Results 1 to 21 of 21
    Braugh Bro.
    Reputation: Buggyr333's Avatar
    2013 Transition Covert with a 180mm fork?
    Toying with the idea of building up a covert as a Am/Freeride bike with a 180mm fork. Wondering if anyone else has done this. I know that a lot of people run SC nomads and Ibis mojos with 180mm forks, and I have one friend with a Titus El Guapo with a 180mm fork, and another with a foes FXR with a 180mm fork, and both of their bike's feel good. So I figured, being in the same class, the covert would handle a 7 inch fork well. Any thoughts?
    I kind of prefer a highish bottom bracket anyway (i like chunky rocky trails)
    Stock geometry looks long, low and slack enough to pull it off fine.
    As long as the frame is rated for the extra leverage a longer axle to crown ads and you want the slacker angles and taller BB do it. 180 forks are stiffer than 160 forks too so you gain more than just 20mm travel and altered geo.
    Reputation: ride the biscuit's Avatar
    A lot of people seem to be fine with doing that, but I didn't like it on my last bike. i put a 180 float on a rune...ended up liking it best at 160. for me, throwing off the geo was not worth the extra travel
    if you are willing to deal with the weight of a totem, you could have external adjustment so you can dial it in for whatever you're riding that day
    The original rune had a higher BB and shorter WB then the Covert does. You need to start with something relatively low/long/slack.
    Braugh Bro.
    Sounds promising. I may have my heart set on this build. Never feel like I used the last inch of rear travel on my 7" freeride rig anyway.
    fascinating member
    unless the bike is spec'd for a 180 i wouldn't do it. tried it also and didn't like it. went back to a 160
    bolton trail info
    bmbc1st @ yahoo.com
    support http://torontooffroad.blogspot.ca/
    Braugh Bro.
    If I don't like it I have an extra 160mm fork laying around. So switching back won't be too hard.
    question is; does the warranty cover using a fork that long? (I doubt it) if not that means the extra leverage could break the head tube (and then you!) call transition and ask them if that frame can support that fork. Kinda sucks that they used to make a pedal-friendly 7" bike ('10-'11' blindside) but like many bike companies...not anymore.
    '11 transition blindside
    '10 sc butcher
    EMR
    EMR is offline
    Sep 2012
    Email transition. I've emailed them in the past and they are very responsive and obviously knowledgeable about their products. They should know if people are running this set up and will be able to clear up any warranty issues.
    Guys from Transition said on Transition forum lately that you can use 180mm fork and it will be no problem.
    Braugh Bro.
    I'm sure headtube strength is not an issue.
    Transition overbuilds basically everything. One of the things I like about the covert vs. other AM frames.
    Trust me, you don't need to put a 180mm fork on a Covert. If you need a fork that large, you should be getting a different frame first. Learned to do more with less travel.
    Adding on to what arkon11 said...the Covert is heavy enough, adding a 180mm fork is just unnecessarily weighing you down even more. The Covert is meant to be pedaled too, but if you want to just build a FR bike, sell off the frame and pickup a TR250.
    Quote Originally Posted by bobby_tables View Post
    The difference in weight between a 36 180 and 36 160 isn't that much. It depends on what models you are comparing but the difference can be less than 200g. That's like switching from a float to a dhx air. Switching between a lyrik solo air and coil totem is different, but a guy can def keep the weight penalty under .5lbs and gain rigidity, BB height, slacker angles, and 20mm extra travel. I call that a pretty good compromise for riders that will benefit from the above changes.
    My nomad has a different personality with a 180. It's quite a bit more capable when it comes to chunky tech, and FR, but it's still light enough to climb whatever. No way would I trade my nomad with 180 for my old bullit or vp free. 6" with 180 fork is a great set up if your riding and trails call for it.
    Braugh Bro.
    Some of us don't really put weight as a priority. My current AM rig (gt force) weighs in at 34lbs, and it feels light to me. Heavier bike means more of a workout. It's more about climbing geometry and cabability. The Tr250 has no FD mount (a must for climbing in Socal) and a lax seat tube angle, which is not what I want. And besides its more than 500$ more.
    I'm with stupid
    Reputation: hitechredneck's Avatar
    See if you can find a blindside v5 seems like they are coming in with in a pound of a beefy built covert.
    Reputation: drakche's Avatar
    Nov 2012
    Just to chip in.
    This was in an email from Lars;
    It should be ok to use a 180mm fork on the Covert, however we haven't tested with this specific configuration. I wouldn't go higher than 170 - 180mm fork.
    I asked him, cause I plan on running it with 180 Durolux
    Then what's the point of slapping a 180mm fork on? The Covert is plenty capable on the downhills already. My point was that it just seems superfluous to add a 180mm fork, skew the geometry and add unnecessary weight when you don't need to.
    Braugh Bro.
    For fun.
    i say if you want a big fork on a Covert run something like a fox 36 160mm or rockshox lyric (545 a-c height),instead the fox 34 160 that the build comes with (534 a-c). i really dont understand why fox made them shorter than the 36s. Oh, and maybe also an external lower headset cup. Doesnt sound like a huge diffeernce but should slack it out closer to 66-66.5and I think that would be the sweet spot. I agree with others, I think a totem is overkill for the covert. But I love totemage on my Blindside v5! for a 7" bike its very light and pedaling-friendly .
    '10 sc butcher
Hot Deals
Contests
Latest Mountain Bike Articles
