Results 1 to 3 of 3
    SRAM X5/X7 2x10 FD, Dual Pull
    Can any one confirm or deny if the X5 FD from the Seeker or the X7 FD from the Goblin are dual pull compatible? Reading the SRAM website it would appear that they are but I've never set up an FD before and am hoping to use one of the FD's I've got (thanks again, by the way!) on an older bike that is top pull.
    Eric
    Reputation: BigDaddyFlyer's Avatar
    I know the X5 on the Seeker is and depending on when the Goblin was made it will be also.
    You can tell its dual pull by just looking at the back of the FD that faces the rear tire. If its obvious the cable can be run from the top or bottom then its dual pull.
    Hope that helps!
    Jeremy
    Please Note: I no longer work for Airborne. If you have an Airborne question or problem please contact them directly.
    Perfect! very helpful, thanks Jeremy.
    Eric
  1. Dual pull derailleurs
    By fernandoj in forum Vintage, Retro, Classic
    Last Post: 05-15-2013, 05:35 AM
  2. Cable guide position for top pull (dual pull) XT from mech
    By shandcycles in forum Frame Building
    Last Post: 06-23-2012, 04:53 PM
  3. FD - how can I know if it is dual pull or top pull?
    By xenon in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-12-2012, 12:49 AM
  4. SRAM X7 Front derailleur - dual or top pull
    By bank5 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-20-2012, 05:40 AM
  5. XT 2x10 Crankset Compatible with SRAM 2x10 Drive Terrain??
    By sbchisholm in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-01-2011, 07:30 PM
