Results 1 to 6 of 6
    AM DS28 DISC OR FUNN XLRATER Rims? Thanks!
    I want to get a pair of white rims. I've read similiar posts regarding white rims, but they pertained to more urban riding. Although I do ride a lot in the streets I dont do any heavy jumping 2-3 ft. max (for now), I mainly ride XC, all-mountain. I havent read much about either of these two rims. I dont care so much about weight. I just want a dependable, strong, white rim. Any suggestions on these two listed below? Any help would be much appreciated.
    Andrew
    Specs on the SYNCROS -
    Intended use: Lightweight Freeride / All Mountain - Disc specific
    / Ultra strong, lightweight (545gms)
    / 32h with eyelets
    / True Track Technology™; A unique sleeved rim design produces the strongest rims available
    / Patented Bead Lock System™ prevents independent tire
    rotation on the rim when running low pressures
    / Every rim is stress relieved and work hardened after joining
    to be the flattest, best building rims available
    / 100% QA on each and every rim ensures near-perfect
    round and runout
    / Concentrically drilled holes for perfect spoke alignment
    / Width: 28mm / ERD: 530
    / Available in matte white or black
    Specs On the FUNN XLRATER-
    XLRATER ( click image for larger picture )
    FUNN BY SUN 26” 4X/ALL MOUNTAIN RIM
    POWDER COATED WHITE
    BLACK EYELETS
    PINNED AND WELDED
    32 HOLE
    28MM WIDTH, 16MM HEIGHT
    WEIGHT 520G
    Reputation: rmbnick's Avatar
    well i am about find out. i ordered thos esyncros for my hard tail 4x bike, so when i get them ill tell you in this coming week
    GETOFFTHEBRAKESYAFAIRY
    011100000110111101101111
    Reputation: unfluid one's Avatar
    Aug 2005
    I have the DS28 white rims. They are matte white and not glossy, so they collect fingerprints pretty easily, but doesn't really matter once the bike gets dirty.They have pinned and sleeved, and I see the Funn rims are acutally welded... if that matters to you.
    They are strong and tall and I have no problem running them on my FR HT with hadley hubs.
    The FUNN rims are actually made by SUN-RINGLE, and these ones are just white versions of the S.O.S rims. Which makes them pretty good IMO.
    Reputation: zahgurim's Avatar
    Aug 2005
    The Syncros DS28 is identical to Halo's Freedom disc, also available in white. Both made in the same factory in Taiwan.
    Awesome rim, very light and strong. I run black ones on a spare wheelset...
    Perfect choice for for an all mountain bikey. Because they are the same rim with different stickers, just buy whichever one you can get cheaper (Halo?).
    Thanks! I'll look into the Halo's I cant even get the people at Syncros on the phone, or to reply to an email...go figure.
