Results 1 to 11 of 11
    Reputation: madgeronimo's Avatar
    2002 Hardrock frame--building it up for AM use
    I've got a 2002 Hardrock frame and am thinking of building it up for AM abuse as a project. Then I'll ride her until she breaks. I have a question: and I know I should ask Specialized about this, but does anyone know if putting a 130mm fork, say, on this frame that originally had 80mm will compromise/stress the frame out?
    And what other goodies should I put on here in terms of wheels and stem to go with this old hardtail? Fork? Crank?
    I'd like to stay under $1500 overall.
    They turned me loose
    Reputation: TheDude's Avatar
    You can get a new "AM" HT for way less than $1500.
    What would you recommend?
    Quote Originally Posted by TheDude
    Reputation: el_chupo_'s Avatar
    And to answer your first question, yes, 130mm on a 80mm frame will probably not be good for the bike.
    For a good AM HT frame: do you want a FR type frame? long travel type? do you want a complete, or a build?
    Matt
    Reputation: natebyrom's Avatar
    you can get a giant stp for under a 1000 and they are sweet bikes too
    Maybe I should elaborate a little. If you have the cheese to drop $1500 worth of parts into your old frame, go for it. I find mself building a re-building my various frames, and never quite get them to a point that i like, and I waste alot of money doing it.
    However, if I were you, and this was a secondary bike, I would buy used bits such as the fork, cranks and what have you. Maybe top your budget out at 500 rather than 1500 and still have a pretty nice rig.
    I would look at Giant's STP as noted above, the Jamis line of HT's (Komodo) and possibly one of the few Ironhorse HT slobs.
    Good luck.
    Aug 2005
    You want to drop 1500 into a Hardrock???
    What's wrong with you? Get a P 2 or P3 or something better.
    pUt Da LiMe In Da CoKe YoU nUt
    Quote Originally Posted by madgeronimo
    The Hardrock can take a lot of abuse. I really doubt that you can break it
    This one is still ticking:
    http://thevishfiles.com/thevishfiles.wmv
    Reputation: ANdRewLIu6294's Avatar
    yup. i fractured my neck riding a hardrock, pretty hard crash off a drop, and it still runs perfectly.
    Going for a ride......
    Reputation: energetix's Avatar
    Feb 2006
    I came across this photo on another forum, thought it would probably interest you. The guy only had those forks there temporarily for some reason - off his dh rig or something. Anyway looks crazy!
    energetix
    ride hard take risks
    Reputation: dogonfr's Avatar
    Jan 2005
    Quote Originally Posted by energetix
    Looks like it was a snowy day.
