Results 1 to 8 of 8
    Sep 2013
    Shifter clamp bolts too tight?
    Is anyone else running into this? I got a new carbon handlebar, new stem and grips in today and wanted to install them. Unfortunately the torx bolts on the X7 shifter clamps are so tight it's twisting and distorting the torx bit I have.
    Any ideas?
    Sep 2012
    There should be some thread exposed on the bolts between the clamp. Put some oil or chain lube in there and let it soak in a while then try again. Use a liberal amount of lube.
    Mar 2013
    I agree. I found mine to be super tight when replacing my handlebar. However, I was using a socket torx so I was able to break it loose without bending the bit.
    Sep 2013
    I ended up getting it off. I had grabbed a T20 by accident instead of a T25.
    The new ControlTech carbon bar is SO NICE. Just took a ride on some local trails and there's a noticeable difference in weight and vibration isolation.
    Sep 2013
    Here's the "after" view:
    <a href="http://www.flickr.com/photos/iso100/9971178425/" title="_DSF3020 by iso100, on Flickr"><img src="http://farm8.staticflickr.com/7418/9971178425_f0edee82f1_z.jpg" width="640" height="427" alt="_DSF3020"></a>
    <a href="http://www.flickr.com/photos/iso100/9971307303/" title="Controltech Carbon Bar by iso100, on Flickr"><img src="http://farm8.staticflickr.com/7293/9971307303_e27737d591_z.jpg" width="640" height="427" alt="Controltech Carbon Bar"></a>
    Reputation: s0ul_chicken's Avatar
    Aug 2013
    Nice! Looks great!
    Sep 2013
    Thanks! Now to decide which trails to ride this weekend.
    Sent from my Nexus 7 using Tapatalk 4
    Reputation: BigDaddyFlyer's Avatar
    Like! Looks great. Carbon bars are a great upgrade both visually and functionally!
    Jeremy
    Please Note: I no longer work for Airborne. If you have an Airborne question or problem please contact them directly.
  1. 08 Enduro Bar Clamp and Crown bolts
    By CMH22 in forum Specialized
    Last Post: 05-21-2013, 06:26 PM
  2. Replacement Magura clamp bolts?
    By Rustyy117 in forum Brake Time
    Last Post: 04-08-2013, 06:52 AM
  3. Stem/Steerer Clamp bolts loosen
    By Adroit Rider in forum Tooltime
    Last Post: 08-28-2012, 07:24 PM
  4. Help...need X9 shifter clamp
    By Francine in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-10-2012, 05:59 AM
  5. How tight is too tight.....seat post clamp?
    By rsolti13 in forum 29er Components
    Last Post: 07-24-2012, 07:17 AM
