Results 1 to 11 of 11
    Reputation: biketuna's Avatar
    5mm spacer between lower headtube and aheadset?
    Does anyone know who makes a 5mm spacer so my fork won't hit my down tube.
    I have seen the spacer from CK but hoping there was another option.
    I have a 2008 fox 36 Talas on a 2006 SC Nomad.
    _______________
    1x10 IS SO FINE on my 21.9 lbs IBIS SL-R
    11-36 XTR in the rear, 36T wide-narrow upfront
    You can get a Ventanna 7mm race (think it also comes in 3 or 5mm too). There is also a headset with the stops already built into it (can't recall who makes it).
    Chris
    the extended headset races only work with king headsets.
    they also work with Cane Creek. Ran one for a year without any problems.
    Chris
    Quote Originally Posted by grnbkr
    Also work with Hope too..................
    That puts the space between the fork and the race.
    Does anybody make a spacer that goes between the frame and aheadset?
    _______________
    reset racing from germany solved my problem. super long press in shaft on lower hs cup.
    And they made a spacer for me in 6.5mm. A spacer can every machineshop make. But dont use a short press in shaft. If its only presst in like 4mm into the frame, it will deform the head tube after a while.... then you have a problem.
    http://www.reset-racing.de/reset/ima...8-hdal_big.jpg
    otherwise use trickstuff hs with itegr, stoppers. ( trickstuff comes from some porsche developers )http://www.trickstuff.de/index.php?p=d42de1
    Reputation: tartosuc's Avatar
    CAne Creek S+5 headset..5mm higher lower cup than a normal one.
    biketuna, do a search for canfield the one + headset and you'll find what you are looking for. I recall them talking about this as I was researching that frame a while back.
    Quote Originally Posted by mnigro
    that why i suggested the cane creek s+5...thats what i have on my ONE
    Great info!!!! That's what I was looking for!!!!!! Thanks everyone
    _______________
