Results 1 to 45 of 45
    4x frames that can climb, trail frames that can be jumped?
    I have a steel DJ bike and a dh race bike. I need something in between that can do trail rides with 10 mile climbs and pedal well but still jump well. I want it to be really stiff with a thru axle rear preferably. About 5" travel. Can a trance hold up to some big jumps, with a 150mm fork? Otherwise I am considering frames like an intense tazer vp, morewood ndiza, possibly a spitfire or rampant although I am not wild about the bushing thing.
    Do any of the 6" bikes jump good enough to hit bmx type jumps?
    I am 5'8" with a 32" inseam. I ride a medium dh bike and a 22" top tube jumper. So I can probably get full leg extension on the 4x type bikes with a big seat post.
    Thoughts?
    Reputation: hartwerks's Avatar
    Oct 2011
    I can definitely say that the Rampant is CRAZY fun for ripping around on jumps and trails that aren't too technical. Unfortunately the bushing issue can be a problem if you are riding it often and hard, though they don't seem to have had as many issues as the Runes and Spitfires. The new (V2) versions of the Spitfire and Rune are running bearings instead of bushings and can be set up with thru-axle rear ends. I love the Spitfire on jump-filled trails, but it is definitely more comfortable on bike-park type jumps. It feels pretty big when you get it onto proper BMX style dirt jumps with its longer chainstays and wheelbase. For those you'd probably be happier on something like a Rampant, the new P-slope, or maybe a Killswitch.
    Reputation: zoro's Avatar
    TRC yo!
    TRC yo? I don't follow.
    I have definitely not ruled out a V2 spitfire(no V1 for me), they seem to be very close to what I want save some excess chainstay length.
    I had a Sinister Gruitr and it was nearly ideal for me as a do all bike with the short back end, low and slack, but the pivot system left something to be desired and it was fairly flexy.
    from what I have read about the intense tazer VP, commencal meta 4x, banshee rampant, mongoose nugget, norco 4x, etc, they are all super fun to ride, jump and corner great blah blah but which can double as a trail bike with long distance abilities? I am not, or will ever be an XC racer I just like some of the higher elevation rides. the bike would be set up 32t 1x9 obviously, with a long seatpost and 2 stems to choose from. a 45 and a 70-90. takes what, 3 minutes to swap a stem. 160 brakes, 2.3 minion dhf/small block 8, mavic 823's, pike 454 or revelation XX.
    Reputation: jazzanova's Avatar
    Re: 4x frames that can climb, trail frames that can be jumped?
    TRC yo! Or, Solo yo!
    Sent from my PG86100 using Tapatalk 2
    dog
    dog is offline
    sit! stay!
    Reputation: dog's Avatar
    i have a Transition Double and a Pivot M4X... The M4X is a good bit lighter, but they are both a ton of fun on the trail... i use an adjustable seat post as well... have not tried switching stems, but i cannot imagine getting regular trail bike feel out of either... Post up when you pick a frame...
    i need to develop my crashing skills...
    SC Blur TRC. I love my blur 4x, and the TRc is supposed to be the modern version. My 4x is my trail bike, set up with a pike and a dropper post.
    why not a 60mm stem? feels good enough to climb and descend. and a dropper post makes you go from xc high to bmx jumper low in the push of a button. if a new frame was in the cards for me I would chase a spitfire. the slackest 140 bike out there with and actual 140 fork. with the steepest seatpost.
    Reputation: BaeckerX1's Avatar
    Oct 2007
    What about something like the GT Distortion with its long travel front/short travel rear?
    Gotta get up to get down.
    LMB
    I have a cheaper solution than a Blur TRc yo, a short shocked Blur LTc yo. You can find them for cheaper than a TRc, and they're built stronger/stiffer than the TRc.
    140mm Fox Float 36, 126mm rear, 13-3/16" bb, 67* HTA, carbon stiff, under 30 lbs w/ burly wheels/rubber (not in pic - white Halo Freedom w/ Hadley hubs & Conti TK 2.4s) and a dropper.
    Pic...cranks were swapped out for the XT 770s...stronger, stiffer, and not much weight gain.
