Page 2 of 2 FirstFirst 12
Results 101 to 136 of 136
Thread: 2016 Revel X
  1. #101
    I got the same message for Europe. You can also order them from iron stable in Taiwan.
  2. #102
    Dec 2009
    Nice!
    Any official word on pricing or go by previous numbers?
  3. #103
    Quote Originally Posted by lacanuck24 View Post
    Nice!
    the saga continues:
    turns out X Fusion is planning on shutting down their santa cruz location. all X Fusion products will in the near future be serviced out of BTI or QBP - doesnt seem like the Revel will be a staple amongst the offereings from these distributors. Santa Cruz office just received their last shipment of goods, they dont plan on receiving any more inventory at that location.
    That doesnt mean that the Revel wont be added in the future...so its still looking to be tough getting one of these forks....
  4. #104
    Quote Originally Posted by ledude View Post
    the saga continues:
    shocking.
    **I don't subscribe to threads. Just PM me if you have a question/comment for me. **
  5. #105
    Jun 2010
    They are definitely available.
    Got mine easily, I just sent a mail to iron stable. that easy.
    I just got the bike back tonight, with the gold edition fork on it.
    I still have to try the fork, so that s tomorrow.
    one thing: no manual came with it, just basic warranty etc. Nothing available online.
    Is there a second air chamber that can be adjusted or just the main one ?
  6. #106
    Quote Originally Posted by matt2000 View Post
    Sounds legit from a guy who joined 7 years ago and has literally 1 post. For a product that's been "pending" for like 5 of those years.....
  7. #107
    Jun 2010
    oh boy... I guess you did try to call iron stable in taiwan, before writing the above post. No? didn t think so...
    So for the other guys following this post, call iron stable ( listed on x fusion's website) and you ll get one. Their singapore sub had 2 other bikes with the black version mounted.
    Below the link to their page. revel « 搜尋結果 « 鋼鐵馬廄 Iron Stable. they respond to emails very fast. I ll post a pic of my bike with today's paper for the doubters...
  8. #108
    Jun 2010
  9. #109
    Jun 2010
    I should add that I started looking for the fork 2 weeks ago... frankly I was stunned how quickly i got my hands on one.
  10. #110
    I ordered mine last week. There will be only one offset option (46mm) 27.5 but it can be tuned for a 29" hope to get it in 6 weeks
  11. #111
    Aug 2016
    Quote Originally Posted by chrisingrassia View Post
    You sure called that one. You're awfully upset you don't have one of these, huh?
  12. #112
    Iron stable is legit....Patrick can hook you up.
  13. #113
    Jun 2010
    first feedback after about 8 hrs of riding ( my previous fork was a pike).
    it feels way stiffer than a pike fore / aft. very noticeable on hard breaking.
    dials for HSC and LSC are super effective, the 12 clicks of adjustments each make an impact. You can dial the support through the stroke and that is way better than the pike
    It is still not as smooth as my 1y old pike, particularly at the beginning of the stroke.
    On the revel you can feel the keyway sliding inside, almost like the internals have not yet bedded in completely. Everything still feels tight. That being said, my pike smoothness improved over time, and when comparing new and used Revel, previous reviewers also noted that used revel were a lot smoother than new ones. I will keep you guys posted on how this evolves. So far happy but i would definitely like the fork to require less breakaway force for it to be total winner. Time will tell if the fork gets there in a couple month.
  14. #114
    Give it a few rides...the fork needs to break in (just like you noticed).
    The breakaway sensitivity definitely increases as it starts the bed in. This is a heavy fork, no denying that. I welcome the extra weight though as it seems to help wi TN stiffness and assist in the damping sensitivity.
  15. #115
    Jun 2010
    Got it. hopefully that won t take too long!
    agreed it is not a lightweight but it doesn t seem to be an issue when riding. Also lower taleral stiffness does not create any problem. the fork is still very precise and quite enjoyable in fast rough corners.
  16. #116
    Any more riding on that revel fork?
  17. #117
    Jun 2010
    very little. pump track only. The fork is smoothing. One interesting thing that i did not notice initially: there is a note inside the owner manual etc that says the fork is designed to react to bumps, and that therefore the fork does not react properly to a " push test ". For a "push test" to be performed, the rear of the bike should be off the ground so that the fork is vertical / perpendicular to the ground.
  18. #118
    Dec 2009
    "regular" parking lot tests are pretty worthless with this fork.
    I've gotten maybe 15-20 hours on my second Revel and the difference between it and my first fork is obvious but expected. It took probably 40+ hours to really break in my first Revel, but there was a lot of experimental adjustment happening there that probably wasted some time. Now the fork is awesome. Getting the sensitivity I need on all sizes of impacts.
