Results 1 to 37 of 37
    r99
    r99 is offline
    2010 Specialized Enduro: A long term review from an average guy. (With Pics)
    A little about me:
    I rarely race. I am not affiliated with a bike shop or bike company. I love to descend fast and climb technical trails. In the past I have owned a Giant Anthem, Fuel Ex, Santa Cruz V10, round tubing DHR and Giant Glory. I have spent a little time on friends 160mm bikes too.
    I purchased a 2010 Medium Enduro Comp in August of 2010.
    I have ridden the Enduro about four times a week since it was purchased eleven months ago. Each ride includes at least a thousand feet of climbing and descending.
    The Bike:
    <img src="http://i206.photobucket.com/albums/bb40/RyanBike_photos/EnduroPic1.jpg" border="0" alt="Photobucket"></a>
    The Build:
    Frame: Medium 2010 Enduro Comp
    Fork: Rock Shox Lyrik with Mission Control DH Rebound and Compression Damper (No Travel Adjust)
    Handlebars: Easton Haven 711mm low rise
    Stem: Race Face Atlas 70mm
    Wheels: Hadley hubs laced to Sun Singletrack rims
    Tires: Maxxis Minion DHF 2.5 EXO
    Pedals: Shimano PD-M647 DX
    Almost Everything Else: Stock
    Weight: More than thirty pounds less than forty pounds
    Key upgrades:
    If you are like me and descending is your primary goal the Enduro comp only NEEDS one change. The Lyrik performs far better with the Mission Control DH Rebound and Compression damper. It costs about 200-250 dollars.
    My take on The Geometry:
    Descending:
    The Enduro is long, low and slack. It is made to feel like a downhill bike and it does.
    The Head Tube Angle is 66.5 which is as slack or slacker than bikes like the Reign X, Nomad and Mojo HD.
    The Medium Enduro has a longer wheelbase at 45.3 Inches than may of its competitors. The Mojo HD has a wheelbase of 44.64 inches; the Reign X is 44.88 and the Santa Cruz Nomad is 44 Inches.
    The Enduro has a BB as low or lower than many other 160mm bikes at 13.78 Inches.
    <img src="http://i206.photobucket.com/albums/bb40/RyanBike_photos/PickG-out.jpg" border="0" alt="Photobucket"></a>
    Climbing:
    The Endruo excels at climbing steep technical and loose trails.
    The Enduro has a steep seat tube angle, and a short chain stay.
    The steep seat tube angle is 75 degrees which is slightly less than the Trek Scratch (75.6), but is steeper than the Nomad (71.5) Reign X (72.5) and Mojo HD (71). I think the steep seat angle makes it easier to get my weight forward and keep the front end under control on steep climbs.
    The Enduro’s chain stay is relatively short when compared with other bikes. I think that the short chain stay gives me better traction on steep loose climbs because my weight is on top of the rear wheel. The shorter chain stay probably makes the front wheel want to wander a little more, but on the rocky loose trails I climb rear wheel traction is more important.
    Compared with cross country bikes the Enduro is heavy, but I do not think its downhill friendly geometry takes away from its climbing abilities. My last bike was a 2008 Trek Fuel EX. I find the front end is easier to control on the Enduro on steep climbs than the Trek. Maybe the difference is I am a better rider, but I only have the Enduro to thank for that. Since I purchased the Enduro I ride more because riding is more fun.
    <img src="http://i206.photobucket.com/albums/bb40/RyanBike_photos/Uphillsequence1pic1.jpg" border="0" alt="Photobucket"></a>
    <img src="http://i206.photobucket.com/albums/bb40/RyanBike_photos/Uphillsequence2pic1.jpg" border="0" alt="Photobucket"></a>
    Can anyone name this trail?
    The Suspension:
    The rear suspension is very active and has been a great match for the loose rocks here in San Luis. The most important suspension quality for me is consistent traction while flat cornering. In this category it has performed better than any other bike I have ridden, including downhill bikes.
    <img src="http://i206.photobucket.com/albums/bb40/RyanBike_photos/PickCornering.jpg" border="0" alt="Photobucket"></a>
    The rear suspension tracks very well through rocks and the rear triangle is stiff. It holds lines and pedals through rock gardens far better than I expected.
    <img src="http://i206.photobucket.com/albums/bb40/RyanBike_photos/PickRocks1.jpg" border="0" alt="Photobucket"></a>
    <img src="http://i206.photobucket.com/albums/bb40/RyanBike_photos/PickRocks2.jpg" border="0" alt="Photobucket"></a>
    A few Cons:
    One of the drawbacks of the stock RP2 shock (which comes on the Comp model) is it will bottom relatively easily. I weigh 145 pound with gear and run 30-33% sag. It will bottom on drops larger than 4 feet unless the transition is steep. There are a number of rear shock options to fix this, but I am so impressed with the bike's traction through loose corners that I do not feel like changing anything.
