Results 1 to 27 of 27
    Hooded menace
    Reputation: papanoel's Avatar
    Nov 2008
    Another custom AMHT frame
    Hi guys,
    I recently received this pic from the factory where my frame is being built.
    There's still a few welds to be done (rear brake tab, cable stop, hoses guides), some sand blasting and it will be good to go.
    For those of you who want some figures, here they are:
    600mm top tube effective lenght
    425mm chainstays
    44mm ID headtube
    74 seat angle
    67 head angle
    Will take 160mm travel forks.
    And yes it's titanium and the down tube is hydroformed. Hope you like it.
    Last edited by papanoel; 11-17-2013 at 12:26 PM. Reason: Added a few details, corrected a mistake in the thread title
    squish, squish in da fish
    Reputation: fishwrinkle's Avatar
    looks like a ripper. why is the company top secret?
    Anytime. Anywhere.
    Reputation: Travis Bickle's Avatar
    64 degree servant tube angle?
    I got some bad ideas in my head.
    Hooded menace
    Nov 2008
    Quote Originally Posted by fishwrinkle View Post
    No it's not top secret. It's TSB.
    Sorry I made a mistake. It's 74.
    FM
    FM is offline
    Reputation: FM's Avatar
    Apr 2003
    That looks really good. Would you mind sharing details on cost and design coordination?
    Also will be interested to see the tire clearance. I've owned 5 AMHT's now, and limited tire clearance was the reason I sold the first three. It seems like a 73mm BB shell, and segmented chainstay(s)- are the most common ways to get clearance for 2.35"+ tires in conjunction with shorter stays.
    Jan 2011
    Rear axle 150 ?
    Looking sweeeeet
    Anytime. Anywhere.
    Love it!
    Hooded menace
    Nov 2008
    Thanks.
    Well, total cost will be around 1200-1250$.
    I did the design but had to change it a bit. I absolutely wanted both top and down tubes to be bent. At first I designed the frame with 44-45mm OD top and down tubes. I asked several frame builders (Triton, RTF, Ora, Hilite) and they declined, didn't answer or tried and disappeared. Those who declined weren't able to bend such big tubes in a conventionnal way.
    Among them, only TSB answered favorably. Please note that I didn't get in touch with XACD because of some apparent quality problems.
    TSB couldn't bend the tubes I required so the top tube is now 38.1 OD and the down tube is 48 OD at the head tube. They use that tube in other frames so it's been quite easy to get it for mine.
    A 2.4" tyre should fit.
    You're right it's a 73mm BB shell. Tyre clearance was a concern here. I didn't want to increase chainstay lenght just to fit big tyres more easily. Wheelbase is already long enough with 425mm chainstays.
    Quote Originally Posted by johnoats View Post
    Rear axle 150 ?
    Looking sweeeeet
    No it's a standard 135mm rear axle. I wanted some removable dropouts at first but chose to keep it simple in order to lower the total price.
    Love it!
    Thanks a lot.
    that sounds like a helluva price for custom hydroformed TI. keep us posted on build and ride report.
    Hooded menace
    Nov 2008
    The frame is now finished and on its way to my home.
    I forgot to remind them that I wanted it sand blasted but it looks good this way. I guess I'll keep it as is.
    Reputation: Fuglio's Avatar
    Holy shit thats nice.
    Bro Mountainbiker
    Reputation: Sheepo5669's Avatar
    May 2010
    Great looking bike. The lines are unique, which I dig.
    26 inch wheel I presume.
    I will braze my own this summer at UBI. Gonna have low BB, slack HTA, short stays, 650b wheel, and 150mm fork.
    Wont be as pretty or light as yours though!
    Raised in a Chicken-Coop by Chickens
    Bro Mountainbiker
    May 2010
    Your bike need a Pike, matching Reverb, enve wheels, 1x drivetrain, and XTR brakes.
    Mmkay? Thanks.
    Reputation: dump's Avatar
    Looks nice. Looking forward to seeing that built up.
    g3h6o3
    Reputation: PissedOffCil's Avatar
    Oct 2007
    Wow!!,
    Check out my SportTracks plugins for some training aid software.
    meh?
    Reputation: Map204's Avatar
    May 2012
    Built yet? Would love to see pics
    Sent from my iPhone using Tapadapabapadoo-op
    2013 Chromag Rootdown
    2010 SC Chameleon
    2001 Specalized Rockhopper FSR
    Hooded menace
    Nov 2008
    Quote Originally Posted by Map204 View Post
    No, it's not built yet.
    Actually I had to send the frame back because the brake tab was bent (it moved slightly after welding).
    It's repaired now and should be sent again to me in the upcoming days.
    Reputation: Fix the Spade's Avatar
    Quote Originally Posted by FM View Post
    That's something to talk to a custom builder about. My frame has 420mm stays and can clear a Conti 2.4 just about. All without any fancy machined bits too, just bent tubes and carefully placed bridges.
    Jan 2014
    Quote Originally Posted by Fix the Spade View Post
    Agreed, I can clear a 2.5 tire with zero machining as well. After 5 frames one should have a good idea of likes and dislikes. Time to stop wasting money on frames and have one built to the riders spec. Then again, some people change bikes more often than their underwear.
    Dianetics Junior
    Reputation: CBizzie's Avatar
    Mar 2011
    Can't wait to see it built up! Nicely done....
    The White Jeff W
    Reputation: jeffw-13's Avatar
    Wow that has great lines. Reminds me of the Titus El Guapo, but much cleaner without the shocks & linkages. Well done. Cant wait to see it built
    No moss...
    meh?
    May 2012
    ^agreed. Got a hump like the old Sc Jackal
    2010 SC Chameleon
    Hooded menace
    Nov 2008
    Thanks for all your comments guys.
    The frame arrived yesterday.
    I just fitted the rear wheel to see if a 2.4" tyre fits (Maxxis Ardent) and... it's ok.
    I'll build it over the next weekend and post pictures once it's done.
    Nov 2013
    That is so cool.. I was just curious, what is your overall height, and stem length you plan to use?
    Hooded menace
    Nov 2008
    Quote Originally Posted by ktminthewoods View Post
    Thanks.
    I'm 1.77m tall (5ft 9in) and will use a stem length between 60 and 70mm .
    Hooded menace
    Nov 2008
    It's done.
    I finally built it. Actually it was ready 2 weeks ago but decided to order a few more parts (seatpost, headset) for a better color coordination.
    2.4".
    I did a quick ride today just to make some adjustments. As you can see it was a bit muddy.
    The bike is quite stable even though I didn't ride rough stuff. The weight repartition is fairly good as I can climb steep stuff without lifting the front wheel.
    The White Jeff W
    Re: Another custom AMHT frame
    Looks great! Enjoy
    No moss...
  1. Replies: 0
    Last Post: 10-17-2013, 09:11 PM
  2. AMHT: Kona Steely vs. Specialized P1
    By Mr KK in forum All Mountain
    Last Post: 09-25-2013, 05:34 PM
  3. Replies: 1
    Last Post: 06-06-2013, 07:46 AM
  4. New AMHT build - reuse parts or start from scratch?
    By svalgis in forum All Mountain
    Last Post: 10-30-2012, 10:20 PM
  5. AMHT Crank suggestion
    By beatkeeper1 in forum All Mountain
    Last Post: 11-25-2011, 11:02 PM