    Reputation: Haus Boss's Avatar
    Jun 2010
    The spitfire v2 is an extremely burly frame for a 140mm bike. I suspect that it'll hold up just fine as long as you're not going huge and riding stuff with transitions. I've heard of people doing some jumping on TrCs, but as others have pointed out, it's not as stiff/strong as the Blur LTC, but that's what you get for a sub-5 lb frame. A medium spitty with shock is just under 8 lb- more than many 150-160mm bikes.
    Reputation: ride the biscuit's Avatar
    The thing about the spitfire is that it seems to me like it would be too slack. guys that ride real dirt jump style jumps with steep lips like steep frame geometry. same with distortion...and both have too long of chainstays
    what about the rocky mountain slopestyle bike. did you look at that one? must be a few others like it but nothing comes to mind
    i think the new santa cruz bikes are more trail oriented than what OP is looking for; though i have no solid reason other than it seemed he wants a jump bike that can ride trails well not a trail bike that is ok to jump
    I suggested.spitfire.cuz he was.talkin getting up to higher elevated trails. Its labeled as the downhillers trail bike. What kind jumps are you talki. About op? Like vert style ? Or.standard trail hit and drops? As for the trance , thats a 120 bike. not sure how much geo would be affected as far a.pedaling goes. The stock setup is 69.5 @ the headtube. You endup slacking it to 68 with a 150 fork but you woukd also kick the seatube angle back another 1.5. Making it not as optimal for climbing. Yes the spitty is slack. i get the hunch the trance isnt sturdy enough when you say jump. There are bunch of other playful 140 bikes not as slack. Maybe transition Bandit at68. on the pricier side theres the intense tracer with the link in the 140 setting or the Turner 5 spot. Maybe you find one slightly used. Or the yeti 575. Again these are trail not true jump bikes. Bikes that pedal well and descend respectfully.
    You could get just any 4x suspension frame with a longer seatube, a propedal shock, and put a 150 dropper post on it. Provided the tt length and seatpost angle are similar enough to a trail bike it would climb 90% like any heavy trail bike. Wallah!! 4x with pedal freindly features. Too bad they dont make a 200mm dropper.
    Unless virtual tt end up too long and seat angle are too slck that could put you in a bad positiin for climbing. A little research on geoms in order here.
    how tall are you? whats your inseam. the 4x bike I looked at was the transition double. it has 14" seatube. short 22.5 tt for a large 5'7 and taller and 68 head angles. if your tall my 4x dropper idea is a no go. if your 5'7 you could totally do it. you could run a long dropper on bike like the transition double. and get pretty good leg extension and get the post almost out of the way.
    Attached Thumbnails Attached Thumbnails 4x frames that can climb, trail frames that can be jumped?-bikes_double_pic1.jpg
    I'm liking the suggestions of the GT and short shocked LTC. the LTC could be converted back to full travel too for certain things, even more versatility! although I had read something about the santa cruz having something of a wallowy mid stroke. I have ridden a double and they are good fun, and plenty stiff. dunno about climbing with one though. will look into that RM 4x.
    as far as jumps, stuff like the jumps by the river in whistler for instance. 15 or so foot with 5' lips.
    5'8 32" inseam
    Goggled jumps by river at whistler. Id want more than trail bike for vert kickers like that. At least an am built frame
    Quote Originally Posted by sonic reducer View Post
    ...the LTC could be converted back to full travel too for certain things, even more versatility! although I had read something about the santa cruz having something of a wallowy mid stroke.
    FYI, you're going into the fork and rear shock to reduce travel, so it's not exactly an easy conversion back...altho not difficult either...just time consuming, unless you have another fork/rear shock to just swap out.
