Results 1 to 2 of 2
    Oct 2012
    Zeppelin Elite geometry
    I used to look this up on the Airborne website each time I needed it but the page for the Zepp Elite got taken down. Does anyone have the geometry measurements of the Zeppelin Elite frame, specifically the 21" size, handy?
    I'd like to know the measurements for when I ride other bikes and then want to compare the geometry to mine, or want to see how other bikes compare to mine in geometry.
    Reputation: BigDaddyFlyer's Avatar
    Hey Alex,
    TT , ETT, Headtube length, etc are easy to measure on your own, but I can see where angles would be difficult.
    Here's the info you need.
    Frame size: 21"
    TT: 58.6cm
    ETT: 60.9cm
    ST Angle: 73 degrees
    HT Angle: 70 degrees
    Head Tube Length: 115mm
    Fork Offset: 38.1 mm
    Chainstay length: 42.7 cm
    Wheelbase: 111.1 cm
    Hope that helps,
    Please Note: I no longer work for Airborne. If you have an Airborne question or problem please contact them directly.
