Results 1 to 7 of 7
    rio
    rio is offline
    Frigid Bits Ice Crit !
    Ice Crit/Team Relay is baaack !
    Team: Consist of 2 riders
    Relay Object: A set of boxer shorts, undies, thongs or whatever and do a lap, exchange the boxer shorts, the boxer shorts must be worn as they are usually worn.
    When : March 30 at 9 PM
    Where: West Chester Lagoon
    Must wear a helmet
    Try out your Dillingers your 29r or 26r studs on the lake ice and bang the bars on a oval short course !
    Oh, yeah, this is also a social function so bring some adult beverages of choice to share with your fellow krazziees!
    There will be a burn barrel but not the Fabulous Famous Frigid Bits Burn Barrel, this time the FFFBBB is on a diplomatic mission to promote
    the end to the inhumane treatment of dust bunnies.
    Yay! Cya out there!
    rio
    rio is offline
    Frigid Bits Ride
    This get together will also will include a trail ride component that may or may not exclude the ice crit : )) !
    I must take advantage of all the white goodness !
    Helmets are required !
    Fat!Drunk!Slow!
    Reputation: JordyB's Avatar
    Oct 2007
    Sweet!
    rio
    rio is offline
    This ride is now amended to exclude the relay part. Instead each rider will do 3 laps on the West Chester skate loop and then ride the Coastal Trail south until you get just south of the ball diamond, be prepared to take a left turn to ride skuzzy skinny trail that has a crazy narrow wooden skanky bridge. Well, after crossing the bridge or after crawling out of the ditch you fell in, continue riding until you get to the Coastal trail and the ride on until you get to the Uranus sign, when you find it turn around there and and come back to where you started including doing another three laps on the lake loop. Pre- riding the single track is suggested to be sure your bike can walk you across the skinny bridge.
    The ride maybe further amended to exclude the ice loop if there are ice skaters. If there are ice skaters the ride will be extended to Kincade Chalet and back to the party!
    Please bring your liquid refreshments of choice to share with others !
    Fat!Drunk!Slow!
    Oct 2007
    Thanks again Carlos for bring us all together! Good times!
    Jan 2013
    Rat Farts, I missed it.......and I had stockpiled my big boy sodas too!
  1. Replies: 6
    Last Post: 03-17-2012, 06:00 PM
  2. Frigid Bits Ice Crit Update 1
    By rio in forum Alaska
    Last Post: 03-17-2012, 01:29 PM
  3. Replies: 3
    Last Post: 03-15-2012, 07:13 AM
  4. Frigid Bits Was Krazzie!
    Last Post: 11-01-2011, 03:12 PM
  5. Frrigid Bits Ice Crit Championship
    Last Post: 03-12-2011, 01:14 PM