    As for the mid-stroke wallow...in full travel, you DO need to do a bunch of air-can volume tuning to get rid of that...or go coil. The design of the suspension is the first ~ 35% of the stroke is regressive rate (or rising compression ratio). It then flattens out for ~ 5%, then it becomes a progressive rate (or falling compression ratio). You can see this on the Linkage software. The short-shocking steps you into its stroke. I shortened my stroke from 2.5 in to 2.17 in. Since the wallow point is mainly due to suspension design, the shortening of the stroke changed my wallow point to roughly the sag point...at about 30%. Trust me, the bike behaves incredibly well as a trail bike, w/o any noticeable wallow. AND, that lower BB...opens up the option to throw some 650bs on the bike and still keep its BB height under 14". This is my next mod for the bike w/ some Light-Bicycle carbon hoops
    Edit: BTW, the Blur LTc was the frame they used to compare against an aluminum V10. If I recall correctly, the dyno showed the BLTc was something like 2.3x stronger than the V10...I could be off on that...but it was def stronger.
    Reputation: honns's Avatar
    NS soda slope could be a candidate, depending on how much you want to spend.
    Quote Originally Posted by honns View Post
    i have no idea why i recommended he look at the RM slope bike when I have an NS soda FR that I love so dearly, haha!
    It could actually be pretty ideal depending on a few circumstances since the seat tube is uninterrupted (the RMs is interrupted so you'd need a dropper, which may or may not be long enough). The seat tube on the soda is 13.7", so the question is: is that enough for you to get leg extension on climbs.
    The other consideration the soda for long trail rides is its main pivot turns around the BB, which supposedly is not efficient for pedaling....if you ran it at 15 or 20% sag it may not be a drawback.
    Other than that, I can only say that NS bikes are amazingly dialed high-end bikes and at a great value point
    but in general I like Paully's modded blur...pretty cool stuff there especially when it comes to the curve rate as it relates to the mini link bikes usually being better at pedaling and going quick over square edges than being great platforms for jumps and freeriding
    Dec 2011
    I was after a fun 26" all mountain bike that i could jump and would climb well.
    I also wanted a suspension design that helped with pedalling efficency. ie: DW link, Vpp2, Quad link, fsr~.
    Top of the list was the Ibis Mojo HD followed by the Santa Cruz Nomad.
    Of course my mate had to get a new bike as well, i opted for the Mojo which i should get in 2 weeks.
    My mate tried to get me to get the nomad, he of course did and it arrived 3 weeks ago.
    I got to test out his bike last week and it feels great. the Vpp2 performed well.
    he had no trouble climbing and it was stable over jumps.
    It is miles ahead of his previous merida 140mm bike which is a single pivot linkage activated shock (faux bar).
    I can wait to get the mojo and compare it to my current marin attack trail (dw link vs. quad link 2).
    My 2 cents.
    Dec 2011
    I vote for the pivot 5.7
    I take my 5.7 to my brothers bmx practice all the time. It's funny to watch me clear doubles and tables and rail the berms on a 6in bike. My buddy goes out there and rips on his 5.7 getting 6+ ft of air on the tables.
    I would say go for the mojo HD in the 140mm .
    However, they are releasing a new bike on Monday.
    It is rumored to be a Mojo HD 650B...
    Not sure if you want bigger wheels for jumping or not.
    Reputation: scmalex's Avatar
    What about the DMR bolt (long)? Looks like a rad bike!
    4130 cromo, 125mm travel, ss or geared, dropper post routing, etc. this would absolutely kill jumps AND trails!
    Products Frames Bolt Xl DMR Bikes
    DMR Bolt [Long] ? First Ride Review - BikeRadar
    i've been looking for a similar purpose bike for next year, something 160mm travel or under, light, poppy, responsive, jumps well and can be thrown around.
    so far my top choices are ...
    the banshee spitfire, which seems like a chargey/fast, likes to be pushed kinda bike, but from what ive heard it jumps well on bike park type stuff, actually seems to me like the ideal bike park bike since most parks i ride are better on 5-6 inch bikes than DH bikes.
    specialized stumpjumper carbon evo seems like a super light playful bike, probably not quite as good as something like the spitfire for charging hard but better if you like to really hop around?
    commencal meta sx and am
    transition bandit 26, seems kinda like a cross between a spitfire and stumpjumper, saw some guy riding at keystone with one last year and he was showing up guys on DH bikes, thats why it caught my attention but it does seem like a pretty jumpy playful bike.
