Results 1 to 35 of 35
    AM Brakes help needed! Hope/Avid/Formula
    Well its time to upgrade the brakes. Right now i have some crappy Hayes, but need more power. Right now I'm looking at the Hope Tech X2, Avid Elixir CR, or the Formula RX. Has anyone had negative experience with the CRs?? A lot of people around here have them but there are a lot of negative reviews as well. I'm leaning towards the hopes for reliability but just cant make a decision. I like the look of Avids a LOT but if they don't work ..... Opinions??
    Helmet Tester
    Reputation: MobileMech's Avatar
    I am running Elixir CR's on my bike, 203 front and 180 rear. These were my introduction to hydraulic breaks, so as far as power goes they kick ass. I have had some issues with my rear break fading, but it's most likely poor adjustment on my part that I have yet to fix. My buddy has Formulas on his downhill bike and they work great, but I haven't really done anything on his bike long term to give any good review.
    Short answer: 1 for avid
    No Clue Crew
    Apr 2005
    I've had several sets of Hopes, several sets of Elixirs and my best riding bud has Formula Ones. Based on his experiences, I would not personally buy Formula. They look fantastic and probably have the best lever feel I've witnessed. However, they're difficult to keep dialed, they eat pads and parts are expensive. He loves them when they're dialed, but doubt he'd buy them again.
    I currently have Elixir Rs (203/185) on my El Guapo. I have to say, this is my second set of Elixirs and I can't make a legitimate complaint about them. Consider, though, I live in AZ and it's very dry. I've experienced zero fade, zero noise, zero maintenance other than pads. Very good power, not as much modulation as I'd like.
    Which brings me to Hope. By far, without question, the best brakes I've used. Mono M4, old Mono Minis, etc. Power, modulation, aesthetics, they're the complete package. I'm about to drop coin on a new set of X2s and move my Avids over to the hardtail I'm building.
    Quote Originally Posted by Blatant
    Yea I'm kinda thinking the hopes as everyone seems to love them. Where are you getting your x2 brakes. Is it a good deal I might be able to get?
    I have to say that the Tech X2's are very powerful indeed and not so bad in regards to setup, even from someone who has not dealt with hydraulic bike brakes before. I cannot compare to Formula, Avid, etc. but they are an incredible upgrade from old XTR cantilevers
    Next bike will have Hope's Tech M4's ... even more power.
    I would say Hope, definatelly.
    I had Hayes HFX MAG, then Avid Elixir CR and now I have Hope Tech M4.
    And this is THE brake for me - as far as we speak AM.
    It is great looking, light and powerfull with excelent modulation.
    They are very easy to set up and I don't need any special set to bleed them.
    I run 183mm front and 160mm rear, but I am heavy rider and I am switching to 203/183.
    In my opinions, Hope brakes are so good, that I will not look for a brake anymore - I will just chose the right model for next bike from Hope line.
    Best regards
    Dec 2010
    Based on what I see, I would totaly imagine for the Avid Elixir CR to workout. Good luck!
    Hopes! You won't regret it. I wouldn't pay a huge price premium for them b/c the Avids work nice too and the Formula's are beautiful and have a stellar reputation. But you can get the Hopes from CRC or Wiggle for nearly the same price as the avids and far less than formulas.
    Master
    Running Formula The Ones and they stop on a dime. Reliable ,strong, light, but pricey.
    Dude save some and get the elixir r...works great
    S&G CREW
    +1 for the elixir r
    "No Clue Crew"
    Reputation: Grave9's Avatar
    I've been running Formula Ones now for a few months and plan on ditching them for Hopes in the next month or so............Drew
    Reputation: mazspeed's Avatar
    The Avids are just not even close to the Hope's IMHO. The Formula R''s and one's are light, but will fade out as told to me by guys at Ibis. I have been running Hope 6 piston ti's for 3 years, and they are by far the strongest brake I have ever used. They have the best feeling, no fade, and very controllable. I ran avid elixir's on my hard tail and I hated them. I'm 225 pounds and tend to ramble down the hills pretty good, and they just didn't have the power my hopes did. Not even in the same ballpark. The avid's are lighter, but if you want the best brakes, if you can find the 6ti or the x2.s get them. I can not tell you how much a good brake will save your ass at those speeds.
