 30.
    Proponent for an Evidence Driven Life.
    Occupation: Disposable gene transfer machine
    Current HTFU status: 4/10; increasing
  68. #68
    Reputation: yogidave's Avatar
    2010 Intense Tracer VP size L 26"
    DT Swiss 135mm standard QR to 135mm/10mm RWS thingy: +50gr
    Thomson Elite post ---> CB Joplin4 dropper: +250gr
    Fox 32 Talas 150 ---> Fox 34 CTD: +200gr
    Tires: I run 2.4" robust tubeless like Maxxis Highroller II: so let's say this is +200gr (vs light tires)
    My body: +7lbs vs last year
    All this makes the bike more capable (or maybe just covers my flaws?).
    Planned:
    Easton Monkey Lite Carbon bars 685mm ---> W-I-D-E Carbon bars: +50gr
    DT Swiss EX500 rims, ghetto tubeless ---> Stan's Arch EX w? proper tellow tape: -250gr
    what else is there, really?
  69. #69
    Jkj
    Jkj is offline
    2012 Spec Epic, Yes it is a fast XC machine. However, after I added Downhill stem, custom-made long steel handle bar, custom-build Flow Ex wheels, dropper post, robust tires, strong pedals.... I fly through technical rock garden with light speed! (In my Mind )
  70. #70
    1. Switched from a Pushed RP2 to an Avalanched DHX 5.0
    2. Peaty Lock on grips from foam grips
    3. Steel XT skewer from Ti Salsa skewer (rear wheel)
    4. 2.4 F/2.2 R Trail Kings from 2.2 X Kings F/R
    Worth the extra 2 lbs or so? He elll yeah.
  1. Anti Weight Weenie - Show me your cool NON-WW bling
    By BoomingSooner in forum 29er Bikes
    Last Post: 01-18-2011, 10:53 AM
  2. Warp's 1st weight weenie thread...
    By Warp in forum Nicolai
    Last Post: 03-14-2010, 11:23 PM
  3. adding weight to test weight saving upgrades
    By lampy29 in forum Weight Weenies
    Last Post: 01-29-2009, 03:07 PM
  4. Weight Reductions (Rookie Weight Weenie) LOL!
    By ROCKHOPPER703 in forum Specialized
    Last Post: 08-07-2008, 08:25 AM
  5. The Bottlerocket weight weenie thread.
    By euroford in forum Transition Bikes
    Last Post: 12-13-2007, 12:04 PM