    transition covert if you want a lil more travel and maybe a little more freeride oriented.
    or what im really wanting to somehow work for me is the new specialized enduro sx
    SOC13: Specialized Launches Limited Production Enduro SX Race Bike
    so long as you seated position was good, and it pedals well, that thing could be an amzing trail bike, id have so much fun hopping around blasting through corners on it. could probably be built up very light also.
    and finally if you want a hardtail look at the stanton slackline, ive got one and its pretty much a DJ/4x inspired frame that can take 160mm forks. ive got it set up with a 150-120 travel adjust fork and in 120 it DJ's better than my old DJ bike and in 160 i can keep up with my friends on their 160mm enduro bikes on trail rides until it gets super gnarly, but if its fairly smooth im faster. it just feels like you're riding on a spring, just wants to hop around and pop out of corners like crazy.
    Quote Originally Posted by scmalex View Post
    dude the video for this bike is bad azz. like bmx race 4x trail bike. not huge hucker more flow and go. im not a hucker. old school trusty 4130 chromoly. less fear of frame fatigue. you just put a new bike on my want list. this bike is soooo cool
    9.1 lb on that dmr bolt. ouch!!!!! ffffff it. I still want one. the geom is way up my ally and I bet it would be harder to brake that 4130. I would abuse her so bad. rebuilding wheel all the time. yeah!!!!!!!!!!
    Jun 2012
    that DMR bolt video was tiiiiiight
    Quote Originally Posted by akiracornell View Post
    thats the downside. the bike is basically the same as the gt distortion except its wayyy cooler. also, any bike shop that can order through bti (basically all of them) can get dmr products.
    Also check out some freeride/am hardtails like the ns surge. i love my surge! most fun bike i've ever owned. you can jump it, climb it and bomb downhills.
    I like bikes
    Reputation: ghglenn's Avatar
    Rocky Mountain Slayer SS ?
    The older I get, the faster I was.....
    Yeah the bolt looks so sick and fun until you read the frame weight.
    I think it must be more due to designing it to withstand the extreme hate-huck more so than just the price of admission for a jump-oriented fs steel bike...cotic has a steel fs with 150mm travel that weighs 7.6lbs...so only a little more than alu counterparts compared to the bolt
    Reputation: Fix the Spade's Avatar
    Quote Originally Posted by ride the biscuit View Post
    I think DMR's mistake was being honest about the weight.
    My L Rocket with a Monarch weighs 9-ish, with the Stoy it was north of 10. Granted the claimed weight is for a medium but it still sounds a little optimistic.
    The flip side is that it feels bullet proof, a Nomad (al) weighs nearly 8lb with an air shock, a medium Rune weighs 8.5lb, so 9lb isn't exactly shameful for a hard use bike. Both the Bolt and my Rocket sit firmly in the hard use end of 'AM' bikes, that kind of bike's never going to have a weenie pleasing frame weight.
    Check out the Felt Compulsion. Adjustable from 150 to 160 travel, and with the Equalink set up they are great pedelers. Smart rear caliper placement also. They are available in carbon or aluminum.
    Quote Originally Posted by Fix the Spade View Post
    That's cool you have one. So what's the verdict? Does steel make good sense on a FS?
    I love my steel is real evil DOC, but just not sure whats the point on a FS.
    And can you separate the benefit of steel vs having a beefy 150m frame? ...and I'm asking that from the basic opinion that a little extra weight makes a bike hold a line and feel better descending and jumping...so what's due to steel and what just due to weight? (If that makes sense, sorry I'm on my phone).
    yeah and its too bad it weighs so much, i feel like its pretty unnecessary, there are 6-7lb frames that can take an absolute beating, and having that extra weight can kill the "fun" of a bike. now ive never ridden a bolt, and the design/geo looks like a freaking blast, but I feel like loosing 2-3 lbs would only make it a bit better and more fun to ride.
    from the bikes ive ridden, theres definitely a point with the weight of the bike where it just feels too sluggish both in the air on the ground. and when your looking for a 4x inspired bike, you want something super snappy and poppy, which is hard to get out of a bike if it weighs 35 lbs.
