Results 1 to 12 of 12
    Sep 2013
    New question here. Seeker tubeless conversion question
    Has anyone here attempted to convert to tubeless using the stock rims and tires on the Seeker? I ordered a Seeker Friday and since I live in Tucson, want to convert to tubeless, but don't want to have to buy new tires or rims to do it.
    Sep 2012
    If you buy a Stan's kit, I'd bet you can do it.
    I'm pretty sure that folks have set up the Geax AKA as tubeless with other wheels.
    The Stan's kit will likely seal up the wheels, so you should be good.
    Be sure to post your results whether you get it to work or not. Other folks will be happy to hear.
    Resident Gear Head
    Reputation: provin1327's Avatar
    Mar 2013
    Not sure about the Seeker wheels but I tried a Stans kit on my Guardian and it would not seal. It looked like the rim was too deep for the Stans kits that I tried. I just went with Gorilla tape, 2 valves, and some Stans sealant, sealed right up with some Continental Mountain kings.
    2 Hands Working Do More Than 1000 Hands Praying
    Sep 2013
    Thanks for the replies.
    Quote Originally Posted by provin1327 View Post
    Provin, what width gorilla tape did you use?
    Resident Gear Head
    Mar 2013
    I choose the cheapest roll of gorilla tape I could buy because no wheel is going to be as wide as the roll of tape haha. I measured the rim straight across then cut a strip of tape at the same width, made sure it covered the rim 100%, put on the tire and aired it up to ensure a seal, removed tire and added sealant. All done
    Here is a simple how to
    Tech Tuesday: Gorilla Tape Tubeless Conversion - Pinkbike
    Sep 2013
    Thank you provin, for the tip and the link. Looks easy and inexpensive enough to try.
    Sep 2012
    so the split tube method wont work on the stock seeker rims and tires?
    The split tube should theoretically work but it seems like people, in general, have far more success with gorilla tape or with the actual Stans tape (not the conversion kit, the roll of tape.) Gorilla tape is quite a bit cheaper though.
    when people do split tube, they typically use BMX/20" tubes.
    Eric
    Sep 2012
    Quote Originally Posted by skyphix View Post
    This might be an issue because the seeker shows presta valves on the website, so the rims would be a limiter. I like the design of the split tube method myself -- makes more sense to me.
    Quote Originally Posted by BodyLinksystems View Post
    Why is presta an issue?
    Q-Tubes Standard 20" Presta Tube > Components > Tires and Tubes > Tubes | Jenson USA Online Bike Shop
    20" tube, presta, up to 60mm valve length, removable core to fill with sealant.
    Eric
    Reputation: BigDaddyFlyer's Avatar
    There are 20" BMX tubes available in Presta.
    Jeremy
    Please Note: I no longer work for Airborne. If you have an Airborne question or problem please contact them directly.
    Sep 2012
    Great info, and thanks guys! I really just assumed trying to find a 20" bmx tube in presta would be an internet treasure hunt. Double-plus good for the Jenson USA link!
  1. Tubeless conversion question
    By DPCardoza in forum Wheels and Tires
    Last Post: 10-18-2013, 08:29 PM
  2. Tubeless conversion (non-tubeless ready stuff)
    By For Waukee in forum 29er Components
    Last Post: 08-09-2013, 07:27 PM
  3. Tubeless conversion
    By TxRider89 in forum Specialized
    Last Post: 01-19-2013, 05:23 PM
  4. Tubeless conversion question- leaking at Presta valve
    By polar8 in forum Wheels and Tires
    Last Post: 11-01-2012, 10:23 PM
  5. Replies: 9
    Last Post: 07-04-2012, 01:28 AM