    The stock dual ring chain guide works ok. I drop my chain every couple of rides. It is not nearly as secure as the MRP G2 I use on my DH bike. Maybe my expectations are too high.
    I wish I could drop the seat post all the way to the seat collar. The stock seat post still has about 4 inches exposed when the seat post is slammed. It is not a problem for trail riding, but it would be nice if it went down farther.
    The rest of the stock components have performed up to my expectations.
    The Bottom Line:
    This bike descends extremely well and is more than capable of climbing difficult trails. It has greatly improved my descending abilities mostly by improving my confidence. Since I bought the Enduro I ride more, because this bike is so much fun to ride.
    Feel free to ask questions.
    Thanks to Niels for letting me use the camera. Thanks to Niels and Chris for taking the awesome pictures.
    <img src="http://i206.photobucket.com/albums/bb40/RyanBike_photos/EnduroPic2.jpg" border="0" alt="Photobucket"></a>
    Reputation: Whip Chop!'s Avatar
    Great review. Where is it that you ride? Also, what chain guide is that?
    r99
    r99 is offline
    I live and ride in San Luis Obispo, California. All the pictures were taken on rides you can pedal to from town.
    The chain guide came stock on the bike. I think it is the same as Gamut's dual ring guide.
    Reputation: bullit43's Avatar
    Dec 2010
    Hi r99,have the same bike that you,made the same fork upgrade and a few more..riser bar Sunline 711mm low rise,Thomson 50mmm stem,superstar flat pedals,command post ( that you should consider )and Maxxis HR2.35 at the rear wheel and Minion, 2.35 too, at the front, i've a question and a tip for you,when do you rotate the dials on your Lyrik the changes are subtil or you really feel them only by yanking on the handlebar??The problem on our bikes ( i feel that it bottoms out frequently too) is using a Fox kit to make the a RP2 more progressive (rising rate) that you can see here,it makes the RP2 harder to compress on the end of the stroke.The larger the spacer the harder ir gets at the end of the travel.
    Latest pics:
    Reputation: jmallory's Avatar
    The backside of San Luis mountain?
    "No Clue Crew"
    Reputation: Grave9's Avatar
    Great write-up!
    r99
    r99 is offline
    Quote Originally Posted by bullit43 View Post
    All the trails I ride have one big climb and one big descent. I take a brake at the top anyway, so an adjustable seat post is unnecessary in San Luis Obispo.
    The effect of the compression adjustments on the Lyrik are subtle. To feel a difference on the trail I have to give it a lot of clicks. I really like the fork though.
    That looks like a great idea. I will check it out. Thanks. Awesome bike too.
    Quote Originally Posted by jmallory View Post
    Yes. The first and last pic were taken on the backside of the mountain. The other trails are a little harder to find.
    Quote Originally Posted by Grave9 View Post
    Great write-up!
    Reputation: pablobaq's Avatar
    great picts too man!
    Great write up on the enduro. i just recently picked up an 2011 comp and so far love it. so far the only things i've upgraded/changed are the bars (to low and to wide for my preferrence) and the seat post, put a control post on it.
    so far the bikes rides amazingly better than i thought, my only issue is not having enough time to get out and ride more.
    Reputation: lew242's Avatar
    Thanks for the write-up, have been seriously considering getting the frame for quite a while now.
    How do you think the bike would behave with a coil shock, 1x9 and a reverb?
    Nice,! I am actually going to Vandenberg AFB for work at the end of July. I use to live out that way, so I am stoked to ride Montana de oro once I get there...kinda curious how it will feel to ride at sea level again lol
    Nice write up and the trails look just as fun as what I can remember!
    r99
    r99 is offline
    Quote Originally Posted by pablobaq View Post
    Thanks! The pictures are fresh too. All the downhill ones were taken yesterday.
    Quote Originally Posted by retrofred View Post
    You should seriously consider the Mission Control DH Rebound and Compression damper for your Lyrik. It is fantastic.
    Quote Originally Posted by lew242 View Post
    Most bikes are built to pedal best in a middle ring, so a 1 X 9 should work great. You could also put on a proper single ring chain guide and never drop your chain.
    I have heard great things about the reverb, but I have never tried one.
    It is hard to find a coil shock that will fit on the enduro. It is a slightly different length than other shocks. I think the rock shox monarch air shock will fit. Specialized might also be coming out with an EVO kit. I would go for the Monarch.
