Results 1 to 19 of 19
    Oct 2013
    some weights of things ive upgraded
    saw a few people ask for weights so while doing some upgrades I figured I would throw these on the scale. grips with end cap 85.2 g, bars 340.5 g, stem 133.6 g. these weights were measured with a crappy harbor freight digital scale. these may not be the exact weights of all stock parts. there will always be a little difference form part to part but its a close measurement.
    Oct 2013
    forgot to add all of this was off my new (black) goblin
    Reputation: 8iking VIIking's Avatar
    Dec 2012
    Re: some weights of things ive upgraded
    Oct 2012
    That is inline with what I measured. (Same scale)
    Seat Clamp: 29g
    Seat Post: 349g
    Saddle: 272g
    Bars: 331g
    Stem: 146g
    Front Skewer: 56g
    Stock AKA: 906g
    Stock Tube: 218g
    Front Disk: 150g
    Front Hub/Spokes/Rim: 1052g
    Dec 2012
    Holy balls that aka is way over the claimed weight! Were they both that heavy?
    Oct 2012
    Quote Originally Posted by 8iking VIIking View Post
    I thought the same thing. I have not been able to find the real weights anywhere else of the wire version and I did not weight the other tire while it was off to convert to tubeless for some reason, only the front.
    I have a Felt with the same tires still running tubes. I'll try to pull one of them off and check it.
    Dec 2012
    I'm actually on my 2nd set of akas, the folding version this time. Its pretty well documented that they run about 50g over the claimed weight, but 906g is nearly 140g over the claimed weight for the wire beads! Unacceptable.
    I wish geax made a "race" version of the tire to compete with the ikon, race king, etc. I love the tires but not the weight
    Oct 2012
    My next upgrade will be wheelset/tires. I could run the Ikon 2.35s and still save weight over the stock tires.
    Dec 2012
    Quote Originally Posted by jdhunt0 View Post
    I'm also thinking about running those. Kinda stuck between then and the ikon 2.2's
    Oct 2012
    I'm leaning toward running the ikon 2.35s front and back. At least until things dry out in the spring. Any thoughts on this?
    Reputation: BigDaddyFlyer's Avatar
    I'd probably run the 2.35 front and 2.2 rear. While the 2.35 will fit in the back, mud/snow/leaf clearance will be limited.
    Jeremy
    Please Note: I no longer work for Airborne. If you have an Airborne question or problem please contact them directly.
    Quote Originally Posted by BigDaddyFlyer View Post
    Jeremy
    I was wondering if 2.4's would fit in the rear. I am running the VeeRubber Speed-R 2.4 (got it for free, figured I'd try it) on the front and am really, exceedingly happy with it, especially since its full price is $26 for a folding 120tpi tire. It's basically an Ardent knockoff and I don't notice any difference in how it rolls vs. the AKA, and quite a bit lighter than the stock AKAs. Thought about trying it on the rear once I kill both of the AKA's but looks like I'll go with the 2.2 version. Thanks for posting this.
    No worries.
    One of the proto frames I'm riding right now has plenty enough clearance for 2.4's but I'm currently running 2.2's on it for the fall for increased clearance. On a ride a few weekends ago with a friend on his Goblin and big Nevegals, he had to stop several times to clear leaves and debris that were collecting near the BB area and slowing him down. I wasn't having any problems, and my traction wasn't suffering a bit from what I could tell.
    Jeremy
    Dec 2012
    Jeremy-
    How do you think clearance would be on a 1x10 setup? Is the fd clearance the main concern or is it the stays?
    On a 2x10 system it's really the stays and the bridge in front of the rear tire.
    Jeremy
    Sep 2013
    Holy crap I had no idea the AKA's were that heavy. After getting 2 thorn punctures in the last 3 rides I'm ditching them pronto. Going tubeless with something a bit more puncture resistant.
    I loved the High Roller (rear) and Ignitor (front) setup I had on my 26er.
    Sep 2013
    Confirming the bar weight. Mine weighed in at 339g versus the replacement carbon bars at 169g.
    Reputation: s0ul_chicken's Avatar
    Aug 2013
    MMMMMM.... Carbon....
    Sep 2013
    I absolutely love them. 710mm and half the weight of the stock 640mm ones. The vibration dampening is very noticeable. Best part is that they were only $99 from Amazon.
  1. Things Fitting Perfectly Into Other Things...
    By CHUM in forum Off Camber (off topic)
    Last Post: 03-23-2014, 05:54 PM
  2. i upgraded!
    By Ultimate-soldier5 in forum All Mountain
    Last Post: 01-02-2013, 09:23 AM
  3. XX1 Mini-Review & Weights, XTR Weights, Race Face Next Crank Weight
    By brentos in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-31-2012, 05:03 PM
  4. Hub weights...Syncros, wtb, Hope pro 2 Evo weights
    By RTM in forum Downhill - Freeride
    Last Post: 07-26-2012, 06:44 PM
  5. Upgraded
    By Adam_B. in forum Beginner's Corner
    Last Post: 04-19-2011, 07:44 PM
