Results 1 to 5 of 5
    KuskoRiverCruiser
    Reputation: qayaq_alaska's Avatar
    New question here. Winter SS Gearing...revisited
    With the plethora of new wheelsets out there...wanted to revisit the question of gearing for SS - Single Speed and DMS - Derailleurless Multispeed Snow Bikes.
    FYI, here is the original posting and discussion:
    SingleSpeed SnoBike Gearing....
    Here is the calculator that I'm using:
    http://software.bareknucklebrigade.com/
    ____________
    Given, 80 and 100mm rims with Endomorphs, 175mm crankarm
    !st QUESTION:
    what tire size would you plug into the formula for an accurate gearinch determination.
    ____________
    The concensus in previous thread was for 'general' snow conditions ~ 38 to 40 Gear Inches was most useful.
    2nd QUESTION: Any additional thoughts on useful gear combos for SS and DMS layups? Suggestions?
    Quyana in advance....
    M
    Martin
    "The pursuit of truth and adventure is far more noble a task than looking for work",
    http://fatbikealaska.blogspot.com/
    is buachail foighneach me
    Reputation: sean salach's Avatar
    29" or a little over. you could find the exact od of your tires by sitting on the bike and having someone hold a level across the top of the tire then measuring to the gorund from there.
    Surly says that the Endo on Large Marges are 740mm in diameter and that a 29x2.1 is 737mm in diameter. I use http://www.sheldonbrown.com/gears/ to calculate my stuff. I've always thought that 32x20 with an Alfine would be a good spread.
    Fat!Drunk!Slow!
    Reputation: JordyB's Avatar
    Oct 2007
    I'm running 32x20 on 29"x2.1'" and it seems to be working pretty good.
    Caveman
    Reputation: Bearbait's Avatar
    24x22 on endos is great!
    for 29" 30-23 was pretty ideal