    Quote Originally Posted by jesse101 View Post
    Vandenberg is very close to SLO. MDO is awesome, but we have a lot of other great trails too. Look for morning glory on the grade. It is one of my favorites
    I picked up an '11 model a couple of weeks ago. That bike kills DJ's too. I cut about 3.5" off the seat post, right above the notches, with a hacksaw at the lbs.
    Dishwasher Safe
    Reputation: deadbolt's Avatar
    Mar 2006
    Quote Originally Posted by r99 View Post
    If you're referring to this one, it's Pick & Shovel. One of my favorites when I lived up there…
    Jun 2010
    Great write up! I have been bouncing back and forth between a 2011 enduro comp and pitch pro. I have decided to go with the 2011 enduro comp. My LBS has marked them down to $2379.00 and they offer a great lay a way plan to hold it. I am going down there next weekend to grab it.
    r99
    r99 is offline
    Quote Originally Posted by deadbolt View Post
    I was asking if anyone recognized the trail in the climbing pictures.
    Pick is one of my favorites too.
    Quote Originally Posted by afp3 View Post
    Awesome. I think you made the right choice.
    I love my Enduro. I will be upgrading the rear to a Pushed RS Monarch Plus and the fork to either a Lyric RC2 DH Coil or a Fox Vanilla RC2.
    People make me mad...
    Dishwasher Safe
    Mar 2006
    Ahhhh. That one's hard to tell. Looks kinda like the Mariposa trail at Irish Hills...
    Reputation: Drth Vadr's Avatar
    One of the drawbacks of the stock RP2 shock (which comes on the Comp model) is it will bottom relatively easily. There are a number of rear shock options to fix this, but I am so impressed with the bike's traction through loose corners that I do not feel like changing anything.
    I've said this one time to many, A better shock can make a bike feel night day difference in performance, Make the upgrade, you'll think you waited too long even if you upgraded it yesterday.
    Great Review
    "I wish I could drop the seat post all the way to the seat collar. The stock seat post still has about 4 inches exposed when the seat post is slammed. It is not a problem for trail riding, but it would be nice if it went down farther."
    I just grab a sawzall and trim off a few inches from the bottom so i can slam it all the way down when needed.
    Reputation: unbalanced's Avatar
    Very cool pics, makes me wish I was back in SLO (Cal Poly alum here).
    r99
    r99 is offline
    No. Other side of town. It is not a trail that very many people attempt to climb.
    Quote Originally Posted by Drth Vadr View Post
    That is a very convincing argument. Now I am considering a Monarch. If it feels like the Lyrik I would be very happy.
    Quote Originally Posted by jeffro719 View Post
    Great Review
    Thanks.
    Quote Originally Posted by unbalanced View Post
    Glad you liked the pics. The trails are still here and as fun as ever.
    Wanted to ask how you like the Minion DHF EXO front and rear for all mountain use and are you running them tubeless? I'm trying to decide between those front and rear or Holy Rollers.
    great write up. I love my 2009 Enduro Comp. It's really my first "all mountain" bike so i don't have much to compare it too, but, i bet i'd like it no matter what (i rode an FSR XC for a long long time).
    I put a Fox Talas 36 on the front, taking out the 32 Float that year's model came with...I'll take the small added weight - it's a fantastic fork. Confidence inspiring.
    other than that, beefier tires (Maxxis Advent), and new front rim and hub (WTB Freeride and Superduty)....
    I think the frame geo is the same on the 2009 and the 2010...but i wanna check now! (Let me know if you know)
    r99
    r99 is offline
    Quote Originally Posted by starry View Post
    great write up.
    The Geo for the 2009 Enduro can be found here: http://www.specialized.com/us/en/bc/...9&sid=09Enduro
    The Geo on the 2010 is similar to the 2009, but the 2010 is a little longer lower and slacker. The 2010 also has a steeper seat tube angle.
    Quote Originally Posted by Whip Chop! View Post
    I was running my DHF EXO tires with tubes. I really like the tread pattern, but I pinch flat the DHF EXO far too much.
    I recently put a dual ply Minion DHF wire bead downhill tire on the rear. It adds almost a pound, but I have had bad luck with tubeless and I do not like pinch flatting.
    The trails I ride have a lot of sharp rocks.
    Key upgrades:
    I am interested in upgrade for my Lyrik R on Enduro 2011.
    Where from did you get the Mission Control DH Rebound and Compression damper?
    Thanks.
    is RAD
    Reputation: Van Cuz's Avatar
    Jun 2010
    Great review. I am keen to hear how it climbs, with regard to suspension performance, in the smallest front chainring? Is there much bob? Do you use the pro pedal much?
    r99
    r99 is offline
    Quote Originally Posted by roamer View Post
    Thanks.
