Results 1 to 3 of 3
Thread: Rainbow trail
    Bikes are good
    Reputation: Elfbkr50's Avatar
    Rainbow trail
    I know, it isn't open to biking. I was hiking there late last night and planned on hiking/running from the potter end to Rainbow and back. There were two brown bears in the Mchugh area which was cool. Took a left on accident because I'm miserable when I run and couldn't read the sign. The trail was so cool though, I kept going. To Mchugh lake maybe? Switchbacked up a bit, then traversed into the valley just north of Mchugh creek (probably was Mchugh creek come to think of it.) The trail winded its way down, there was a trail equipment box, and the trail abruptly ended after descending a bit more. Anybody know what that is, or the plan is there? There was a makeshift campsite set up, and clearly a heck of a lot of manual labor making this trail. That whole system would be an awesome bike ride. Over to Rainbow if you took the right turn too.
    "Having lack of self-preservation makes biking more fun."
    Did you end up on the Rabbit lakes trail? That would be turning left just before you get to Mchugh- Its been ridden down from rabbit lakes, but I heard it involved some bush-whacking.
    Bikes are good
    I'm not sure
    It was cut neatly into the side of the mountain, about 3 feet wide, and after it switchbacked up from Mchugh, went down and then was barely a trail. I think they are building it from the top down, or Mchugh over. It too will probably be closed to mountain biking which is too bad. It would be great riding.
