Results 1 to 13 of 13
    ummmmm??? What?
    Reputation: frenzy2223's Avatar
    Idea! 2007 GT Avalanche 2.0 Disc or 2007 Iron Horse Warrior 3.0???
    I'm not sure which bike to buy!?!? I'm getting back into mountain biking and my budget only allows a max of $400.....Please let me know what you think and if there are any better options under $400! Thanks!
    ~2007 GT Avalanche 2.0 Disc $399.99~
    Seatpost: Alloy Micro-adjust
    Handlebar: Anatomically sized Aluminum, 20mm rise, 6 degree bend
    Pedals: ATB Resin body, Steel cage, Toe Clip compatible
    Stem: GT ATB, Threadless, 25 degree rise w/ 4-bolt Aluminum face plate
    Grips/Tape: GT Dual Density ATB
    Frame: GT Triple Triangle Design w/ 6061 Butted Aluminum
    Chain: IG-31
    Tires: Kenda Nevegal, 26 x 2.1
    Rear Shock: NA
    Bottom Bracket: Power Spline cartridge sealed
    Wheelset: Rims: Alloy double wall ATB; Front Hub: Alloy QR for Disc; Rear Hub: Alloy 8-speed Cassette w/ QR for Disc
    Cassette: Shimano 8-speed, 11/32T
    Rear Derailleur: Shimano Deore M-530
    Front Derailleur: Shimano M-330
    Levers: Shimano ST-EF50
    Shifters: Shimano ST-EF50, 8-speed, EZ Fire shifters
    Fork: Suntour XCR, 100mm Travel
    Headset: Tange Seiki system for 1 1/8"
    Brakes: Tektro Aquila, forged caliper w/ dial adjust pad centering
    Crankset: TruVativ Iso Flo, 42/32/22 with Power Spline interface
    Saddle: WTB Speed V
    OR
    ~2007 Iron Horse Warrior 3.0 $399.99~
    Frame: DOUBLE BUTTED HARDTAIL FRAME, 1-1/8" ZERO STACK HEADTUBE, REPLACEABLE DERAILLEUR HANGER, INTERNATIONAL DISC BRAKE MOUNT
    Fork: MARZOCCHI MZ COMP, 100MM TRAVEL
    Rear Shock: N/A
    Front Derailleur: SHIMANO DEORE, 34.9 CLAMP
    Rear Derailleur: SHIMANO DEORE
    Shifters: SHIMANO DEORE RAPIDFIRE
    Brakes Levers: SHIMANO ALIVIO
    Brakes: SHIMANO DEORE MECHANICAL DISC, W/ 6" ROTOR
    Chain: SHIMANO HG-73
    Crankset: FSA DYNA DRIVE
    Cassette: SRAM PG-950, 11/34T, 9 SPEED
    Pedals: ALLOY PLATFORM
    Bottom Bracket: FSA POWER DRIVE, 73MM
    Headset: ZERO STACK
    Saddle: WTB PURE V SPORT
    Seat Post: ALLOY MICRO ADJUST
    Handlebar: ALLOY RISERBAR, 31.8MM CLAMP
    Grips: N/A
    Stem: RITCHEY V2
    Tires: WTB WEIRWOLF 2.1
    Wheelset: WTB SX-24 W/ EYELETS w/14/15G DB STAINLESS BLACK SPOKES
    Weight: 31.7 lbs.
    Brackish
    Reputation: carbuncle's Avatar
    Dec 2005
    They both have a pretty good group of budget components, with the IH having the better fork. My vote is for the Warrior,, as I had one of those MZ Comp forks on my STP 2 a couple of years ago and it worked well with no problems.
    Grand Poobah
    Reputation: minus9's Avatar
    Check out what makes you can get at you local shops, keeping an eye out for Haro, Giant, and Jamis.
    The Iron Horse looks like it may have the advantage there between the two bikes, assuming that you fit on both frames equally well.
    Frenzy,
    I was faced with making that exact decision about 2 months ago. I had a buddy who had the avalanche and I liked the feel of it. So I went to my LBS to buy one, while I was there I got turned on to the Warrior by one of the salesmen there. After a trip to the trails on a loaner bike my mind was made up the Warrior was great! Seemed to pedal easier up the hills, and the Marzzochi fork is awesome. Ultimately it should come down to what ever feels the best to you, but I will tell you I have done alot on this bike so far its held up to everything including some nice dirt jumps.
    ummmmm??? What?
    Sweet! Thanks for the info! I will be going to my LBS to try some stuff out in a week or two! I don't think that I'll be able to get a better deal than on the two bikes I listed though!
    Reputation: max.veregge11's Avatar
    Hmmmmm
    I own an avalanche, and it's great. However, the fork is pretty limp when pushed on, and you can compress pretty much the entire thing by just standing on it. I'm not sure about the marzocchi fork, because I've never ridden one, but I assume it's a little better quality than the suntour. But if you like a limp fork, go with the gt.
    Commit or eat sh!t
    Reputation: Cable0guy's Avatar
    I own an Avalanche (backup bike). I rode it last week. I almost crashed because I was trying to ride it the same speed as my dual suspension bike. My wrist was hurting after a ride through the rock gardens. Not even a contest between the two systems.
    My advice is to get a used dual suspension with that $400. Check craigslist or eBay.
    Very Wildery
    Reputation: mpvanger's Avatar
    No Contest
    Go with the Iron Horse. For sure. Beefier everything, better components. The extra pound or two is well worth it.
    Reputation: dnlwthrn's Avatar
    umm, shouldn't this be in "Bike and Frame Discussion"?
    extra $200 will get you ALOT more....http://www.rscycle.com/s.nl;jsession...category=23170
    I've sold TONS of both bikes (I work at a Performance during summers and on breaks from school), and both are great. The avalanche frame is bomb proof, but some say it's a bit too harsh. Also, the pedals on it are crap. For that and a few other niggling details I won't get into, I'd say the Warrior is your best bet. Also check the IH Maverick 3.5 However, if you can scrounge a bit more money, the Warrior 4.5 and 5.0 are much nicer, as is the Avalanche 1.0....as it stands, the warrior 3.0 is good. I had a day this past July when I sold 6 bikes during my shift--5 of them were black warrior 3.0's. It's a very popular bike, and great for the money.
    duplicate
    ummmmm??? What?
    Yeah, I think I'm going to go with IH Warrior 3.0, unless I can find a better deal on another bike online or at my LBS.
