Results 1 to 15 of 15
    Nov 2012
    1x10 Shimano Question
    I am planning on replacing my SRAM X9 rear derail. with Shimano XTR Shadow plus and was wondering if I should go with 11-36 or 11-34 rear cassette. My front cog will be 36.
    meow meow
    Reputation: b-kul's Avatar
    there is no compelling reason in my book not to go 11-36 unless it it is a dh application.
    Dec 2012
    If you're riding a 36 up front I'd probably go 11-27.
    Reputation: jmallory's Avatar
    Are you replacing your shifter as well?
    Nov 2012
    Quote Originally Posted by jmallory View Post
    Of course, I am getting new shimano shifter that works with shimano rear Derail.
    Living Ghetto Fabulous!
    Reputation: Uncle Cliffy's Avatar
    11-36 no doubt. Been on this setup for 2 seasons now.
    Quote Originally Posted by ST-->Power View Post
    No way. 11-23.
    Quote Originally Posted by kidwoo
    The internet sounds like a tough place to ride.
    undercover brother
    Reputation: tangaroo's Avatar
    If you want to still be able to climb for extended periods I would definitely go 11-36. I had 34t up front and 11-36 in the rear and with all the steep climbs around here I found myself in being in the 36 rear too much. I went down to a 32t up front and it seems to be golden. I run out of gears on the road, but never in twisty singletrack.
    Reputation: MSU Alum's Avatar
    Hard to say, since we have no idea how or where you ride. I need a new kayak paddle, should I get a 202 CM or a 198?
    meow meow
    probably 200 for greatest efficiency.
    Nov 2012
    Quote Originally Posted by MSU Alum View Post
    Fair enough. I live in MA and most of the singletracks are mix of climbs and descents.
    I was running 11-34 and 34 up front and it was a little tough, dropped to 32 front and it was perfect. If I was gonna go 11-36 then I would probably start with a 34 up front.
    Wait for me!
    Reputation: whoopwhoop's Avatar
    Nov 2008
    I run 11-36 cassette and started with a 34t a first, moved down to a 32t and it's just about perfect now. I do ride a lot of steep tech climbs, so the lower range gearing is what I needed. If I rode all singletrack, I'd go back to the 34t.
    squish, squish in da fish
    Reputation: fishwrinkle's Avatar
    32-11/36
    Quote Originally Posted by b-kul View Post
    I'm getting a 194 bent shaft...it's for playboating!
    meow meow
    ohh, good choice!
  1. Shimano Zee 1x10 quandry?
    By peterpiper in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-11-2014, 10:19 PM
  2. 1x10 Shimano XT Questions
    By Zaf in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-15-2013, 03:27 AM
  3. 1x10 using Shimano and Campy
    By Carver96er in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-12-2013, 02:35 PM
  4. Shimano XTR 1x10 questions
    By VR46 in forum Shimano
    Last Post: 05-25-2013, 06:14 PM
  5. whos gone 1x10 with Shimano Zee?
    By mjduct in forum 29er Components
    Last Post: 02-01-2013, 08:35 PM
