Results 1 to 10 of 10
    Reputation: Sleevem1's Avatar
    Wider bars on the Goblin
    Is anyone runnin the Goblin with 700++bars? I'm thinking of trying some longer bars but wan't to get some feedback. I find the stock bars a bit twitchy but then again it may because of my noob a$$ riding skills.
    Nov 2012
    Re: Wider bars on the Goblin
    From my reading XC bikes aren't set-up with wide bars (or at least wide bars/short stem). I'm not sure why though.
    If you have lock on grips you can slide them out a bit too get an idea of how it would feel (I prob wouldn't ride on a gnarly trail like that though).
    Reputation: Mitch1171's Avatar
    Jan 2009
    im going with a 50mm stem and prob 700 bars as i dont like to be over the bars as much. ZBut waiting on my HB XO still so really cant answer yet!
    Dec 2012
    The aerodynamics are better with bars that aren't so wide, plus they are easy to manuever on skinny single track. I find myself more comfortable with the 740mm bars on the skyhawk than the 680mm on my other bike they allow me to have more stable control of my bike. Another personal preference I must say.
    -Airborne Skyhawk
    -2000 Raleigh M30
    -2008 Cannondale Rush 6
    Reputation: Zerort's Avatar
    Jan 2013
    Yes, I ride my goblin with a niner carbon bar measuring 710 mm.
    by Silentfoe
    I'm satisfied knowing that what I wear during my "day" job makes me more of a man than you'll ever be.
    I have 725mm bars and a 70mm stem on my Guardian. Same frame as the green Goblin. Feels perfect to me.
    Reputation: WineDine29er's Avatar
    Apr 2013
    I was wondering about this myself. I ended up ordering the race face atlas...i know its super wide but i can cut it down a little. I am pretty lanky so figured a wider bar will give me a little more stability and cut down on twitchiness.. We'll see once i get it
    Reputation: KrazyKreitzer's Avatar
    I have FSA SL-K low rise bars which I believe to be around 680 mm. I already want something a little wider. There aren't that many tight trees where I ride.
    CoolArrow
    Reputation: jhazard's Avatar
    I like the more stable feeling of a wider bar. I picked it up when I was riding single speeds and it never went away. Right now I'm riding the Deity D30's on my Hobgoblin (760mm wide). Also ran the Raceface Atlas bars at 30 inches, but I like the sweep/rise of the Deitys better (funny how minute a difference you can recognize).
    Running the Deity Black labels on my Marauder which are 787mm/31 inches, and I'm finding that's the limit - actually a bit beyond. For freeriding its okay, but in the woods I was clipping trees on the last ride. And then, I don't always ride my hands at the end of the bar either, sometimes I'll choke up on them a bit to alter my riding position. I like to have that option. Riding a 50mm stem I've found you have to be careful to weight the front wheel in turns, or it can wash out. I'm used to it now, but it took a few "lessons" to break me in.
    Keep in mind, running wider bar will also have your leaning forward a bit more because your stance will be wider. I don't think there's an exact equation, because people have different postures when riding, but something to keep in mind too.
    Cool BandolArrow
    Jerry Hazard website
    Quote Originally Posted by jhazard View Post
    Thanks for the feedback guys, I'm going to try my low-rise raceface sixc 725 off my Chilcotin. I should get wider bars for that bike anyway so the lighter carbon bar should be an added bonus. I'm also going to try using a shorter stem at some point to see how it feels.
  1. Wider bars and a shorter stem...
    By markersniffen in forum Beginner's Corner
    Last Post: 11-20-2012, 05:37 PM
  2. Wider Bars....????
    By bowler1 in forum 29er Components
    Last Post: 05-16-2012, 02:22 PM
  3. wider bars?
    By esundell90 in forum Singlespeed
    Last Post: 08-23-2011, 06:51 AM
  4. I dont' think wider bars would work
    By manabiker in forum Passion
    Last Post: 04-08-2011, 07:51 AM
  5. Wider Flat Bars where can I find them?
    By cale399 in forum 29er Bikes
    Last Post: 01-16-2011, 11:33 AM
