Results 1 to 9 of 9
Thread: 1x10 question
    Mar 2013
    1x10 question
    I'm sure this has been asked a lot but I wanna go 1x10 I never use my granny gear even on big climbs. I know I want a mrp s4 chain guide. My question is do I need a new rear derailer? I don't think i would but just checking before I start taking everything apart and also do I need a spacer for where my granny gear is?
    Reputation: El Cerveza's Avatar
    Nov 2012
    Sv: 1x10 question
    Your rear derailer should be short or medium. And if you have an shimano shadow+ or an sram type2 derailer you will not need the chain guard.
    Personally I use a single 32t (wolftooth direct mount chainring on sram s1400 gxp crank) in front and a sram x9 type2 derailer and no chain guard, and it works flawless.
    Sendt fra min GT-I9505 med Tapatalk 4
    stock cassette, cluth type rear derailleur, 30-38T front chainring in 104bcd, chain retention device is all thats needed
    Im running sram XO type 2 rear, 34T Renthal chainring on E13 LG1R crank, E13 LG1 chain guide. works flawlessly. You will probably want to cut your chain a few links shorter from what you have now
    Mar 2013
    I wanna get the renthal 38t. I have a sram x7 rear. I still should shorten the chain if I'm going with the same front chain ring?
    Nov 2012
    Sv: 1x10 question
    You don't need to shorten the chain if the chainring is the same size as the large you use now.
    Reputation: jmallory's Avatar
    A shorter derailleur works best but if you have a long cage it will work. If you're trying to save money, run it til it breaks. I also have the Wolf Tooth with clutch RD and no chainguide and love it. Absolutely no problems, less weight and less drag.
    squish, squish in da fish
    Reputation: fishwrinkle's Avatar
    when i ran 1x10 (32T) w/ clutch RD i still needed a guide and tensioner. clutch RD's soften the slap but don't eliminate it IMHO. maybe look into a narrow/wide chainring like the xx1, RF makes one for pretty cheap. it depends on terrain and style of riding, i was using a short cage and chain of proper length too. if you're running a 38T it sounds like you are either doing a lot of DH or riding a lot of flat.
    I tried running an X9 type 2 with a 32 tooth bling ring and it didn't work for me. Keep in mind, I am a graceless hack on my bike and that may be part of the issue. But since I added an MRP guide I haven't dropped the chain once.
    Mar 2013
    Yeah I do lots of dh at ski resorts. Whats a clutch rd? Def want the mrp though I go through some pretty narley stuff. Did you leave your granny gear on or do you need a spacer?
  1. new to 1x10 question
    By gmx in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-09-2012, 05:28 PM
  2. Question about 1x10 setup...
    By In-Yo-Grill in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-20-2012, 07:42 AM
  3. A9C 1x10 Question
    By Tyrone Shoelaces in forum Niner Bikes
    Last Post: 02-17-2011, 10:06 AM
  4. 1x10 question
    By SprocketRocket in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-05-2011, 10:57 PM
  5. Crankset for 1x10 Question
    By eubank3 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-04-2011, 10:34 AM