    A riding buddy of mine has had a nightmare with his Elixir's, mine have been fine.
    The biggest difference between the Elixir's and Hope's is the Hope's have much more modulation and the lever of the Hopes has a much more solid feel to it. Hopes are also a doddle to bleed.
    The X2's might not be powerfull enough. But that depends on the rider and trail. I would go for the M4's any day.They might not be the lightest of brakes...but Hope brakes are the nicest looking IMO.
    Double-metric mtb man
    Reputation: Psycho Mike's Avatar
    I've been running a set of Mono M4's for a few years now and can say Hope makes awesome products.
    I'm not a small rider (6', 240-ish lbs), but they've got the modulation so that I've never had an issue riding in the winter on snow and ice, but they also have the power that 1-finger braking is my norm unless I a) need to lock 'em up or b) do a s#!t bricks panic on something.
    They can be a bit tricky to set up, but once you get them sorted, they rock. A friend of mine likes his Formulas...he went to them after not getting quite the power he was looking for out of his Hopes (I suspect it was a set-up or bleed issue). We swapped bikes for a bit during a ride and he just about endo'd because he wasn't expecting the power my M4's were making. His "The One" brakes were good but, and this is personal preference, I preferred the feel of my Hopes.
    As if four times wasn't enough-> Psycho Mike's 2013 Ride to Conquer Cancer Page
    Moran? Let your opinion be free -> F88me
    rotor size
    Hey guys..im pretty much sold on hopes..sorry to all you avid lovers. My other question is what rotor size to get. I think that I want to upgrade to 183mm rotor but Im afraid that I will snap my RS Revelation in half. Will I? I can see it flexing with a 160 rotor up front. Are my worries unfounded or will the fork break?
    Quote Originally Posted by awesome51
    You won't be sorry! Just look up the requirements for your specific fork, but a quick google led me to the conclusion that Rev's are rated for up to 203 to 210mm depending on the model. Also, how much do you weigh? That will prob factor into the equation...
    I weigh probably about 200 lbs loaded up with all the gear. Are these forks supposed to flex?
    Quote Originally Posted by luke_
    Best regards
    IMNSHO, don't trust a guy that matches his brake hose and anodized 2-piece rotors to his frame
    Just kidding of course ... I'm just disappointed that I didn't think of it
    Quote Originally Posted by dipan
    That's the comfort of building the bike all by myself and carefully choosing every part to be reliable, strong and the right color
    best regards
    I'd recommend Avid's new Code R's in lieu of the Elixir R's. I installed a set of Code R's on my Trance X1 and they're great. The power is very good and a definite step up over the Elixir R's. On straight line testing it's possible to induce lift the rear wheel by applying the front brake. At slow speeds I can even lock up the rear wheel quite easily with 160 mm rotors.
    At high speeds the Code R's have incredible performance I did some high speed street runs to test the new brakes they're awesome and bring the bike to stop consistently and easily from hair raising speeds.
    My elixir CR has stick pistons. One side does not retract fully. The pad adjustment does not adjust alot to make a difference, just slight.
    Power is not that bad, although for that money better, lighter brakes can be bought. The carbon lever is surprisingly not as weak as I thought.
    Took a couple of big hits and only slight scuffs. So far 4 months and not a bleed yet so I guess the brake is going well.
    I'd say for that money go get something better. Unless of course you get it real cheap in a closeout deal.
