Page 2 of 2 FirstFirst 12
Results 26 to 48 of 48
  1. #26
    Quote Originally Posted by dwyooaj View Post
    Action tec makes 20 and 21 tooth rings for standard (64) crank.
    Yes, apparently they do. Looking at a 22 tooth, however, I can't see how there's room for the bolt holes to go any smaller. But I guess they figured it out.
    Unfortunately, the inexpensive steel 20's only come in 58 BCD. The only option is titanium at $60.
    Since its apparently possible to do, why doesn't Shimano make a 20?
  2. #27
    how about this? 36t cog, 20t granny ring!
    Hey, for a soon to be 51 year old weekend warrior trying to ride the Rocky Mountains, that doesn't sound so funny.
  3. #28
    my whole body is a weapon
    Reputation: boomn's Avatar
    i wasnt serious, pedaling that gear would feel like a time machine! thats the lowest gear possible, I'll bet someone's done it.
    It's not so crazy for 29ers though!
    20x36 on a 29er is about the same gear inches as 22x36 on a 26er
    Also, looking at it in terms of the cassette... 22x36 on a 29er is the same as 22x33 on a 26er
  4. #29
    psycho cyclo addict
    Reputation: edubfromktown's Avatar
    Now that's overkill... you might have trouble staying on the bike at very low speeds.
    I have 11-34 cassette with 38/32/20 rings (compact 94/58 cranks) on a 29er which is plenty low 'n slow for any significant grade & duration climb.
    $himano doesn't make 20t in 94/58 or anything else for the same reason they are phasing out 9-speed... so you will chuck what you have and buy new stuff.
    The HG-61 will munch your freehub body/drive shell for sure. The 36t cog makes for a lot of torque... Smaller chain rings and with less exotic (and lighter) cassettes is a much better approach.
  5. #30
    psycho cyclo addict
    Quote Originally Posted by smilinsteve View Post
    The HG -61 is too heavy, but I read about someone who took the 36 off the HG-61 and added it to his XT cassette. That might be a more durable option than what I did, but too late, its paid for.
    You can get it here:
    http://cgi.ebay.com/36-Tooth-Cog-Mou...item3a64a7060c
  6. #31
    Many full suspension frames were engineered around the middle ring being 32-34 and the majority of pedaling being done in that ring. Pedaling in granny is not ideal on my Nomad and induces pedal feedback. Riding a 31 home brewed sprocket and 11-36 XT/ebay 9 speed cassette here. Riding San Diego's finest in the front and rear on my bike. Living in San Diego...
  7. #32
    I wonder the same thing! Anyone have any experience with the 20T on a 64mm bolt spacing? I used to have one on my old 5-arm crank, but it's hard to see how something that small would fit on a 4-arm crank.
  8. #33
    I currently run a 1X9 with a 32T chainring and 11-34 cog. I am climbing just fine with the 32/34 but my problem is I am spinning out on the flats. If i were to get the 12-36 cog I would change the front ring to a 34....
  9. #34
    R.I.P. DogFriend
    Reputation: jeffj's Avatar
    Quote Originally Posted by edubfromktown View Post
    Because everyone rides the same as you, has the same fitness level as you, and rides the same terrain as you?
    The hardest thing for me with super low gearing is that the momentum is not as strong when the trail is chunky. Steep non-tech trails have not been a problem at super low speeds in that regard. Anything that can help you keep pedaling instead of walking or stopping is a good thing. I have used some super low gearing setups in the past for several years. Even if one can eventually get fit enough to not need it, it may help them get to that point faster if they can keep moving, even if it is not real fast.
    Shimano doesn't make a 20t in 58mm BCD, but others do (or have) besides actiontec. Race Face made a 20t with 58mm BCD in steel and they were excellent and very durable. You can still find them from time to time on ebay. Salsa is another, but those are/were aluminum and not nearly as durable as the steel ones from Race Face.
    I'm curious to know if the freehub cares how the torque/hp is manufactured? It seems like it takes what it takes to keep your body/bike (mass) moving up a steep hill at a given speed. If your legs have the power to climb with a combination that yields x gear inches, how does it matter to the freehub how you arrive at the final drive ratio?
  10. #35
    Quote Originally Posted by osmarandsara View Post
    Unfortunately that 1 tooth change on the low end has a big enough effect that 34x12 is actually a slower gear than 32x11. A 36t ring would give you a faster top end gear ratio but actually only by a small amount compared to 32x11
  11. #36
    Quote Originally Posted by jeffj View Post
    I think I know what you are saying. The torque would be the force applied by the chain times the radius of the gear, FxR. The torque will only be enough to move the wheel, so if R goes up, F goes down, and torque stays the same with a larger cog. The potential torque is greater with a larger cog, for example if the wheel was held still while applying max force to the chain. But if you stay within your same power outputs while the wheel is rolling, using a larger cog wouldn't put more torque on the freehub. (that's what I'm thinking anyway).
