Results 1 to 9 of 9
    66RC on a AM bike?
    Would any of you put a MZ 66 RC (150 mm) on a Blur LT?
    I mean would you use it in a All Mountain setup?
    Reputation: MattyBoyR6's Avatar
    Sep 2004
    It's a pretty tall fork, at least the 170mm set up is. Great fork, very responsive, but might slack out your rig too much. Compare the dimensions on marzocci.com to your current set up.
    Got Daytons on the Motha Ship - Cube
    Some Assembly Required
    Reputation: man w/ one hand's Avatar
    I'd slap a 170mm 05, (tall model), on there so fast it'd make yer head spin. But thats my prefrence. After riding a slack ha for so long, it makes anything else seem like I'm going OTB. I would consider a 66 SL adjustable travel an' all. Light & its a Zokie. SWEET !
    "Why are you willing to take so much & leave others in need...just because you can?"
    Quote Originally Posted by ductape
    Well, they say it can take a 160mm fork, so you should be ok. The geometry specs are measured with a 496mm fork height. Maybe a 66SL, so you could fine tune the fork height if it feels too slack.
    http://www.santacruzmtb.com/blurlt/
    Freeriding Feline
    Reputation: SuperKat's Avatar
    Mar 2005
    I don't know...My 66 (170mm) went on my Heckler and I thought it was too tall. I used that as an excuse to get a 6.6 frame.
    Sad, right?
    "If you give up your dream, you die."
    Twitter - KIKat1029
    So the 150 would be ok on a blur LT then?
    I am also considering the Heckler, it is a lot cheaper (X9 AM package and 07 Float 140 RLT + 07 Float R runs at $2535 only).
    My other choice is the MKIII expert, same price as the Heckler ($2600)
    The Blur LT option is getting too expensive for my budget...
    thoughts?
    Reputation: Hardtails Are Better's Avatar
    May 2005
    I wouldn't put a 66 (except maybe an SL) on a Blur LT. They'd be sweet on a Heckler though. What kind of riding are you going to be doing?
    66RC 150mm has a 575m a-c height. I wouldn't want that fork on my Bullit or Heckler. I run 550mm a-c height's on both my bikes. My Heckler has a 05' Z1 150mm, my Bullit has a 66 RC2X. 66 coil forks are quite heavy too @ 6.5 ish lbs.
    bb height would be too high imo