    The parking lot test isn't great for sag setting and you can feel a lot of twist/flex in the fork if you wedge the wheel against something. Very disconcerting till you hit the trail. When things get going the fork feels stiff and composed. I have no fear running it strait into things. It does what I want it to do without any complaints or angry feedback.
    Hopefully having the tune info from my first fork will reduce the wasted break-in time for the second. A lot of patience waiting for the break-in.
    Oh, air pressure. Not at home right now, but if I remember right the fork chart recommends aboot 100psi+ for my body weight. I'm only 5'8/230lbs - 173cm/104kg with my all my gear. But my fork was super stiff at that pressure. I've been experimenting with 78-85psi to get the right feel/bump sensitivity
  19. #119
    Jun 2010
    agreed on pressure, i am running much lower.
    M
  20. #120
    Jun 2010
    true on the parking lot setting not really working for setting the sag: what was your process to get it right?
    ps: i ll check my air pressure, and will see if I run it like, around 20% to 15% lower than factory.
    One more thing: did u experiment with oil volume ? the factory is telling me that this is how I can reduce the air spring volume ( like with token).
  21. #121
    Dec 2009
    I never really worried about the sag since the process requires multiple people. Lazy I guess.
    I haven't experimented with oil volume yet either. I've been pretty happy with the performance of the fork overall, but I'd like to mess with it a bit. I feel like I'm not getting the last 5-10mm of travel very easily, hoping playing with the oil will fix that. Man I wish these forks had tokens. probably my only real gripe
  22. #122
    Jun 2010
    i am getting a second one :-)
    I ll be putting it on a hardtail this time around.
  23. #123
    May 2016
    Gold looks ok on black
  24. #124
    Jun 2010
    Nice!!!
    thinking stanton switchback titanium + black version.
    what is that rear tyre?
  25. #125
    Jun 2013
    Quote Originally Posted by ideate View Post
    Came here to say that this bike looks amazing.
    roots, rocks, logs, downhills, jumps, drops, chutes, climbs...repeat
  26. #126
    Feb 2014
    Does the new revel have the Same dual positive air spring as the first one from the limited Series? If no, how is the Support without cranking in lsc?
  27. #127
    Jul 2017
    What price did you guys get from Taiwan ex. shipping?
    Looks pretty sick!
  28. #128
    Jun 2010
    single positive air chamber. so only one to adjust. I find that the support is naturally good, and that the LSC is also quite effective along its range.
  29. #129
    Jul 2017
    Thanks for the feedback, how much did you pay for it excluding shipping and taxes?
  30. #130
    Jun 2010
    retail price. it is on iron horse TW website.
  31. #131
    Jul 2017
    Thanks, do you have any links? Do they have different color options?
  32. #132
    Feb 2014
    Quote Originally Posted by Rodent View Post
    Just google, found it pretty easily .
    Can anyone compare midstroke s upport and Sensitvity to those of a lyrik or float 36?
    Please: -)
  33. #133
    May 2016
    Just read reviews of something with a roughcut damper in it like the sweep to compare.
  34. #134
    Test Monkey
    Reputation: Deviant_MechE's Avatar
    Dec 2015
    Just picked an all black one up from Iron Stable a week ago. Super impressed with the fork. I was coming off a DVO Diamond and this thing blows it out of the water. Small bump is fantastic and it remains controlled over brake bumps, roots, drops, etc. Even fresh out of the box the thing ate curbs. I'm light enough at 155lbs that I don't notice a difference in flex. I am running 10psi lower than suggested but with the high and low speed compression dialed in a bit I find it more than composed enough.
    Broke it in with some laps and collegiate races up in Steamboat and it was flawless all weekend. Plus it looks sick! All in all I'm sold.
    Pic taken before brakes fitted, I couldn't resist with how rad that thing looks:
  35. #135
    Feb 2014
    Quote Originally Posted by Deviant_MechE View Post
    Review please!
  36. #136
    For all you guys from america, there is an X Fusion Revel X for sale there:
    https://www.ebay.com/itm/X-Fusion-Re...53.m1438.l2649
    Unfortunately for us European guys the hassles for bringing bike parts from the US is so big that it is not an option.
  1. Replies: 26
    Last Post: 04-21-2016, 07:36 AM
  2. Replies: 2
    Last Post: 11-15-2015, 10:15 AM
  3. Giant Revel 1 vs Revel 0
    By Joey Jiggles in forum Giant
    Last Post: 11-09-2012, 10:36 AM
  4. Revel 3 Disk (325) or Revel 1 (399)
    By Notsoseriousbiker in forum Giant
    Last Post: 03-06-2012, 12:43 PM
  5. 2011 Revel 1 MUCH lighter than 2012 Revel 1
    By Gorky_Park in forum Giant
    Last Post: 10-14-2011, 06:46 PM
Members who have read this thread: 11