  12. #37
    eBiker
    Reputation: Mr.P's Avatar
    Feb 2005
    I guess it's a matter of personal preference or riding style.
    I don't spin out on flats with a 32/11-32.
    The only time I feel I need more gear is on downhill fireroads.
    I call spinning out at a cadence of 100+.
    P
  13. #38
    Jun 2010
    Quote Originally Posted by agoura_biker View Post
    I run a 21 tooth and hubby runs a 20, both Action Tec ti. His rear is 11-30 mine is 11-32. They work very well! I have been considering running a 1x9 with a 11-36 but not until they get the weight down and give us more options.
    Brenda
  14. #39
    I can't find the picture I saw, but I think the bolt hole takes up part of the space of a tooth, so there is a little mini tooth above the hole. Hard to describe.
  15. #40
    Reputation: Jesus's Avatar
    170mm cranks + steep hills= 12-36 cassette
    I ran a 1x9 on my old bike, I race cross country on an 11-32, but I run a 12-36 on my AM bike and I love it.
    If your AM bike is on the FR side, then you are most likely on 170mm cranks. If you are on more of a FR bike, then you probably live somewhere with very very steep hills. If this is you, 12-36 is the only way to go.
    It is so nice being able to sit and comforably spin up the hill like a normal person. The tiny weight penalty of the 12-36 is of course totally invisible, the added gearing however will change your life.
    The downside is that the bigger cassette will tend to dig into your aluminum freehub body and get really stuck. I just took one off this morning and it was a pain in the ass.
    The cassette and lockring is 423g on my scale.
  16. #41
    I am a pathetic rider...
    So the torque on the freehub does matter, because if you look at what things are constant in a bike drivetrain, you can basically assume that max chain tension in a given pedal stroke is usually some fairly constant value, because it is a function of force at the pedal and the size of your chainring. This larger chain tension being applied to a larger cog would induce a greater torque at the freehub, even while yielding the same final drive ratio. This is assuming that the pedal force remains fairly constant, which in my experience/perception is not that outlandish.
    Save the Earth, Ride a Cyclist
  17. #42
    Good info. Thanks!
    Good info. Thanks!
  18. #43
    Quote Originally Posted by Jesus View Post
    great thread, as i am currently trying to figure this out.
    So for instance, i currently own a 11-34. if i remove the 11 or 12T and install that 36T from either the shimano or the EBAY 36T, i will have problems with rubbing? or you will only encounter issues if you install the 12-36 cassette "CS-HG61"?
  19. #44
    Is that Bill rated?
    Reputation: Lord Humongous's Avatar
    You can transmit maximum torque to the freehub for a given chain tension in your largest cassette gear ergo larger gears dig more into soft aluminum freehubs than smaller ones. Caveat, I can dig a fifteen tooth, the only free narrow cog on an XT 11-34, thoroughly into a DT 240 FH with little apparent effort so it's not like it matters to me.
    Well, it was a good try.
  20. #45
    20T Granny : $20 (64 BCD)
    I switched to a 20T granny a year ago and never looked back. Now my knees don't hurt on super steep climbs (anyone heard of Pumphouse Hill and Hell Hill?). Run it with the PG990 11-34 cassette and its my Secret Weapon for hills.
    This guy is selling them on Ebay for $20: eBay My World - crmxer or just search 20T chainring, it should pop up.
    He makes them out of stainless steel at his machine shop and I must say they work very well. The secret is out now...
    Curious to see if anyone else tries this setup....
  21. #46
    Quote Originally Posted by guitarjohn21 View Post
    That's exactly my set up
    Installing my 20 T chain ring
  22. #47
    Quote Originally Posted by Lord Humongous View Post
    For any given speed, wouldn't the torque on the hub be the same regardless of of gear sizes? That would have to be true to obey the conservation of energy law, right? For example, a small cog with large chain ring requires more chain tension but a smaller lever arm on the hub, while a large cog with small chain ring results in a larger lever arm, but with a lower force, to produce the same speed.
  23. #48
    Reputation: thegoodword's Avatar
    Some of the steep climbs in Idaho were too difficult on my Niner W.F.O. with a 22-23-44 front with a 11-34 on the back cassette. I put the 12-36 on the rear and have not noticed the extra weight. I have noticed easier climbing and better control on loose gravel/sand on the climbs. I have not tried swapping the 12 tooth for an eleven, but it sounds like it works fine!
Hot Deals
Contests
Latest Mountain Bike Articles
