Results 1 to 18 of 18
Thread: Shipping
    Shipping
    Good morning, Jeremy. I see you are up early.
    Just wondering, ordered a Goblin XO Wed. Never got a shipping notification. I am thinking I'll get one tomorrow. Are you aware of any delay in Goblin XO shipping?
    Thanks.
    Have a great day.
    BTW: at the risk of being flamed I have a non-Airborne question.
    We spoke on the phone about tubeless vs tubes. I understand that tubeless allows for lower pressures and there fore a more compliant ride. I imagine this translates into comfort as well as more traction on steep hills and technical terrain.
    However if running a cross country race don't we want the least rolling resistance (greater speed)? That would mean higher pressure which means less tire surface area contacting the road.
    In this case it could be tubes or I suppose tubeless at higher pressure.
    Advantage of tubeless at higher pressure would be no stopping to change a flat during a race. I think this scenario is perhaps the only one where tubeless truly shines.
    Any thoughts on this deep question early on a Sunday morning.
    Dr. Jay
    Dec 2012
    Quote Originally Posted by drjay9051 View Post
    Thanks.
    Have a great day.
    Dr. Jay
    I can help you with the tire question. Yes tubeless allows you to get a lower pressure with out pinch flats like you would get with the tube. If you are someone who wants to run below 35-40 psi tubeless is the way to go and the lower pressure will give better grip overall. I would imagine as long as you have what psi is printed on the tire and not over it you shouldn't have a problem blowing the tire bead off the rim. I see plenty who run tubeless and im not one of them ..... yet, unless I keep getting flats then ill consider it . I never see anyone having serious problems with tubeless. You'd also for a race want to look for a faster tire such as those specifically made for racing which i'm sure you know helps your speed.
    Hope this helps,
    sfb12
    Quote Originally Posted by sfb12 View Post
    Hope this helps,
    sfb12
    I agree. Lower pressure = more tire surface area contacting terrain which would give better traction. However doesn't the lower pressure just slow you down as the resistance is greater? I am not suggesting that one need to go all out. Myself on technical stuff I go slower so speed is not an issue. So here is another area where tubeless may be a better way to go. Sort of like watching Big Foot (the vehicle, not the ape ) crawl over stuff.
    For everyday relatively smooth trail stuff where grip is not an issue I'm thinking tubes.
    As an alternative to lower pressures why not use a different tire which is more "knobby" such as Kenda Nevagal ?
    Lots to learn.
    Reputation: BoomerBrian's Avatar
    Shipping
    I find lower pressure doesn't slow me down. More tread on the ground allows me to carry more speed into turns. On dirt I think the benefits of lower pressure is greater than possibly adding some resistance.
    Nov 2012
    Re: Shipping
    I'm interested to know when/if my goblin shipped out on Friday as well. I ordered Wednesday also.
    Quote Originally Posted by trevor_b View Post
    Trevor: Cannot wait , can you ? Not sure if Jeremy can check on this today just thought I'd post it.
    Is this your first 29er ??
    Nov 2012
    Re: Shipping
    I sure can't wait. It is my first 29er and will actually be my first mountain bike that should fit me. My current one is a hardrock sport disc 26er with a 15" frame (bought it at a pawn shop for $150 when I was in college to get around campus). I then got into the sport and the small bike has been pretty uncomfortable (I'm 6' with a 34" Inseam). So I am pretty anxious about getting the goblin.
    Is this your first 29er? If so, I am jealous of the xo although I'm not sure that I need that much bike, but I would take it!
    U get the 20 inch frame? I do have a full sus. just had to get a hardtail.
    The XO is more than i really need but I'm treating myself for my birthday.
    The Goblin will be just fine for you. Why the hardtail instead of full ?
    Nov 2012
    Re: Shipping
    Yes I got the 20", what about you?
    I got the hardtail because I'm used to riding them and never needed a FS. I do ride a lot of rocky technical terrain so I could see the use for one. I'm also 24 so I don't need the extra suspension now. I think in the future I will probably own one. I like the look of the hobgoblin.
    5 11 31 inseam. Went with the 18
    Dec 2012
    Thats the right size. I'm 6' 1'' 32" inseam and I have a 19.5" skyhawk which is plenty good for my size.
    It will be interesting coming from a FS bike.
    I imagine a very different feel. Probably have to change my technique a bit. Time to get out of the saddle.
    Reputation: BigDaddyFlyer's Avatar
    Hey, Dr. Jay, I know your bike shipped out friday and we are in the process of sending out tracking numbers this morning. Thanks!
    Jeremy
    Please Note: I no longer work for Airborne. If you have an Airborne question or problem please contact them directly.
    Quote Originally Posted by BigDaddyFlyer View Post
    Jeremy
    BDF:
    Appreciate the reply. I feel like it's Christmas eve.
    Look forward to the first ride on Friday.
    Jay
    Sorry I missed this earlier this morning. What's your order#? I can check it for you.
    Jeremy
    Found it. It shipped. Let me know if you didn't get your trackin# earlier today via email. Thanks!
    Nov 2012
    Re: Shipping
    I did get it, thanks Jeremy. Looks like you guys switched to FedEx? If I remember correctly, it said UPS during checkout.
    No, it's said FedEx for the past month or so. We switched back to FedEx after a trial 2 month run with UPS. It just wasn't working for us.
  1. RWC shipping
    By Wasmachineman NL in forum Shocks and Suspension
    Last Post: 12-25-2012, 08:07 AM
  2. TS2.2 for $182.75 + $16.95 shipping
    By wschruba in forum Where are the Best Deals?
    Last Post: 11-12-2012, 09:50 PM
  3. on-one shipping to US
    By mnigro in forum On One
    Last Post: 08-15-2012, 02:27 PM
  4. Cheapest Shipping Cost for shipping a bike?
    By TheYoungBikeDude in forum General Discussion
    Last Post: 03-14-2012, 06:14 AM
  5. Why oh why...shipping?
    By Shark in forum General Discussion
    Last Post: 02-24-2011, 04:42 PM
