Results 1 to 14 of 14
    Captain Climber
    Reputation: Jem7sk's Avatar
    Jan 2013
    Is there a difference in the Guardian and Goblin frame?
    Reputation: TheDocTx's Avatar
    Apr 2013
    Quote Originally Posted by Jem7sk View Post
    I know the Goblin frame has a tapered head tube and increased clearance for the rear tire. I'm sure there are more differences than that, but that is all I know of.
    EDIT: The following is copied from Airborne Bicycles. Goblin
    FRAME: Tapered HT with increased rear wheel mud clearance, increased standover clearance on the 16" frame-size.
    Reputation: 8iking VIIking's Avatar
    Dec 2012
    ^what he said. I believe that the guardian has the same frame as the old green goblin. Still a high quality frame, just no tapered ht and less rear wheel clearance. I think that the chain and seat stays on the goblin might be a little beefier than the guardians but don't quote me on that
    Captain Climber
    Jan 2013
    What does rear wheel clearance mean? I'm guessing width so you can fit a fatter tire? I think I've seen what a tapered HT looks like (fatter at bottom and tapers off skinnier towards the top?) but what does that accomplish?
    Tapered Head Tubes
    Captain Climber
    Jan 2013
    Thanks Jay! Seems like it is not a big deal either way on the HT for XC bikes? How about the rear wheel clearance?
    Captain Climber
    Jan 2013
    I found my answer on the Goblin frame only page if this is the only differences between the Guardian and Goblin.
    The Goblin frame is made from 6061-T6 aluminum with butted main tubes. We've added more mud clearance in the rear so that a 2.2" fits with plenty of room to spare. New for this year also is a tapered head-tube for added steering crispness and rigidity. The headset bearing standard has also been changed to an IS standard ("drop-in"), and we've included a headset with the frame. The bottom bracket shell remains the 68mm threaded BSA standard.
    Reputation: BigDaddyFlyer's Avatar
    A tapered HT is, IMHO, a huge diffeŗence in regards to steering input and feedback, especially on a 29er. Much like my personal migration toward 29inch wheels a few years back for XC riding, I've also moved all of my personal rigs to tapered HT's. I think the tapered HT makes a bigger difference than a 15mm thru-axle.
    The current Goblin frame is much different than the Guardian, with a tapered HT, increased mud clearance, larger stays, and is optimised for a 100mm travel fork.
    We have something in the works for another new version of the Goblin frame, but i have to be a little tight-lipped about it at the moment. :-)
    Jeremy
    Please Note: I no longer work for Airborne. If you have an Airborne question or problem please contact them directly.
    Captain Climber
    Jan 2013
    Quote Originally Posted by BigDaddyFlyer View Post
    A tapered HT is, IMHO, a huge diffeŗence in regards to steering input and feedback, especially on a 29er... I think the tapered HT makes a bigger difference than a 15mm thru-axle.
    Your talking Greek to this newbie now? I can't wrap my head around how either the HT or thru axle would do that.
    Mud clearance is just like more tire clearance from the frame correct?
    Looking forward to seeing he new bike(s). When do you think they will be ready?
    TXTony
    Guest
    Tapered head tubes provide three major benefits to riders: stiffness, responsiveness and durability. A wider head tube junction leaves room for a larger down tube, enabling engineers to create a stiffer, more efficient pedaling platform. The wider junction also enables us to use forks with stiffer, stronger fork crowns and steer tubes; these forks are less prone to flex, so riders experience enhanced responsiveness and control in the handling of the bike. Tapered head tubes also enable engineers to optimize headset bearings. Oversized 1 1/2" lower bearings are stronger and more durable, and they are better at dissipating loads and handling impacts. Smaller 1 1/8" upper bearings, which experience less load, are lighter. Combined, all of these tapered head tube benefits contribute to a more thrilling ride experience.(Pulled this off the web..but pretty much sums it up)
    Captain Climber
    Jan 2013
    Reputation: KrazyKreitzer's Avatar
    Jeremy
    Are you talking about that one you showed me or the other one you showed me? Haha! Can't wait for the ______ to show up so I can add one to the fleet.
    Quote Originally Posted by KrazyKreitzer View Post
    It's the one I showed you.
    We've got a few new models hitting in late July and early August, and then another new model in September. Stay tuned!
    In general, we don't revamp our entire line every September/October like other bike companies do. We bring bikes in at different times of the year and some models have more than a year of run with us, generally 18-20 months. That helps us keep costs down rather then dumping "old" models every year in the fall.
    Jeremy
    Reputation: hrbib21's Avatar
    Apr 2013
    So now I'm wondering if I should buy the Guardian now or what...STOP CONFUSING ME!
    LOL, all good info. Thanks.
  1. Presta or Schrader for Goblin and Guardian?
    By ddblu in forum Airborne
    Last Post: 05-03-2013, 01:57 PM
  2. Single speed based on goblin frame?
    By MadMacMan in forum Airborne
    Last Post: 04-09-2013, 06:20 PM
  3. To Guardian or to Goblin...that is the question....
    By FirefighterMTN in forum Airborne
    Last Post: 02-19-2013, 01:05 PM
  4. Airborne Goblin vs Orbea silver 29er carbon frame
    By jkidd_39 in forum 29er Bikes
    Last Post: 12-10-2012, 03:49 PM
  5. Replies: 5
    Last Post: 08-30-2012, 07:05 PM
