Results 1 to 8 of 8
    Reputation: geo5dkp's Avatar
    2008 orange p7 pro issue
    Bought this new bike from stif 4 weeks ago and have been riding it almost every day! Only problem is after every demanding ride the Rear disc caliper/frame mounting bolts come loose! So i tightened them up really tight each time. The problem has persisted.
    Threadlock hasn't helped; will not stay rigid = v.annoying!
    This is the only let down on an otherwise perfect bike!
    Has annyone got any suggestions for what to do? Cheers!
    Takw/agranofsalt
    Jan 2005
    tork them to factory spec.
    ride hard take risks
    Reputation: dogonfr's Avatar
    Jan 2005
    Red Lock-Tite, plumbers tape, wave washers lastly safety wire.
    Formotion Products
    http://www.formot
    Same Problem
    I had the exact same problem with my P7 which I bought in October 2008. The threads inside the plate completely disintegrated and so the screws could not be tightened up. Fortunately the bike is still under warranty. I took it back to the shop I bought it from and they replaced it free of charge.
    I think the under-lying problem is that the bracket is made from soft alluminium.
    I did the same! Just collected it back from stif and they replaced it free of charge
    Intresting to know im not the only one!
    Cheers.
    Hi,
    It might be a bit late - but I have a 3rd bolt on the 2009 model on the brake side to help alleviate this problem. The bike shop (Kudubikes) suggested that this could be retrofitted after asking about this issue. I would say it is worth checking to see if you can obtain one as they seem to have fixed it.
    Jan 2005
    Quote Originally Posted by P7rider
    Hi,
    Post a pic for show an tell.
    Formotion Products
    http://www.formot
    Reputation: Luigiugueto's Avatar
    Oct 2007
    New bolts, loctite and elbow grease!
