I know of two companies that make SS kits (DMR and Gusset) but I am not sure if there were any other companies out there that I do not know of and figured the best way to find out was to post such a thread. Also, no idea on quality of the kits. I could have posted in the SS sub-thread but then most of them do XC and figured asking here in the AM sub-thread I would def. have a better chance of someone who SS and does AM giving me a straight answer. Also giving me advice on a cog for uphills and whatnot.
I found this link but no idea on the tooth count. I do a lot of climbing, don't care to race, and somewhat decent amount of rock gardens. If anyone has any idea on tooth count.
$23, 16t cog, enough spacers to get a perfect chainline. no need for a $40 cog just to try it. chances are you will want to try a couple sizes. once you figure out what you like then you can get a more expensive cog.
Yea, I was gonna just get a cheap one but figured I'd ask for opinions of teeth through that site, which I most likely will be buying from when things are in place. :thumbsup: But, that's pretty much it for a SS swap, huh? Thanks!
Now why couldn't Ass P. be this nice. :cryin:
Edit: Which option should I be looking to get, though? W/Spaced, Angled spacers or W/Guides, Spacers?
I use 32 x 20, which is low by SS standards. Typical is a 32 x 16 or 32 x 18. The 20t rear lets me wheelie drop, climb trailside rocks, and mash through rock gardens reliably. I also weigh about 210 w/ gear so I can't scamper up the steeps as well as the lightweights.
Surly makes a fine spacer kit, but so a million and one other folks. Surly makes a great SS cog with an asymmetrical profile to help dial the chainline. Alternatively, you can break apart an old cogset (like a SRAM PG850) and recycle those cogs. Try to figure out which gear is close to what you like to spend the whole day in - you can do this on the geared bike with some willpower. Go to Sheldon Brown's gear calculator and play around with different combinations of chainring and cog. Lastly, build the bike and start accumuating valuable experience. Between your legs, lungs, and brain you should be able to figure a workable gearing solution. For reference I run 30:18 or 34:21 on my 29er, and I used to run 34:19 on my 26er here in rocky PA.
I ride both a AM bike and a single speed. My single speed is geared 32/20. it is great for where I ride which is the mountain benches. alot of up hill. keep in mind, my single speed bike is about 10 pounds lighter then my AM bike ( Specialize Enduro). it will depend on where you ride. If there are alot of long hills then 18-21 tooth cog will probable work for you. I am just giving my 2 cents worth. it all depends on your riding style, and how strong YOU are or how strong you want to become. I got into SS to get stronger to help me peddle my AM bike up hills. I am also a Clydsdale, 6'1", 260. so all hills are hare for me.LOL. What I found is start samowher ein the middle and just experiment with different cogs until you find the one that suits you the best. good luck!
Thanks for the advice, guys! I am using a 32 up front and I seem comfortable with a 11 in the back. At least for climbing. Maybe a little bigger cog for getting over obstacles. OperatorBo, your 2 cents count!!
This is what I use currently on my On One Summer Season. The 32x20 is a decent all around choice for what you describe. I have had to change my riding style a bit becasue I do spinout fairly often on even slight downhills. All that being said, I think I will be slapping a 18 tooth sprocket on the On One in the next couple weeks. I do have mine set up as a 2x1 though, using my Sram xo grip shift and x7 for front chainring shifting duties and this for handling the varying chainlengths needed.
On my regular xc oriented singlespeed I used a Forte conversion kit from Performance that does the job, but is a bit heavier. On that bike, weighing in currently at about 22#, I run 32x16 gearing with no issue.
Good luck to you. My experinmenting into the singlespeed and 2x1 side of MTB started because I was frutrated with my rear derailler. However, I am finding I enjoy it for the simplicity, lack of obsessive thinking (which gear should I be in?) and reairs that seemed the norm when I was running gears.
You're good, Ass P. :thumbsup: Yea, I use a 32 ring up front and the 11 cog at the back. Jealous? With your HIGH IQ of little things, I hope not!. Although, If am going to go SS I will have to suffer with a 12 cog. :cryin:
I read, you're 150 lbs? Yes? No? Move next to me and I'll put meat on you from going to the gym.
Having built an all-mountain capable singlespeed Chameleon, I will say that you're going to want a little shorter of a gear ratio than a comparible XC bike. You'll be carrying a ton more weight than most XC SS bikes.
Also, you'll want a faster rolling rear tire to help you get up to speed quicker. Just be careful getting through rock gardens.
And gear your bike for the worst climbs imaginable. 32-11 is cute, try using that on a 1200 ft climb all the way to the top; or even trying to get up a steep/technical section of trail without stalling. 34/18 worked well for Georgia mountains but your region might be worse.
I'll stick to using the 32-11 for climbs for now, since I still have the rear cassette on. Guess not too many work out and don't drink beer and eat donuts or greasy fat bacon bombs. But, I appreciate your suggestion for the rocky terrain. Again, I am ONLY using the 32-11 right now since I am climbing forest roads to get warmed up. I have not hit the rock gardens yet, which is why I wanted suggestions as to which type of cog would be suited for such terrain.