    The other thing about the bolt is that it has a concentric pivot meaning it may not pedal that well ala bass and killswitch. Anyone know for sure?
    Reputation: 53119's Avatar
    Nov 2008
    @sonic- have you tried an older spesh sx ss/4x frame? it's a 16" st but only 100mm of squish. i run 120mm up front. it's great to jump with but not if your trannies and backsides are dh chunky. you could run a long with a 40mm stem & the front wouldn't wander on a climb. It's got a long wheelbase for a 4x and ultra low bb for the same purpose. so, it corners like a slot car and super easy to pump but a little tricky to manual cuz of wb. it's a burly set-up.
    That Blur LT Carbon is on sale now...
    I ride a GT Distortion with a dropper post and a 454 Pike up front. It sits at 140mm when riding trails and I can dial it down to 110mm when jumping. Super fun bike that climbs great.
    Short answer, really nice bike.
    Longer answer, it's very long and slack, low bb, think small downhill bike rather than big trail bike. Really stable, really fast, the suspension is pretty firm (my set up) and it works well. The weight I don't notice except when it's time to lift it over a gate. In tight twisty trees it can be hard work to pull the front wheel around, but across more open or rocky ground just stay off the brakes and fly.
    As for steel vs everything else it's hard to tell how much is the material and how much is design. It's extremely stiff, the suspension pivots have 15mm axles and 35mm OD bearings, compared to most bikes they're noticeably beefier, the 12mm rear axle doesn't hurt either.
    The biggest difference I've noticed is the silence of this frame, against the sort of hockey stick thwock noise carbon makes or the rattling of alu bike this one is all but silent. Occasionally I get a quiet bong sound when a big stone hits the down tube, but nothing else. It's also very resistant to dents, which is nice.
    I've had one since May last year and it's been reliable, nothing's worn out in that time. As a whole bike I can thoroughly recommend it.
    meow meow
    Reputation: b-kul's Avatar
    blkmrkt roam with 2 shocks. a short one for when you want to get jumpy and the longer one for letting it rip.
    I am currently building a Cotic BFe up with a Talas 150/120 fork. I havent had a chance to ride it yet, but it seems like it might be what you are looking for. Short chain stays, medium short wheelbase and geometry that will take anything from 100-160 forks.
    Honestly, it is killing me to see it sitting in my garage unrideable. Pretty sure that bike is going to rip.
    meow meow
    also, i definitely check out the nukeproof mega tr. vital has a review up for it.
    Just wanted to follow up on this thread by saying I ended up with a 2013 SC Blur LT carbon with 142x12 rear. it's one of the funnest bikes I've ridden. For the weight it has to be one of the stiffest frames around. I have it built with a fox 34 talas, 5mm offset rear shock bushing, 2.35 minion dhf's, havons, 1x9 drivetrain, 70mm stem and a reverb post. With the fork on low and some extra air in the shocks and tires it dirt jumps excellent. Nearly as good as an actual slope style bike. With stiffer wheels and smoother tires than I have it would be a really wicked jump bike. for general purpose trail riding it is stellar but that was already common knowledge. Corners like mad and hooks up on rough climbs. Only when pushing it to near dh bike pace down steep fast stuff does it get a bit scary and the wheelbase feel a bit short and headtube steep. I would definitely consider going to a 160 fork and possibly an angleset but that would possibly detract from the jumpiness.
  1. Design Logic "Da"-Trail frames for sale
    By Design Logic Bikes in forum Cargo Bikes
    Last Post: 03-02-2013, 11:00 PM
  2. Replies: 3
    Last Post: 06-12-2012, 10:26 AM
  3. Gt frames, orbea frames
    By kamidsake in forum Bike and Frame discussion
    Last Post: 02-14-2012, 08:19 AM
  4. Prices on Trail SL frames?
    By dhouskee in forum Cannondale
    Last Post: 12-05-2011, 10:44 AM
  5. Sette Frames vs. Motobecane Frames
    By motoroil in forum Bike and Frame discussion
    Last Post: 11-08-2011, 07:08 PM
