Results 1 to 6 of 6
    2013 Remedy 8 Rear Axle
    I am trying to find out what size the axle is on a 2013 Remedy 8. The precious year used a Shimano 525 hub, but all I can find out about the 2013 rear hub is that it is a Bontrager sealed bearing hub. I looked at the wheel itself and cannot find anything indicating the size. I do not know enough by sight to tell the size. I have been looking for hours on the Internet but haven't been able to find it. HELP!
    rear should be standard 9mm QR
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by Dominic49 View Post
    Standard rear axles for open dropouts are 10mm. Fronts are 9mm.
    mtbtires.com
    Comes stock with a 10x135 QR however the QR skewer is longer than average in order to fit through the ABP system. They are also convertible to 12x142.
    Ok, 10x135 is what i thought it was. In order to convert it I assume I need the ABP convert kit from Trek? Thank you all for the info.
    Yeah...and it's not cheap.
    converting Remedy to 12 x 142
