Results 1 to 49 of 49
    Reputation: tubadude's Avatar
    All Mountain floor pump?
    I am getting bike ready for tomorrow's All Mountain ride and realize my floor pump is inadequate for such a burly All Mountain bike. Does anyone have any recommendations?
    My pump is also woefully inadequate for an All Mountain bike so I have reverted to gripping the valve with my teeth and just inflating that tire myself. I'm searching for a true All Mountain pump and some ALL Mountain valve caps. When I find some, I'll report back.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Yes..
    Okay, quit teasing the poor guy and tell him what your All Mountain floor pump recommendations are. They better not be some dinky lil XC floor pump either. We are talking only All Mountain here.
    t0t411y.
    ALL Mtn. pumps r the hardest core. dude you should get like a schwinn or a JEEP or a HUMMER pump. wut's more all mtn than a hummer? berly.
    How about a 60 gallon Husky floor pump, thats AM adequate?
    Big Test Icycles
    Reputation: Hangtime's Avatar
    Make sure it has an all mountain handle and lock on grips, ODI work well. Get the one with the 10' air hose.
    Quote Originally Posted by jmac1911
    Is there a review in Mountain Bike Action you can post a link to? I would hate to buy one and find out it is only a XC pump made a bit heavier and relabeled.
    I just bought a compressor thinking it would be the bare minimum for a true All Mountain pump. However, I'm having a bit of trouble putting it in my car every time I go ride. This is ridiculous. The only helpful advice I can offer is this:
    A true All Mountain Pump will air a tire in at least the same number of strokes as the tire size. So a 2.1 takes 2.1 pumps and a 2.4 takes 2.4 pumps. Any worse and you may as well toss it at the next XC weenie you see.
    All the best in your search and all future All Mountain activities.
    long standing member
    Reputation: PCinSC's Avatar
    I just blow mine up manually. That includes seating my DH tubeless tires on the rim. My lungs are very strong.
    Reputation: Slack_er's Avatar
    Big Test Icycles
    Quote Originally Posted by tubadude
    Here'a a link to a pump. Not what I use, I ride XC and DH so I dont have the need for the All Mountain pumps. Good luck.
    http://www.mypleasure.com/Sex-Toy-Fireman's-Pump.asp?dept_id=901
    Now with More Wood
    Reputation: Iceman2058's Avatar
    You're comtemplating buying an ALL MOUNTAIN pump that's going to be used on the FLOOR? You're obviously woefully under-qualified for even aspiring to owning an All Mountain pump.
    Me hates pinchflat
    Reputation: 545cu4ch's Avatar
    Aug 2005
    dudes... tubes (and tires) are for wussies. They are just a crutch for the not-machos. Riding on the bare rim is where its at
    Quote Originally Posted by sriracha
    "jesus would huck it"
    Quote Originally Posted by FoShizzle
    i have found the 1.5" headtubes to be slightly larger in diameter than 1 1/8", plus or minus
    PUMPS ??...........can't choose
    I get so confused sometimes figuring out which pump i should use for which bike I have. I have so many...... XC pump, All mountain pump, freeride pump, downhill pump. Maybe I should label them. I wouldn't want to use the wrong pump on the wrong bike.
    Order placed. They had a lot of stuff for All Mountain Man, but very little stuff for All Mountain bikes.
    King of vegetarians
    Reputation: yoginasser's Avatar
    Quote Originally Posted by PCinSC
    Wouldn't it be more correct to say orally then?
    Black Sheep Dream Bike Design
    www.blacksheepbikes.com
    The future is not retro proof.
    Quote Originally Posted by yoginasser
    Probably, I didn't want to be that explicit...you know it's a family website and all. My meaning was more along the lines of definition #2.
    This thread emphasizes what I dislike about the sport of cycling now. I have been out of the riding scene for the last 10 years. I was on a 20" then riding street and dirt. I had a GT Outpost too...bottom of the line. I could pull 3's, no footers etc. on it. I didn't have to go out and purchase a DJ bike just for this. I made it work with what I had. Alot of the threads I see deal with petty "best all mountain sock" type of subjects. Stop posing and worrying about what label your equipment has on it and go ride.
    I will stick with my industrial 10 hp air pump with off road nobbies on it to make it easier to move and a mini pump.
    the goose is loose!
    Reputation: rm_racer's Avatar
    Feb 2006
    this entire thread is sarcasm to the max.....can't you see that? it's a floor pump for god sakes...
    Reputation: jetta_mike's Avatar
    Feb 2007
    Quote Originally Posted by kbdub
    360 and no footers on a GT Outpost!?!?! R U SPAWNSORED!?!?!?!?
