Results 1 to 19 of 19
Thread: 32lb Hardtail
    Apr 2013
    32lb Hardtail
    Hi everyone
    I have finished doing up my 17'' frame hardtail bike with new 80mm travel forks and stuff.
    I bought some scales and it weighs about 31.5/32lbs
    Is this too heavy? For proper XC and fast riding?
    And if so, should I buy lighter components or a whole new frame
    Its fine for riding, but i know it would be much easier on hills.
    Many thanks in advance!!
    Reputation: thickfog's Avatar
    Oct 2010
    Re: 32lb Hardtail
    If you like it and it doesn't bother you, who cares wear others' opinions are.
    It will keep you in shape and make you a stronger rider that's for certain!
    CRAMBA Chairman
    Apr 2013
    Great point!
    If i stick with a heavier bike then later upgrade it will be like riding a a feather.
    Luckily i can easily keep up with people on a 2 grand bike.
    Whats the weight of yours?
    And thanks for the help
    It is a bit heavy but it shouldn't really bother you unless you're racing it.
    Can you do without the front gears? (assuming it has them).
    Does it have any particularly heavy components that would be cheap to upgrade?
    Reputation: millertm's Avatar
    Look to your rims, I too had a 33 lbs HT (2012 Spech Carve). I ditched the liners and heavy tubes and dropped 4 lbs of wheel weight. Made a huge difference. I did have the thick goo filled $11.5 tubes that were close to 750 gr and liners were ~200gr. If you have the stock tubes you should drop a couple lbs that way.
    Mark
    2012 XXL Carve Expert
    Reputation: bigfruits's Avatar
    Mar 2011
    what frame and parts do you have?
    32lbs is not bad for a beefy long travel AM hardtail but you built an XC bike which is a different animal.
    your wheels and tires are prob the first thing to upgrade like Mark said. Losing weight from the wheels will make the bike feel lighter than a lighter frame/fork.
    read about rotational mass and bike wheels.
    like you and others said, you will get a better work out with a heavier bike and when you do upgrade or change bikes, it will seem much lighter.
    Reputation: MSU Alum's Avatar
    As others have said, as long as you like it....but, how did you manage to make it that heavy? I'm just curious as to the build on a HT that would put that much weight on.
    R.I.P. DogFriend
    Reputation: jeffj's Avatar
    That's not unusual for a modestly priced hardtail. It's likely there's a little bit of extra weight on just about all of the parts, but I would examine the tires and tubes first. If you're riding all-mountain terrain, I would go too narrow or minimal with the tread, but there could well be some weight to shed there, and that would be the most noticeable place to lose some weight if it's there to lose.
    Many modestly priced hardtails have boat anchor stems and seatposts too, so that is the next place to lose some weight while not spending a lot of money. The fork and wheels probably have some heft too, but that is going to be expensive to replace those and before you do that, you may want to examine the option of upgrading the entire bike if the weight is bugging you that much. Unless your disposable income is just laying around and begging for something to do, I wouldn't worry too much about it. Much more important to ride and have fun.
    Apr 2013
    Thanks for all the reply's!!!
    I need the front gears The reason the bike is heavy it that it was originally cheap, (95) so everything about it is not built to be amazingly light, including the frame/components/wheel.
    I think your right about wheels, rims and tires, but it already has slick mtb tires.
    I weighed one wheel and it was 6.5lbs, so both wheels are almost half the bike weight, but as i said the parts are all rather cheap, frame still aluminium but it would mean upgrading a lot to get down to 25lbs!
    Lastly, your right, its much more important to have fun, and a few lbs cant make a big difference really? surely its the same as having a rucksack on?
    Thanks again!
    Reputation: mtskibum16's Avatar
    My steel all mountain hardtail is around 30lbs with a heavy 140mm travel fork (Pike) and heavy wheel/tires. The rest of my build it pretty lightweight (Shimano XT).
    If yours is an inexpensive/department store bike, I'd ride it as is until you're no longer happy with it, then buy or build a new bike with lighter weight in mind.
    Apr 2013
    Ok so it would be reasonable for an AM but not something with 80mm travel and less sturdy.
    Its not exactly a department store bike, just an inexpensive XC hardtail
    GAME ON!
    6.5 lbs for one wheel?? jesus. my entire wheelset is less than 3.5lbs
    RIP Adam Yauch
    "M.C. for what I AM and do, the A is for Adam and the lyrics; true"
    Oct 2010
    Re: 32lb Hardtail
    Quote Originally Posted by saturnine View Post
    I think he means with rotor tire, etc. My first low end wheels and kenda nevegals weighed near that (rear). Not uncommon. Just ride it. Have fun. Upgrade as you can afford it.
    http://biketubes.blogspot.com/2010/0...eight.html?m=0
    CRAMBA Chairman
    GAME ON!
    wheels would be the best place to start. it's what makes the bike feel heavy and sluggish.
    RIP Adam Yauch
    B.Ike
    Reputation: ElwoodT's Avatar
    Mar 2011
    You don't get a better workout with a heavier bike. You'll just go slower.
    Formerly of Kent
    Reputation: Le Duke's Avatar
    ^^This. Power won't change. Just slower.
    Death from Below.
    Mar 2011
    don't upgrade the wheels. save up and buy a new bike in the future. enjoy.
    Apr 2013
    Hi and thanks.
    It would improve fitness if I keep up the same speed and push more surely?
    I think if anything I would upgrade the wheels (because of rotating mass) but probably just leave it and live with it until I get a new bike frame, as it would be a bit pointless to upgrade every component on a cheap heavyish frame.
    Reputation: jtnord's Avatar
    Jun 2010
    Just ride it and enjoy it! You will want to upgrade things soon enough. Other than bars, stem, grips, seat, pedals, you should leave it alone. Save up as others mentioned for a better bike in 1-2 years.
    6'5" 230lbs
    My Build: Vitalmtb - Bike Check
  1. Hardtail or not to hardtail - thoughts and advice please
    By Velosprocket in forum Specialized
    Last Post: 02-15-2014, 07:57 PM
  2. why no AM hardtail?
    By JRR in forum Niner Bikes
    Last Post: 11-24-2012, 09:22 PM
  3. Should I get a hardtail?
    By kikoraa in forum XC Racing and Training
    Last Post: 10-16-2012, 10:05 AM
  4. Hardtail to FS back to hardtail?
    By VTSession in forum All Mountain
    Last Post: 08-15-2012, 08:16 AM
  5. Session 9.9 (32lb. Complete) build in Trek Section...Here is link
    By OneEyedHito in forum Downhill - Freeride
    Last Post: 02-02-2012, 08:20 PM
