Results 1 to 9 of 9
    KuskoRiverCruiser
    Reputation: qayaq_alaska's Avatar
    SingleSpeed SnoBike Gearing....
    Wondering what gearing folks are using on their SS SnoBikes?
    ________________
    Using Sheldon Brown's spreadsheet to calculate in 'Meters of Development' (MD):
    http://www.sheldonbrown.com/gears/
    Assuming Endomorphs on Marge rims - avg. tire pressure...closest assumption on the spreadsheet is 29 inch (700x56)...175 crank length.
    ________________
    I'm running 35, 38 CR & 19, 21 COG = 3.9MD, 4.2MD, 4.3MD, 4.7MD
    Any comparative numbers out there!
    Martin
    Martin
    "The pursuit of truth and adventure is far more noble a task than looking for work",
    http://fatbikealaska.blogspot.com/
    ThisseatmakemyA$$lookfat?
    Reputation: brian_404's Avatar
    my winter bike was an ss... but i did an 8 speed rear conversion... i needed the extra gears for the deep snow...
    aka: akfreeridemtber; brian_404
    Just get out and, RIDE!!!
    www.facebook.com/shagwn007
    dumb ass
    Reputation: mtnbykr©™'s Avatar
    i'm in n minnesota. riding mostly hilly singletrack and snowmobile trails. running 32 x 22 w/ nokian 3.0s on a surly 1x1. could use a lower gear after 2-3 hours of riding...
    i'll probably run a 5-6 gear setup next winter w/ some mods to the surly.
    Baby seal walks into a club.
    Caveman
    Reputation: Bearbait's Avatar
    30-23 low baby.. I'm done with that though.
    i'm running a 32-16 with 175 crank length. in the summer... great around gearing...
    40-42 inch gear
    Martin,
    I used a 32x20 on my 26" snowbike with 2.4 tires, which equates to roughly a 42 inch gear. I used a 29x20 on my 29er to get the same gear and it worked fine. But with the Endomorphs I'm using a slightly smaller gear in the 38-40 range because of the higher rolling resistance. For general fun riding I'm using a 22x16 = 40 inch gear and I'm not a hammer on the bike like you, but this may be a good start.
    I think Bearbait is close to what I'd recommend.
    Pat
    KuskoRiverCruiser
    Good info...
    those ranges r about what I'm finding use-able as well!
    Thanks folks...ML
    ______________
    Have a great setup on one of the Pugs' that folks might find interesting...still refining some of the parts and all but...my own interpretation of...
    the Derailleurless Multi-Speed (DMS)
    maybe a separate post....
    Quyana
    Martin
    KuskoRiverCruiser
    SS or DMS Gearing...revisited....
    Laying up some bikes and was wondering if anyone had anything to add re: gearing on fatwheels...Marges running Endomorphs.
    How'about some of the wider layups...80 and 100mm spreads?
    M
    Martin
    Feb 2006
    Pugs SS
    My Pugs was originally built as a SS 32/20 which did not seems adequate for changing snow conditions on such a heavy bike - changed to 32/26 up front and a 13/32 8-speed in the rear which seems low enough to climb anything I can keep traction with the Endos - also went to the long 17 degree Salsa bars for low speed leverage.