    Aug 2010
    i ve used elixir cr and formula rx. i perfer the rx for its excellent feel and stoping power. the cr has a nice feel to them but they dont stop as well.
    im about 145 with gear on and run 180(rx) 185(cr) front, 160 rear rotors
    dont know about the hopes
    Reputation: edray's Avatar
    Ive had Elixir R's, CR's, Code R's, Formula The Ones (older version) and now Tech M4's on my AM bikes. The Hopes out-perform them all. Hands down. Insane modulation, power and come on, they look crazy awesome. That CNC action is just beautiful. Worth the money and the wait. The Elixirs, both R and CR's were rock solid too, just got some UGI.
    I'm building an AM hardtail and need some brake advice. I've been using Elixir brakes for a couple of years and really like them, but saw the glowing reviews of the Hopes, so I might just go that way. My question is rotor sizing. If it's a hardtail, wouldn't it be wise to use the smallest rotor possible on the back since the rear end is going to hop and chatter over terrain much more than a FS bike? Seems the suspended front end is where all the stopping power is going to be, above and beyond normal. I'm about 210lbs when kitted out. Thanks for the advice.
    wuss
    Reputation: dropadrop's Avatar
    I don't understand how anyone can say hope brakes are easy to set up. They require you to tighten the caliper and then align the pads, while everyone else just requires pressing the lever and tightening the bolts.
    I'm happy with hope, but set up does require more work then anything else.
    Aug 2010
    Hope FTW.
    Quote Originally Posted by dropadrop
    I didn't hear about such procedure with Hopes.
    What year and model do you have?
    I have Tech M4 and I have just aligned caliper ONCE. I have removed front wheel for transporting my bike many times and I NEVER had to realign the caliper.
    My friend with Elixir does have to realign caliper every time the wheel is replaced.
    In my case the set up was much simplier than my previous brakes (Hayes and Avids).
    Best regards
    wuss
    Best regards
    I've had Mono M4's and currently have Tech V2's.
    If you actually read the manual for either you will notice they advise you set up the brake by first attaching the caliper parallel with the disk - then aligning the pads so that they extend evenly and don't bend the disk. With my M4's it was quite a pain in the rear as the pistons all extended out at different speeds.
    Every other brand I've had / read the manual advises you to attach the caliper by just pressing the brake and tightening the screws. This has also always worked for me.
    Now I like Hope brakes, I just don't consider their set up to be simple compared to other brands, and if you follow the instructions it won't be.
    Don't know about your friends elixirs. I used to quite like my BB7's, but the only Avids I've tried after that was Juicy 7's which (IMO) don't come close to Magura and Hope. I can't imagine why he's having to adjust the caliper, probably presses the brakes while the wheel is off or has an axle that centers the wheel differently on different occasions...
    I have the Hope Race X2s. They are awesome. I'd like the Tech X2s next. Then I would have a little more adjustment up front. The Tech lever is really cool looking too. The Race lever is light. There you have it.
    That's true, but you can align the Hopes the same way as other brands (squeeze and tighten) and you can also align the other brands the same way as Hopes (align by sight, then adjust pads). If I have a problem in the field, I always go with the simple way, but the Hope method actually seems to yield better long term results if you take the time to do it properly.
    I have to say, I don't use this procedure. Now, when you said about it, I remember that this is in the manual (I have read it once )
    What I did - I have aligned calipers visually. tightened the screws and that's it. Everything worked perfect from the first try.
    And after a while, I have never done that again.
    For me, the Hope Tech M4 is the first "set it and forget it" brake in my bike.
    I had so much trouble with realigning my elixirs, that I am really happy now and will not use other brakes on my bike.
    For me - the Tech M4 is exactly what I need. Period.
    Thanks for your reply.
    Best regards
    Loved the way my elixirs modulated but hated the brakes. Replaced 3 under warranty in the course of 2 years. When they worked, they were great. It was keeping them working that was the trick. Running Formula the ones now. Love them! Went with smaller rotors but they still have more stopping power than my elixirs.
    This guy is the bible,I have also owned all three and agree 100%,and if your looking for rock solid brakes,minus the bling throw the shimano xt brakes into the mix...
    Reputation: illini's Avatar
    Dec 2009
    Yup the 2010 XT's have the best lever and very easy to bleed.