    You need to upgrade two parts.
    1. Mission Control DH Compression Damper
    Vendor Part Number: 11.4015.415.020
    Bikeman Link: http://www.bikeman.com/FK7182.html
    2. Mission Control DH Rebound Damper.
    Vendor Part Number: 11.4015.416.020
    BikeMan Link: http://www.bikeman.com/FK7250.html
    You could also get the parts through your local bike shop. The parts you need are available through BTI.
    You can find them in here under Rock Shox Damper Kits: http://www.bti-usa.com/public/category/FK/FKSP/RS
    Quote Originally Posted by Van Cuz View Post
    I have never found bob to be a problem while sitting down on any bike.
    When I purchased the Enduro I switched propedal to the off position and have not touched it since.
    The Enduro bobs as much as you would expect a 160mm bike with 30%+ sag to bob. The bob is noticeable while grinding up fire roads (compared to an XC bike), but it has never bothered me on single track.
    Other suspension platforms pedal a little better out of the saddle. My friends Pivot Firebird pedaled very well. (It was set up with less sag so I do not know if it is a fair comparison.) Giant's Maestro suspension also pedals very well out of the saddle.
    Try to test ride one.
    r99 Thanks
    Rep Power Infinity +2
    Reputation: brad72's Avatar
    Thanks.
    Don't know if you have already purchased the parts but I bought mine from http://www.bikeman.com/FK7182.html
    Do you know if your lbs still has these prices!? Mine is charging $2,700
    Reputation: Jeepcop31's Avatar
    I just got my 2011 Enduro and love it. I upgraded to the RP23 right away. Unfortunately I had a crash last Feb on my 2011 Stumpy 29er EVO. Another awesome bike btw. So I am still a little gun shy about getting to crazy on the new bike and really using it to its full potential. Anyway Great write-up. You answered all of my questions. Especially the one about upgrading my fork. I think I will take it to the LBS and have those DH R/C parts installed. Of course my LBS is 5000 miles away. I am currently stationed overseas with the USAF.
    Jun 2010
    Quote Originally Posted by Lil' Red View Post
    As far as I know they do. If you go on there webstite and click on "bike specials" they are still showing them @ 2379.00. I noticed when i was there about a month ago they had quite the selection of Enduro's from comp's to experts. I have been in about 3 other bike shops and they had none but this shop was stocked. PM me if you want the details.
    Radical Rookie
    Reputation: rookie nick's Avatar
    Awesome! Respect your riding spirit!
    r99
    r99 is offline
    Quote Originally Posted by Jeepcop31 View Post
    Glad I could help.
    When you get back to the states post some pictures.
    One more thing. I assume it is possible to also convert that fork into the coil model instead of the air. If so, do you know which parts I would need? I do a lot of climbing so I really don't know which set-up would be best. Maybe the RC2L setup huh? Again, if so, which parts? Please pardon my ignorance, I'm just learning all this shock crap.
    Well if you go to coil u-turn you will need 11.4310.717.000 (knob), 11.4015.096.000 (spring), 11.4015.458.010 (top out thingy), 11.4015.205.000 (spring sleeve). The cost is about $140
    Now the spring above is the standard spring so you may need to go harder or softer. As for the spring sleeve you may want to use a hard plastic sleeve to protect the surface finish of the shock bore just in case you go back to air (the spring will scratch if left unprotected).
    If you went to a 2-step the parts are a lot more expensive. I'm pretty sure you would need 11.4015.103.000, 11.4015.079.000, 11.4015.275.000, 11.4015.104.000 and 11.4015.276.000.
    I havent done the above yey but i did add the mission control DH compression and rebound dampers, part numbers 11.4015.415.020 and 11.4015.416.020. These 2 parts are really easy to install and the total job takes about 45 minutes. In addition to the dampers you will need some 5wt and 15wt oil and some isopropyl alcohol to clean things up. I also used some judy butter on the upper seals and bushes since the seals do not have the felt oil ring. You can pick up the fork oil form your local Moto shop
    Brad
  1. Replies: 65
    Last Post: 08-22-2012, 08:35 AM
  2. Long Term 429 Review
    By padrefan1982 in forum Pivot Cycles
    Last Post: 04-04-2010, 08:37 PM
  3. Long-Term PRO REVIEW: Sultan
    By FoShizzle in forum Turner
    Last Post: 08-16-2009, 07:19 PM
  4. Long term Session 10 review
    By bmxconvert in forum Downhill - Freeride
    Last Post: 01-21-2009, 11:57 PM
  5. On-One Mary long term review
    By Professor in forum Singlespeed
    Last Post: 04-25-2006, 02:37 PM