    Not sponsored and KIDS are pulling 3's on flat ground now. Doing a flip is becoming just another trick. Stuff is progressing super fast due to foam pits. It's not really a big change to go from a 20" to a mountain bike with respect to dirt jumping. Both behave the same once in the air. I learned on my 20" (Hoffman Taj) and then moved to the Outpost for fun. It also helped that I was in highschool and my balls were much bigger back then. Turn your head and your body will follow.
    Me hates pinchflat
    Aug 2005
    Quote Originally Posted by rm_racer
    yah, I thought it was pretty darn obvious
    Come on, man. There is a world of difference between a tire designed to withstand the rigors of All Mountain abuse and one designed for XC riding. My tires are way beefier and I can't take the chance of a part breaking if I use flimsy weight weenie equipment.
    I gotta know that the air in my tires is All Mountain.
    the goose is loose!
    Feb 2006
    you have an excellent point.....
    Me hates pinchflat
    Aug 2005
    ooo thats a good point right there. To inflate an All Mountain tire properly, do you have to do it in an all-mountainish place??? I wouldnt like my allmountain tires filled with xc-weenie air
    Reputation: JrockFeltaz's Avatar
    I just fill em up with some ganja smoke. If I ever forget my stash or lighter I always will have a hit out on the trail
    Reputation: pixelninja's Avatar
    Quote Originally Posted by JrockFeltaz
    BRILLIANT!
    "If you suck, that means I'm better. The more you suck, the better I am. So. Let me count the ways you suck." - Scribb
    Bite Me.
    Reputation: cutthroat's Avatar
    Hilarious - but what if you don't really ride ALL the mountain, maybe only half the mountain, or even just the part where the trail is - are you really riding ALL Mountain, or is it more like 1/3 Mountain? And do you still need an all mountain pump?
    When I see an adult on a bicycle, I do not despair for the future of the human race. ~H.G. Wells
    Reputation: drunkle's Avatar
    this is a dumb question. there's no such thing as an all mountain pump. you don't use pneumatic tires on real AM rides. take your weenie pneumatic tires back to the pavement where they belong.
    Dec 2005
    i fill each tyre up with 20 scoops of stan's... no need for floor pumps
    Baba Booey!
    Reputation: monkeyfist23's Avatar
    Dec 2005
    OH, I didn't pick up on the sarcasm, but I am in the market for some all mountain tire levers.... suggestions?
    Quote Originally Posted by monkeyfist23
    this might be AM
    s62
    s62 is offline
    Reputation: s62's Avatar
    This thread is
    GOLD
    the goose is loose!
    Feb 2006
    if it's steel then it's too DH. my titanium tire iron is lighter.
    s62
    s62 is offline
    Who uses tires for AM, anyway? I just FALL down the mountain, headfirst. The only way to do it right.
    Me hates pinchflat
    Aug 2005
    titanium is sooo 2006 and tire levers are for pu$$ies.
    The right way to take off an AM tire is with your bare hands and use a bit of blood as lubricant if the bead does not come off
    King of vegetarians
    Quote Originally Posted by s62
    Thats how may dad and my grandpa used to do (in tandem)!Real men right there,real AM!
    the goose is loose!
    Feb 2006
    Quote Originally Posted by 545cu4ch
    that is actually how really i get my tires off the rim....my bare hands work fine.
    Me hates pinchflat
    Aug 2005
    i do too
    try to remove a double ply wire bead tire for extra fun
    the goose is loose!
    Feb 2006
    i've done single-ply wire beads. but never double. gonna have to try it.
    Me hates pinchflat
    Aug 2005
    your hands will suffer, believe me
    I nearly died when I put my highroller. Since im macho, I didnt use tire levers, I had to use a spoon to get the final part of the bead on
    My mini pump is as all mountain as they come, makes my face turn red pumping up a 2.5 tire.
    large member
    Reputation: mud'n'sweat's Avatar
    Feb 2006
    I opened up my XC floor pump and poured some Dew into the air compression chamber. That mutha' is totally AM now.
    I still haven't found the spot to put the needle into my all mountain tires. I just fill them up with straw,leaves,and dead rodents and squirrel blood. All mountain tires rock.
    AKA; Jimmy Tango
    Reputation: gop427's Avatar
    This should do the trick!
    Reputation: Gman086's Avatar
    Duuuude,
    You need to get some of those ACME All Mountain CO2 cartridges!!! They fill them near the Coors factory with only the choicest of pure mountain CO2 goodness so you KNOW your tires will be set up PERFECTLY for their specific design of all mountain fun!
    Have FUN!
    G MAN
    Don't forget to replace you crappy XC presta or schrader valves as they aren't up for proper AM punishment, they will leak AM air no matter what.
    You need real AL-Am (Aluminium-Americium alloy) valves for the job:
    Reputation: Ironchefjon's Avatar
    I just fill my tubes up with a can of dew. problem solved.
    I live in Maine and I hate lobster.
