Results 1 to 21 of 21
    Reputation: Ufdah's Avatar
    Sep 2012
    New question here. 2.5 Minion DHR II vs DHF as Front
    I'm looking for a new front on my Intense Spider Comp 29. I'm running an Ardent 29x2.4 front and back and want a little more cornering grip, rims are 29mm internal. I've read some that like the DHR II 29x2.5 as a front but it seems the DHF is designed for front usage. Ardent will stay on the rear. I could be swayed to the High Roller II but I'm afraid it will be too square with the wide rim. I ride in Colorado, any thoughts?
    Nov 2014
    IMHO when mounted on the front wheel, DHF works better with a fast aggressive riding style while DHR is effective for slow technical trails.
    Dec 2010
    Can you get a DHRII in a 29x2.5? Looks like you can in the DHF.
    mbtr member
    Reputation: scottzg's Avatar
    Quote Originally Posted by ironmike81 View Post
    I agree. Nice first post!
    "Things that are complex are not useful, Things that are useful are simple."
    Mikhail Kalashnikov
    Sep 2012
    Quote Originally Posted by bhmax View Post
    Good catch. That kind of settles it for me. Looks like a DHF in my future. Don't know how I missed that in my research...
    Sep 2012
    Anyone have thoughts as to how much increased rolling resistance I might feel with a 2.5 DHF bs the current 2.4 Ardent? I think I'm willing to sacrifice quite a bit for better cornering but just curious.
    for the front tire, grip > rolling resistance.
    Rocks belong
    Quote Originally Posted by Ufdah View Post
    Ardent rear, DHF front will be awesome for CO
    I like 'em long, low, slack and playful
    Reputation: Gman086's Avatar
    ^^ What I run in the summer. Running HiRoller 2 for rear in wet/winter conditions at low psi and works amazingly well.
    Have FUN!
    G MAN
    "There's two shuttles, one to the top and one to the hospital" I LOVE this place!!!
    Rocks belong
    Quote Originally Posted by Gman086 View Post
    Have FUN!
    G MAN
    Also what I do. Bet he has them on a Bronson as well... Because G Man seems cool like that.
    Reputation: coke's Avatar
    I switched from a 2.4 ardent front to a dhf 2.5. The dhf is in a different league as far as traction. The only other tire I've ever ridden with this much grip is the 4.6 ground control on my fatbike. It's predictable and it's easy to feel the cornering limits. Also be aware that the tire is huge. It will slacken thr geo of your bike and you could also possibly have clearance issues.
    Reputation: nauc's Avatar
    Quote Originally Posted by 06HokieMTB View Post
    this ^
    Rocks belong
    I just re-upped this combo and bought some Black Friday Ardent and DHF's for the garage shelf
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Combos that have worked well in the past:
    DHF front, DHR rear
    DHF front, DHF rear
    I run a DHF front. I have run DHFs for a long time, sometimes paired up with DHRs in the rear. You can't go wrong putting a DHF up front.
    Zaf
    Zaf is offline
    Reputation: Zaf's Avatar
    Mar 2012
    The DHR is like a HRII with Minion side knobs and swapped center knob sipes. But the DHF is such a great tyre I can't actually admit to having ever tried the DHR up front as an aggressive HRII before.
    Jul 2014
    Maxxis needs to discontinue the Ardent 2.4. No aggressive rider who needs/wants a 2.4 will find that tread pattern desirable. I know this first hand. I'm sure it makes for a great 2.25 XC wheel, or perhaps a rear trail wheel, but the 2.4 doesn't fit into a category.
    High Roller II.
    Never understood what all the ardent hype was, had huge gaps it seemed between knobs. I bought them. Wasn't impressed.
    Nov 2014
    Quote Originally Posted by scottzg View Post
    thanks!
    Reputation: woodyak's Avatar
    For awhile it was the only large single ply readily available from Maxxis. I used them exclusively for a couple of seasons. When brand new they actually aren't that bad, well OK. they are but you get used to it. They do roll a good bit quicker than the DHF, DHR, HR2's and they would grab in the corners if you leaned them over enough. The problem is once they start to wear the side knobs are worthless and the whole tire becomes like a Small Block 8. I also found that I couldn't keep them toobless for too long as they'd pry right off the rim.
    Once I started playing around with the HR2, DHR, DHF's I never looked back. I see no reason to run any other tire upfront than a DHF. Those tires have saved my bacon many times. I was running a DHR on the rear for awhile and it's pretty solid, but once the middle knobs start rounding off you really start slipping out on climbs, especially when it's wet. I'm running a new DHF 2.3 TR on the back right now and it's pretty solid. Corners a little differently than the DHR but other than that not much of a difference. I ran the HR2's front and rear for a season and it's definitely a solid combo. Seems to be a stickier tire in general but wears out very quickly.
    Come stay and play at da Kingdom Trails! - http://www.homeaway.com/vacation-rental/p3486813
    Dec 2012
    Maxxis Minion DHR2 | Blister Gear Review ? Skis, Snowboards, Mountain Bikes, Climbing, Kayaking - The most honest and in-depth reviews of outdoor sports equipment on the planet.
    This is a very good review of the DHR II. After reading this review, I bought 2 DHR IIs for my DH bike next year, I'll try it untrimmed in front to start, but will probably trim the front eventually.
    Aug 2015
    I agree as well.
  1. Minion DHR2 in front
    By dirtrider76 in forum Wheels and Tires
    Last Post: 11-09-2014, 09:46 AM
  2. (Front) Minion DHF vs HRII
    By Warshade in forum Wheels and Tires
    Last Post: 12-01-2013, 11:26 AM
  3. Want to match a Minion DHF 2.3 front
    By lew242 in forum Wheels and Tires
    Last Post: 05-11-2013, 08:25 PM
  4. minion dhf 2.35 60a with weirwolf comp 2.3. which up front?
    By akiracornell in forum All Mountain
    Last Post: 02-21-2013, 11:01 AM
  5. Replies: 15
    Last Post: 04-04-2011, 04:14 PM
Members who have read this thread: 103
